Read Modify Write problem?
Results 1 to 5 of 5
    Jun 2005
    Question Read Modify Write problem?
    I am writing to a 7segment LED display with a 16F627A and believe I might be experiencing a Read Modify Write problem, some segments will not turn off.
    If I use a pullup resistor on the output the segments will turn off. It seems like the output pin is being read as an input.
    I turned off analog comparators and set TRISA = %00001100 and
    TRISB = %00000010.
    Any suggestions how should I modify controlling the outputs?
    X0 is my variable that has the segment pattern and I write
    each output pin. Hardware serial port uses portB.1 & portB.2
    and prevents writing a word to the entire portB.
    PORTB.0 = X0.0 ' Send segments to LED
    PORTA.4 = X0.1
    PORTA.6 = X0.2
    PORTB.3 = X0.3
    PORTB.4 = X0.4
    PORTB.5 = X0.5
    PORTB.6 = X0.6
    PORTB.7 = X0.7
    Mark
    Hi Mark,
    Instead of trying to set the PORT's either high or low, set the PORT to the active ON state, then set the TRIS bit to INPUT(1) or OUTPUT(0) to control the LED's. No R-M-W that way.
    Jun 2005
    Thanks Darrel,
    Is this what you meant?
    Variable X0 is the segment pattern and is sent to the output ports.
    TRISB. I use OR to maintain portB.1 as input
    TRISA. I use OR to maintain PortA.2 and PortA.3 as inputs
    Is there an better approach?
    'initialize ports
    TRISA = %00001100 'configure port A outputs = 0
    TRISB = %00000010 'configure port B outputs = 0
    Mark
    'write segments to ports A and B
    PORTB.0 = X0.0 ' Send segments to LED 0 = ON
    PORTA.4 = X0.1
    PORTA.6 = X0.2
    PORTB.3 = X0.3
    PORTB.4 = X0.4
    PORTB.5 = X0.5
    PORTB.6 = X0.6
    PORTB.7 = X0.7
    TRISB = X0 OR %00000010 ' OFF segments = 1 (set to inputs)
    X1=X0 AND %01010000 ' isolate X1= PortA.4 and PortA.6 bits
    TRISA = X1 OR %00001100 'maintain PortA.2 and PortA.3 inputs
    uh, nope.
    I was thinking something more like this.
    PORTA = 0
    PORTB = 0
    TRISB.0 = X0.0 ' Send segments to LED 0 = ON
    TRISA.4 = X0.1
    TRISA.6 = X0.2
    TRISB.3 = X0.3
    TRISB.4 = X0.4
    TRISB.5 = X0.5
    TRISB.6 = X0.6
    TRISB.7 = X0.7
    Jun 2005
    Wink
    Thanks Darrel,
    That is much cleaner! I will give it a try.
    Mark
  1. Cleaning up code
    Last Post: - 2nd December 2009, 07:14
  2. write -read problem?
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 30th August 2009, 13:06
  3. Read Write Problem
    By kduck63 in forum mel PIC BASIC Pro
    Last Post: - 15th June 2009, 19:03
  4. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 11:20
  5. problem to read write 24LC512
    By edysan in forum mel PIC BASIC Pro
    Last Post: - 19th February 2008, 21:46
