PIC16F18446 - 12 bits ADC gives 16 bits results!!!!
+ Reply to Thread
Results 1 to 4 of 4
    SWITZERLAND (french speaking)
    Default PIC16F18446 - 12 bits ADC gives 16 bits results!!!!
    Still going ahead with the PIC16F18446...
    I'm testing the 12 bits ADC.
    First, I had to find out the correspondance between Pin and Channel (I'm using a 20-pin device). Here it is:
    The code I use is here:
    ' PIC 16F18446
        __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT1 & _CLKOUTEN_OFF & _CSWEN_ON & _FCMEN_ON
        __config _CONFIG2, _MCLRE_ON & _PWRTS_PWRT_64 & _LPBOREN_OFF & _BOREN_SBOREN & _BORV_LO & _ZCDDIS_OFF & _PPS1WAY_OFF & _STVREN_ON
        __config _CONFIG3, _WDTCPS_WDTCPS_31 & _WDTE_SWDTEN & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
        __config _CONFIG4, _BBSIZE_BB512 & _BBEN_OFF & _SAFEN_OFF & _WRTAPP_OFF & _WRTB_OFF & _WRTC_OFF & _WRTD_OFF & _WRTSAF_OFF & _LVP_OFF
        __config _CONFIG5, _CP_OFF
    ' Oscillator Control Register1
    OSCCON1 = %01100000 ' $60
    ' HFFRQ - Oscillator's Frequency Selection Register
    OSCFRQ  = %00000010 ' 4MHz
    DEFINE ADC_BITS 12   'Number of bits in ADCIN result
    ' ====== VARIABLES =================================================================================
    ADC_Value   var word
    Serial_Out  VAR PORTB.7
    Mode        Var BYTE
    ' ====== INITIALIZE VARIABLES ======================================================================
    Mode        = 84 ' serial com BdRate settings
    ' ====== TEST PROGRAM ==============================================================================
    TEST:
        ADCIN 23, ADC_Value ' ADC channel 23 is RC7
        Serout2 Serial_Out,Mode,["ADC in: ", dEC ADC_Value,13,10]
        PAUSE 500
        GOTO TEST
    Now, the strange thing is: where I expect a 12 bits result (0..4095), I get a 16 bits value 0..65520 as result and it's amazingly steady, not a digit variation!!!
    I'm using a 10 turns 10kOhms pot and that's all.
    How can that be please?
    Roger
    Default Re: PIC16F18446 - 12 bits ADC gives 16 bits results!!!!
    Your code does not set the ADCON0 register properly to right justify the result. The default is Left justification, hence the 65520, or FFF0 or 1111 1111 1111 0000 result, which seems as 12 bit just fine, only left justified.
    You need to set FRM bit to 1. It is the bit 2 in the ADCON0 register. Look at the page 536 of the datasheet. There are many other settings regarding ADC converter if you need other features.
    I bet that your first reading after 0 was 16 then 32, then 48 etc instead of 1,2,3
    Hum....its now obvious that I didn't read the DS first
    Thanks a lot for your time and patience for dreamers like me.
    Okay, let's go to page 536 then....
    PS: I forgot to mention that your information makes my PIC show the "correct" values now
    Roger
    Glad you got it working.
  1. Parity & Stop Bits settings and results
    By svjohngalt in forum Serial
    Last Post: - 27th January 2018, 20:16
  2. Replies: 2
    Last Post: - 23rd April 2013, 16:34
  3. Incorrect adc channel bits generated
    By grahamg in forum mel PIC BASIC Pro
    Last Post: - 6th February 2010, 18:56
  4. DT_INTS-14 /interrupts enable bits / flag bits
    By bogdan in forum mel PIC BASIC Pro
    Last Post: - 16th May 2009, 18:42
  5. parsing adc word into bits
    By GREYBIRDMAN in forum mel PIC BASIC Pro
    Last Post: - 13th April 2007, 21:08
Members who have read this thread : 10
