I2C Communication between PIC18F4550 and AS5600
+ Reply to Thread
Results 1 to 8 of 8
    Mar 2024
    Default I2C Communication between PIC18F4550 and AS5600
    Hello,
    I am trying to communicate between PIC and AS5600 chip. I am not sure if the commands I send are correct. The only data I receive back from AS5600 is "6" for B0 and "6" for B1.
    Here is part of my code:
    define LOADER_USED 1
    define OSC 24
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 38400
    DEFINE HSER_CLROERR 1
    Define LCD_DREG PORTD
    Define LCD_DBIT 4
    Define LCD_RSREG PORTD
    Define LCD_RSBIT 1
    Define LCD_EREG PORTD
    Define LCD_EBIT 0
    define LCD_BITS 4
    define LCD_LINES 2
    define CCP2_REG PORTC
    define CCP2_BIT 1
    ADCON1 = 15 'make all inputs and outputs digital
    TRISA = %11111111 'set up port A as input
    TRISC = %10000000 'set up port C as output/input (Rx-1,Tx-0)
    TRISB = %11111111 'set up port B as input
    TRISD = %00000000 'set up port D as output
    TRISE = %00000000 'set up port E as output
    PORTC = %01000100
    DEFINE I2C_SCL PORTB,1
    DEFINE I2C_SDA PORTB,0
    DEFINE I2C_SLOW 1
    DEFINE I2C_HOLD 1
    DEFINE CHAR_PACING 102
    start:
    B0 = 0
    B1 = 0
    i2cwrite PORTB.0,PORTB.1,$36,$0E,[0]
    pause 10
    i2cwrite PORTB.0,PORTB.1,$36,$0E,[1]
    pause 10
    I2CREAD PORTB.0,PORTB.1,$36,$0E,[B0]
    pause 10
    I2Cwrite PORTB.0,PORTB.1,$36,$0F,[0]
    pause 10
    I2Cwrite PORTB.0,PORTB.1,$36,$0F,[1]
    pause 10
    I2CREAD PORTB.0,PORTB.1,$36,$0F,[B1]
    pause 10
    LCDOut $FE, 1, dec B1
    LCDOut $FE, $C0, dec B0
    goto start
    Any help you can provide in this matter will be appreciated.
    Default Re: I2C Communication between PIC18F4550 and AS5600
    Well, from the datasheet I could not understand much about how to read data from the chip.
    What are the $0F and $0E after $36 in your commands?
    Also, are you sure you have connected correctly data and clock of the I2C bus from PIC to AS5600?
    the data sheet address is a 7 bit address pbp uses 8 bit address
    what are ic2writes for ?
    they seem to be of no value that i can see
    you defined sda and scl why not use them ?
    more like
    start:
    I2CREAD SDA,SCL,$6C,$0E,[B0,B1]
    goto start
    Mar 2024
    $36 is I2C address for AS5600
    $0F and $0E address for low and high bytes from encoder.
    I am pretty sure the data and clock are connected correctly. Also I pull them hight with 4.7k resistor.
    Mar 2024
    I thought that I need to send trigger first to AS5600 (Master mode), but I might be wrong.
    Can I ask you why did you use
    $6C in read command? Shouldn't it be $36?
    the data sheet address $36 is a 7 bit address pbp uses an 8 bit address scheme
    You may well have to "configure" the device but for an i2c read transaction that is an unnecessary step
    both registers can be read in a single transaction as i indicated
    Mar 2024
    Does it mean that I can not communicate or I need to adjust the address?
    ok
    ok
    Thank you.
    Mar 2024
    I have used this one:
    and it works. Thank you very much for your help
  1. Replies: 18
    Last Post: - 4th July 2017, 14:26
  2. PIC18F I2C Communication with Arduino
    By picmilan in forum mel PIC BASIC Pro
    Last Post: - 14th July 2016, 21:38
  3. Replies: 0
    Last Post: - 26th May 2012, 13:57
  4. EEprom and MCP9801 I2C communication problems
    By aajgss in forum mel PIC BASIC Pro
    Last Post: - 3rd September 2011, 21:45
  5. Replies: 2
    Last Post: - 10th June 2005, 02:34
Members who have read this thread : 8
