Blinker for 16F18446 - OSC settings and PORT addressing
+ Reply to Thread
Results 1 to 5 of 5
    SWITZERLAND (french speaking)
    Default Blinker for 16F18446 - OSC settings and PORT addressing
    Hi there,
    Did anyone already make a "blinker" for 16F18446? Mine won't work at all
    This device supports PPS (Peripheral Pin Select Module) and I this is new to me. Is there any captcha here?
    I also don't get the oscillator configuration. This device appearently uses PLL as oscillator. But how do I configure it to have kind of 4 or 8 MHz internal oscillator?
    The DS is (again) hard to understand....
    '====== FUSES =====================================================================================
    ' PIC 16F18446
        __config _CONFIG1, _FEXTOSC_HS & _RSTOSC_EXT1X & _CLKOUTEN_OFF & _CSWEN_OFF & _FCMEN_OFF
        __config _CONFIG2, _MCLRE_OFF & _PWRTS_PWRT_64 & _LPBOREN_OFF & _BOREN_SBOREN & _BORV_LO & _ZCDDIS_OFF & _PPS1WAY_OFF & _STVREN_OFF
        __config _CONFIG3, _WDTCPS_WDTCPS_31 & _WDTE_SWDTEN & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
        __config _CONFIG4, _BBSIZE_BB512 & _BBEN_OFF & _SAFEN_OFF & _WRTAPP_OFF & _WRTB_OFF & _WRTC_OFF & _WRTD_OFF & _WRTSAF_OFF & _LVP_OFF
        __config _CONFIG5, _CP_OFF
    ' ====== TEST PROGRAM ==============================================================================
    TEST:
        LATB.6 = 1
        LATB.6 = 0
    GOTO TEST
    Roger
    Default Re: Blinker for 16F18446 - OSC settings and PORT addressing
    you won't get far blinking pin latb.6 when its defined as an analog input
    i assume you are not using a xtal osc
    this will do it ,i think [ untested]
    ' PIC 16F18446
        __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT1 & _CLKOUTEN_OFF & _CSWEN_ON & _FCMEN_ON
        __config _CONFIG2, _MCLRE_ON & _PWRTS_PWRT_64 & _LPBOREN_OFF & _BOREN_SBOREN & _BORV_LO & _ZCDDIS_OFF & _PPS1WAY_OFF & _STVREN_ON
        ANSELB = $B0;
        TRISB = $B0;
       OSCCON1 = $60;
        // CSWHOLD may proceed; SOSCPWR Low power;
        OSCCON3 = 0
        // MFOEN disabled; LFOEN disabled; ADOEN disabled; SOSCEN disabled; EXTOEN disabled; HFOEN disabled;
        OSCEN = 0
        // HFFRQ 4_MHz;
        OSCFRQ = 2;
        // HFTUN 0;
        OSCTUNE = 0
    TEST:
        LATB.6 = 1
        LATB.6 = 0
    GOTO TEST
    for osc=8mhz
    // HFFRQ 8_MHz; OSCFRQ = 3;
    Last edited by richard; - 10th February 2024 at 09:54. Reason: nearly forgot osc setup
    Replace // with ' or ;
    Thumbs up Blinker for 16F18446 - OSC settings and PORT addressing
    Guess what: it's blinking now!
    Thanks a lot (again).
    Yes, I had to replace // by '
    Roger
    These chips (with PPS registers) need more care to setup correctly. But are very versatile...
  1. Replies: 4
    Last Post: - 13th January 2021, 00:43
  2. Port settings - 18F4620
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 20th November 2015, 06:17
  3. Port Addressing Issue
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2005, 19:15
  4. 18F2525 Int Osc settings?
    Last Post: - 26th March 2005, 22:44
Members who have read this thread : 8
