Using as many internal peripherals as possible.
+ Reply to Thread
Results 1 to 12 of 12
    Default Using as many internal peripherals as possible.
    I wonder how small the code can it be if I use as many internal peripherals as I could (and I know).
    The task is simple, alternately slowly flash LEDs on ports RA0 and RA1. If the supply
    voltage goes below 3V lit up the LED on port RA2.
    I used PIC12F1840 mcu. Used it's comparator, fixed voltage reference and Timer0.
    The code compiles used 42 words.
    Just for fun, I wonder if it is possible to program it more effectively?
      __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_ON
      __config _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_ON & _BORV_19 & _LVP_OFF
    OSCCON = %01101010
    TRISA   =    %010000   ; RA4 input, rest output
    ANSELA  =    %0000     ; ADC Disable
    OPTION_REG = %10000111 ; Disable internal pull-ups, TMR0 On, prescaller to 256
    FVRCON  =    %10011000 ; Internal reference to 2048V
    CM1CON0 =    %10100110 ; comparator uotput to C1OUT, switch on LED if voltageis beloe ref 2,048V
    CM1CON1 =    %00100001 ; C1IN1- pin is RA4, comparator voltage input, C1IN1+ positive input to FVR set to 2,048V
    LATA    =    %000010   ; init state of pin RA0 and RA1, LEDs connected to these port
    n var byte  : n=0      ; init n value to 0
    if INTCON.2 = 1 then n=n+1 : INTCON.2 = 0 ; if TMR0 owerflow increment n by 1, then clear owerflow flag
    if n=10 then LATA = LATA ^ %000011 : n=0  ; if n=10 then invert bit 1,0. Pins RA0 and RA1 alternately flash the LEDs
    goto Main
    Default Re: Using as many internal peripherals as possible.
    Even better, only 33 words.
    OSCCON =     %00110010 ; Clock 250kHz
    TRISA   =    %010000   ; RA4 input for battery measurement, rest output
    FVRCON  =    %10011000 ; Internal reference to 2048mV
    CM1CON0 =    %10100110 ; Comparator output to C1OUT, switch on LED if voltage is below ref. 2,048V
    if INTCON.2 = 1 then LATA = LATA ^ %000011 : INTCON.2 = 0 ; if TMR0 owerflow flip LEDs, then clear owerflow flag
    I think, reached the limit of optimization.
    How about this?
      n = n + INTCON.2
      INTCON.2 = 0
      IF n.3 THEN
          n=0
      goto Main
    It won't produce exactly the same frequency as your example but it's 12% smaller (37 words). I suppose there's also the odd chance/risk of the TMR0 interrupt bit being set in between checking it and clearing it. You COULD also do away with the n=0 at the start with the drawback of the FIRST iteration taking longer depending on the start value of n. AND, possibly, get rid of the GOTO Main and let the PC freerun and start over from the top.
    Adding DEFINE NO_CLRWDT 1 saves one or two words depending on which version.
    Using TMR1, which is 16 bits with its 8:1 prescaler instead of counting overflows should achieve similar results
    T1CON = %00110001
    IF PIR1.0 THEN
        PIR1.0 = 0
    Goto Main
    Combining these I got it down to 34 words but have not checked if it actually works.
    I tested your codes, both works. The second example with TMR1 I like the most because maintain 4MHz clock. And yes, it compiles only 34 words. Just one more word than mine when I manipulate the clock speed.
    Nice.
    In my minimalist mania, I tried using interrupts. On pin RA3 hooked up 10k pullup and pushbutton to ground. On pin RA5 LED. First I tried the On Interrupt statement from PBP not work at all. Then I tried DT Instant interrupts, which worked flawlessly but the code size was a little big.
    Then I came up with this. Is it ok to use interrupts like this?
    I welcome comments so that I can learn from them.
    DEFINE INTHAND INT
    DEFINE NO_CLRWDT 1
    OSCCON = %01101010
    TRISA   =    %011000   ; RA4 input for battery measurement, RA3 input on change, rest output
    LATA    =    %000001   ; init state of pin RA0 and RA1, LEDs connected to these pins
    T1CON = %00110001      ; TMR1 On, prescaller 1:8, Fosc/4
    INTCON = %11001000     ; Enable GIE, PEIE, IOCIE
    PIE1.0 = 1             ; Enable TMR1IE Owerflow interrupt
    IOCAN.3 = 1            ; Enable RA3 negative edge OnChange interrupt
    ; ------------  With TMR1 and interrupt, oscilator 4MHz ---------------
    ; pause 10000 ; some stuff here
    ; ------------  INT Handler Routine ---------------
    asm
    INT:
    endasm
    IF PIR1.0  THEN LATA = LATA ^ %000011 : PIR1.0 = 0  ; Flash the LEDs on RA0 and RA1 alternately
    if IOCAF.3 then LATA = LATA ^ %100000 : IOCAF.3 = 0 ; Toggle LED on Pin RA5 if button on RA3 is pressed
    @ RETFIE
    It compiles only 58 words, and the main section is empty, ready for some other code.
    no , you may appear to get away with inserting pbp statements in an ASM interrupt but it is a delusion.
    pbp statements set many internal variables to enable complex statements to be evaluated , executing foreign statements from an isr will pollute this process. thats why dt-ints exists.
    use asm code in asm interrupts like this
    #CONFIG  __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_ON
    DEFINE INTHAND myINT
    DEFINE NO_CLRWDT 1
    OSCCON = %01101010
    asm
    myINT
     movlw 0
     banksel PIR1
     btfsc PIR1,0
     movlw 3
     bcf PIR1,0
     banksel IOCAF
     btfsc IOCAF,3
     iorlw 32
     bcf IOCAF,3
     banksel LATA
     xorwf LATA,f
     RETFIE
    endasm
    Thanks Richard for the answer. I understand. In more complex cases, this could cause problems.
    In my case, it works, but it is not correct to combine it like this.
    So in PBP use only On Interrupt statement or DT Interrupts. Or only ASM interrupts.
    Alternatively, a system variable can be set up, e.g.:
    Test VAR BIT SYSTEM
    and use it from PBP and ASM?
    If I want to set the Test in PBP
    Test = 1
    or
    @ bsf Test
    If I want to set the Test in ASM
    bsf Test
    and use the variable from both PBP and ASM. Or it's not possible that way either.
    Test VAR BIT SYSTEM
    Will create a var in this case called PB01
    and then define test as bit 0 in that var
    #define Test PB01, 000h
    @ bsf Test
    translates to
    @ BSF PB01 , 0 ;set test to a logic 1
    bit vars and declaring them to be system located in no way makes their use asm interrupt safe if used with pbp statements in said isr
    its the pbp statements not the vars where the issue lies
    What I trying. Omit PBP code from ASM interrupt routine.
    But this try not work, of course.
    Where is the problem?
    DEFINE INTHAND INT
    DEFINE NO_CLRWDT 1
    OSCCON = %01101010
    Switch var bit SYSTEM : switch = 0
    if porta.3=0 and switch=1 then
    pressed:
    pause 20
    if porta.3=0 then pressed   ; if the button is still pressed loop and wait for release
    Switch=0
     asm
    INT
     banksel IOCAF
     btfsc IOCAF,3
     bsf Switch                       ; set bit in Switch to 1
     bcf IOCAF,3
     RETFIE
    endasm
    Aug 2011
    Among other things...
    - that's not the form of an asm 'bsf' instruction
    - you may have issues with the proper bank being selected... you are specifying 'banksel IOCAF', but where is 'Switch' located?
    When writing asm it will do exactly what you specify... correct or not.
    Good luck trying to get pbp to set a bit var where you need it be
    use a byte and place it in access space if you have to
    enabling the timer1 interrupt and not servicing it will not work well
    DEFINE INTHAND INT
    DEFINE NO_CLRWDT 1
    OSCCON = %01101010
    ANSELA  =    0     ; ADC Disable
    PIE1.0 = 0             ; DISable TMR1IE OVerflow interrupt
    Switch var BYTE  $7f  SYSTEM
     Switch = 0
    pressed:
    pause 20
    Switch=0
     asm
    INT
     banksel IOCAF
     btfsc IOCAF,3
     bsf Switch,0                      ; set bit0 in Switch to 1
     bcf IOCAF,3
     RETFIE
    endasm
    Thank you, Richard, for the explanation.
    Now I have a clearer understanding of how to work with variables and share them in ASM and PBP.
    Active TMR1, yes. I just forgot to comment on this line.
    Whenever I have the time, I try to learn something new about programming in PBP.
    Right now, I'm experimenting with interrupts.
    Advice like this is helpful in my efforts.
    Louis
  1. New cool PIC peripherals
    By HenrikOlsson in forum General
    Last Post: - 21st September 2016, 20:50
  2. Replies: 8
    Last Post: - 21st March 2015, 17:21
  3. Replies: 4
    Last Post: - 11th June 2014, 22:53
  4. Replies: 0
    Last Post: - 7th August 2008, 09:02
  5. Internal Oscillator
    By jhorsburgh in forum General
    Last Post: - 10th December 2007, 02:13
Members who have read this thread : 15
