KiCad - free PCB design tool
+ Reply to Thread
Results 1 to 4 of 4
    Default KiCad - free PCB design tool
    I've been using KiCad for a few months now and I can't say enough good about this software. The structure of KiCad is very well organized (I used default components to make my first test circuit):
    - define a footprint in the footprint library
    - define a corresponding symbol in the symbol library (add link to footprint)
    - draw the schematic of your circuit (add link to symbol)
    - draw the PCB of your circuit using schematic
    Once you get the hang of things, it just seems to flow nicely (at least for me). I didn't take an online course at the beginning; I just jumped in after watching an intro video on youtube (I didn't save a link, sorry).
    I just found a neat little feature. Many devices like an EC11 rotary encoder have support brackets that are not part of the electrical circuit.
    Name:  Copper keep out.png
    Use the Rule Out Area tool in the footprint library, you can lock out the area under these supports as desired:
    And that's it. You don't have to do what I was doing; adding little hatch marks on the front silkscreen to remind me not to put anything in that area.
    Default Re: KiCad - free PCB design tool
    And if you want this metal bracket be earthed, if it is not on the electric circuit, how can you do it.
    I should have added a pic. I was talking about the metal supports that don't go through the PCB. The RK097 pot has 2 (bottom left unit), the 2 other through-hole supports are grounded:
    https://ae01.alicdn.com/kf/Sd244b8c1...4ef397562P.jpg
    I know the switch will be secured, but I can't leave a support "rub" against traces. A metal burr could potentially cut through the epoxy protective layer.
    It's just easier to avoid tracing through that area, than have to deal with some "freak untraceable ground" on a trace.
    I try to plan so that any student/intern could assemble these without requiring keen observational skills.
    Oh, I see. Got it now.
  1. Free PCB Prototype For New Customer
    By NilaYang in forum Adverts
    Last Post: - 18th August 2016, 15:23
  2. HTML design tool
    By ardhuru in forum WiFi
    Last Post: - 24th March 2016, 18:14
  3. PCB Design Software
    By dhouston in forum Off Topic
    Last Post: - 29th June 2012, 16:22
  4. PCB Design
    By BobEdge in forum Off Topic
    Last Post: - 7th November 2006, 14:45
Members who have read this thread : 8
