Can not get my IF THEN statement to work
Results 1 to 10 of 10
    Rhatidbwoy's Avatar
    Rhatidbwoy Guest
    Default Can not get my IF THEN statement to work
    I am trying to check values within the ram and all that I am getting is a continuous count. Is there something that I am doing wrong or what could be a reason for the problem that I am having.
    VARINC:
    B7 = B7 + 1
    goto check
    VARDEC:
    B7 = B7 - 1
    goto check
    CHECK:
    if B6 = $31 and B7 < $35 then twenf '25
    twenf:
    poke B6,$32: poke B7,$35
    if B6 = $32 and B7 > $35 then fift '15
    fift:
    poke B6,$31: poke B7,$35
    if B6 = $32 and B7 < $30 then nint '19
    nint:
    poke B6,$31: poke B7,$39
    if B6 = $31 and B7 >$39 then twent '20
    twent:
    poke B6,$32: poke B7,$30
    goto cs
    Aug 2005
    If your code is as shown,the if statements mean nothing as each line after the if statement is scanned during each run cycle.The if statement label code needs to be located else where in the program so as it is scanned only when the if is true.
    Rhatidbwoy's Avatar
    Rhatidbwoy Guest
    meaning the line to follow the if then statement needs to be else were to make the statement do what it is suppose to do. Ok that makes a little sense when thinking about it. I tried pulling the line labels that would make the statement true elsewhere in my program and same results. it looks something like this:
    CHECK:
    goto cs
    twenf:
    poke B6,$32: poke B7,$35:goto cs
    fift:
    poke B6,$31: poke B7,$35:goto cs
    nint:
    poke B6,$31: poke B7,$39:goto cs
    twent:
    poke B6,$32: poke B7,$30:goto cs
    this make sense to having the if then statement work rather than the other one, but I still get no response to how I think that the the if then statement should work. I am still falling out of my limits when i do the scrolling of me wanted value of 15 to 20.
    P.S. the whole program is attached
    Aug 2005
    goto cs
    Nov 2004
    Saskatchewan Canada
    If you really are using PicBasic and NOT PicBasic Pro then any ENDIF and ELSE statements won't work for you. Keep that in mind when writing your program. You need to work around that. Some of the solutions presented won't work "as is" for that reason.
    Rhatidbwoy has the right idea in his example.
    Bart
    Aug 2005
    Houston, TX
    I have never been able to get an "If - Then" command to work using more that one condition in PIC Basic. That is no A and B. Only A, then another question.
    If I want to test a as 10 plus b at 20 for calling x:
    loop:
    if a = 10 then isb
    loopb:
    isb:
    if b = 20 then x
    goto loopb
    Nov 2004
    Saskatchewan Canada
    AND and OR are valid PicBasic commands used with IF/THEN and the proper syntax is "IF A=1 AND B=2 THEN" so if your's aren't working I don't think that is the reason. I'm just not good enough at reading other people's code to sort out the why.
    Sorry.
    Bart
    Perth, Australia
    shouldnt the line "if B6 = $31 and B7 < $35 then twenf" read:
    if B6 = $31 and B7 < $35 then GOTO twenf ?
    or is the GOTO not required when using an if statement?
    dw_pic's Avatar
    dw_pic Guest
    To my knowledge, "with picbasic, not pro"
    The picbasic compiler will see the added "goto" as a undeclared symbol and choke on it.
    the action is a goto, but the syntax is
    if X = true then label
    dw
    Rhatidbwoy's Avatar
    Rhatidbwoy Guest
    The problem that I have with the statement is that when it is executed to the goto from the IF...THEN I used poke. When writing to a VAR I do not need the poke, but when I need to write to a address on the chip, per-say, that is when I would use the poke or peek. Example: POKE $86,0 for writing to the chip ;
    (NOT CORRECT)
    twenf:
    (CORRECT)
    twenf:
    B6 = $32 : B7 = $35 : goto cs
    OR
    twenf:
    B6 = $32
    B7 = $35
    goto cs
  1. END Statement
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 9th November 2008, 14:48
  2. How do I get DATA @ to work with a 18F452?
    Last Post: - 2nd February 2006, 10:35
  3. blink.bas help cant make any 18f's work
    By Bonxy in forum mel PIC BASIC Pro
    Last Post: - 13th December 2004, 21:28
  4. Pin RA4 doesn't work
    Last Post: - 15th July 2004, 12:03
  5. Interrupt Problem
    By FrankM in forum mel PIC BASIC Pro
    Last Post: - 20th June 2004, 15:53
