MCS vs MPLAB 8
+ Reply to Thread
Results 1 to 8 of 8
Thread: MCS vs MPLAB 8
    May 2009
    Saint-Quentin-en-Yvelines, FRANCE
    Default MCS vs MPLAB 8
    Hi Everybody,
    From time to time it's good to sit and to reconsider one's own beliefs and maybe to optimize or chose an other way...
    I have developped several projects with some PIC18LF2685 and PIC18LF26K22, using of course PBP under MPLAB 8 and PicKit 2/3. MPLAB X is a nightmare for me. I really dislike it but MPLAB 8 it now getting quite old.
    For my future projects, with a PIC18LF26K22 what would be the pros (is any) of using Micro Code Studio ? Would it replace MPLAB 8 ? Would it replace PicKit3 as a debugger and/or as a programmer ? On the other hand what would be the cons ?
    Thank you for your help
    MikeBZH
    Aug 2011
    Default Re: MCS vs MPLAB 8
    You can use MPLAB8 (MPLAB v8.92) as a programmer and debugger for both those chips with a PICKit3.
    MCS won't let you do any hardware debugging, just programming. Any "debugging" under MCS is really done using software, so I wouldn't recommend it.
    I'd stick with what you're doing. I still use MPLAB8 for any chips that are supported even though I use MPLABX for the others.
    OK
    What need do you feel XC8 would fill that PBP currently does not? I did migrate to MPLABX, but to gain access to 16-bit PICs (with XC16). That was what I had to gain.
    May 2009
    Angry Re: MCS vs MPLAB 8
    Thank you for your answers.
    Yes, I also went to MPLABX and XC16 for a development with a 24F chip. Very bad experience !
    Coming back to MCS, yes it is a little bit poor for debugging and MPLAB 8 should be better for this task.
    But in the field programming without a PicKit may be interesting.
    MikeBZH
    PS : Please do not consider the in the title. It should be but I cannot change it !
    Aug 2011
    To do that you'll need to implement a bootloader and be able to transfer the program via a serial port link or some other method.
    Is that what you're after?
    Quote Originally Posted by MikeBZH View Post
    MikeBZH
    Hi, Britton ...
    for 16bits, you could try the MikroBasic Pro for DSPic ... eval version is free ... not so hard to turn to ...
    for MCS, you can buy the "Plus" license and then get the debug feature ...
    I do use MPLAB 8.32 for 8 bits, for debugging purposes. But MPLABX 5.30 is fine for programming and using ICD4 ... ( also still have the v 2.35 on the computer !!! )
    note my Old Picstart plus works fine with Win 10/64 !!!
    Still sometimes use PBP with Win XP for the Pickit2 or ICD2 ...
    May 2009
    Red face Re: MCS vs MPLAB 8
    Trugarez braz AceTronics ! : (sorry, private joke )
    A lot of options to explore.
    I was not aware of all these development tools. It opens some interesting ways.
    MikeBZH
    MikeBZH
    no need to bow down ...
    long time I'm no more " super moderator "
  1. Mcs ide
    By Ioannis in forum PBP3
    Last Post: - 7th April 2020, 12:53
  2. What MCS do you use?
    By SKOLS1 in forum mel PIC BASIC Pro
    Last Post: - 29th July 2011, 22:56
  3. problem with MCS
    By James1 in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2010, 04:48
  4. mcs prob
    By andrewwaack in forum mel PIC BASIC Pro
    Last Post: - 8th January 2009, 09:59
  5. Compile using MCS
    By Angus Anderson in forum mel PIC BASIC Pro
    Last Post: - 26th February 2007, 18:50
Members who have read this thread : 14
