Using same button for entering/exiting some part of code?
+ Reply to Thread
Results 1 to 18 of 18
    Default Using same button for entering/exiting some part of code?
    Hello. This might sound simple, but I can't find the reliable solution.
    Say I have button, input pin, which is tied to VDD via 10K resistor.
    Pressing button pulls input pin down.
    There is in some code, say code1, which runs in loop.
    When user press button, execution goes to code2, which also runs in loop.
    While in loop2, when user presses the button, execution is returned to code1
    The issue is, if user keeps button pressed, the code will jump from code1 to code2 and back from code2 to code1.
    To avoid this, the button state should be checked, so when user presses the button while in code1, jump to code2 will not occur until he releases the button.
    I tried to use BUTTON statement, but it is not handy, since it only can do jump to label, and sometimes I just want to change value of some variable. And sometimes buttons are tied to ADC, so different button returns different ADC value.
    Is there a simple way for fixing the issue I have?
    Default Re: Using same button for entering/exiting some part of code?
    I made a multi-function timer that deals with that and does different things according to how long sw is pressed ( and improved it to a touch sw using a/d)...... simply loops through routines using counts of pauses between sw presses.
    part of sw press checks......
    FOR B5= 1 TO 10 '.1 SECONDS FOR TIMER
    PAUSE 6
    if GPIO.1= 1 then start
    NEXT B5
    read 1,b6 :PAUSE 10: W0=60*B6:W1=W0
    HIGH 4 ': HIGH 2
    FOR B5 = 1 TO 100 '2 SECONDS FOR 6 HR
    PAUSE 10
    if GPIO.1=1 then TIMER
    NEXT B5
    W0=28800 '8 HRS
    HIGH 2
    You might do something like this:
    Obvioulsy you can't have code that takes a long time to exectute in each section or you'll miss the button press. If that's the case, move the code that handles the button to a subroutine and call that routine multiple times from within the section(s) that takes the longest time.
    ButtonPressed          CON 0
    FirstPieceOfCode       CON 1
    LastPieceOfCode        CON 3
    CodeToRun              VAR BYTE
    ButtonHasBeenPressed   VAR BIT
    ChangeButton           VAR PortB.2
    CodeToRun              = FirstPieceOfcode
    ButtonHasBeenPressed   = 0
      If ChangeButton = ButtonPressed THEN
        ButtonHasBeenPressed = 1
      IF (ButtonHasBeenPressed = 1) AND (ChangeButton <> ButtonPressed) THEN  ' But was pressed but is now released
        CodeToRun = CodeToRun + 1             ' Advance to next code section
        If CodeToRun > LastPieceOfCode THEN   ' Wrap around and start over
          CodeToRun  = FirstPieceOfCode
      Select Case CodeToRun
        Case 1
           'Some code
       Case 2
           'Some other code
        Case 3
           'Yet some other code
      END SELECT
    Goto Main
    This is not tested or even compiled so use it as an idea.
    I think, there is some misunderstanding.
    Here what I need
    code1:
    if button=0 then goto code2
    'somecode here
    goto code1
    code2:
    if button=0 then goto code1
    'somecode here
    goto code2
    So all I need is when user presses the button in code1, execution won't jump to code2 until he releases the button. And same for code2.
    The code I posted should do exactly with that, with the advantage that the section of code you're currently in will continue to run UNTIL you release the button. What you're proposing will HANG the current program section until you release the button. But here you go:
    code1:
    if button=0 then     'check if button is pressed
      PAUSE 5                       'allow some contact bounce
      WHILE button=0 : WEND  'wait for it to be released
      goto code2
    'somecode here
    goto code1
    code2:
    if button=0 then
      WHILE button = 0 : WEND
      goto code1
    'somecode here
    goto code2
    and obviously, button is a reserved word.
    Thanks!
    No problem for code to "Hang", since this is for going from main menu to sub-menu and back.
    my experience with button press usage is to have to wait for button release, can either stay in present routine and wait before switching OR moving to other routine and wait for release before looking for new press and going back.
    Here is the practical code I'm using, but it sometimes behaves strangely.
    Say, button was pressed, action was made once, user still holds button, so no advance in code. But when user releases the button, sometimes it acts as button was pressed once again. Any ideas how to fix it?
    MENULOOP: 'MAIN CONFIG SCREEN
    IF UPBT=0 THEN
    MENUITEM=MENUITEM+1
    IF MENUITEM>4 THEN MENUITEM=1
    GOSUB CENTRAL
    pause 200 'debounce
    WHILE UPBT=0:WEND
    IF DNBT=0 THEN
    MENUITEM=MENUITEM-1
    IF MENUITEM<1 THEN MENUITEM=4
    GOSUB CENTRAL
    pause 200 'debounce
    WHILE DNBT=0:WEND
    if menuitem=1 and rbut=0 then
    pause 5
    while rbut=0: wend
    goto clockconfig
    GOTO MENULOOP
    There does not seem to be any debounce on button release. Try
      IF UPBT=0 THEN
        MENUITEM = MENUITEM+1
        IF MENUITEM > 4 THEN MENUITEM = 1
        GOSUB CENTRAL
        ' PAUSE 20          ' May be needed if subroutine CENTRAL executes very fast.
        WHILE UPBT = 0 : WEND
        PAUSE 20 'debounce
    read switch a few times to be sure and debounce......
    IF UPBT=0 THEN
    PAUSE 20 ' or 40 or 50
    IF UPBT=0 THEN 'go ahead........
    do same for release check .... if upbt=1 then.....
    For couple of buttons this code works fine, but when I increase number of button handling operations, some weird things occur - the further from beginning is the button handling routine, more rarely it responds to user.
    The code below has 8 "blocks" of button handling.
    first 3 work fine, 4th one works only maybe on 10 or 15th press. 5th and further - do not work at all.
    And this is not issue of particular code - if I move say "5th block" to 1st place of this code, then it works fine.
    PIC18F45K80 @64mhz.
    IF UPBT=0 THEN
    MENUITEM=MENUITEM+1
    IF MENUITEM>6 THEN MENUITEM=1
    pause 200
    WHILE UPBT=0:WEND
    IF DNBT=0 THEN
    MENUITEM=MENUITEM-1
    IF MENUITEM<1 THEN MENUITEM=6
    pause 200
    WHILE DNBT=0:WEND
    IF LBUT=0 AND MENUITEM=2 THEN
    RICXVI=RICXVI+1
    IF RICXVI>31 THEN RICXVI=1
    pause 200
    GOSUB SETTIME
    WHILE LBUT=0:WEND
    IF RBUT=0 AND MENUITEM=2 THEN
    RICXVI=RICXVI-1
    IF RICXVI<1 THEN RICXVI=31
    pause 200
    GOSUB SETTIME
    WHILE RBUT=0:WEND
    IF LBUT=0 AND MENUITEM=1 THEN
    TVE=TVE+1
    IF TVE>13 THEN TVE=1
    pause 200
    GOSUB SETTIME
    WHILE LBUT=0:WEND
    IF RBUT=0 AND MENUITEM=1 THEN
    TVE=TVE-1
    IF TVE<1 THEN TVE=13
    pause 200
    GOSUB SETTIME
    WHILE RBUT=0:WEND
    IF LBUT=0 AND MENUITEM=3 THEN
    DGE=DGE+1
    IF DGE>7 THEN DGE=1
    pause 200
    GOSUB SETTIME
    WHILE LBUT=0:WEND
    IF RBUT=0 AND MENUITEM=3 THEN
    DGE=DGE-1
    IF DGE<1 THEN DGE=7
    pause 200
    GOSUB SETTIME
    WHILE RBUT=0:WEND
    I tried to reduce PAUSE 200 to 20 or even 2 - no change.
    Aug 2011
    what about something like this instead?
    IF UPBT=0 THEN
        MENUITEM=MENUITEM+1
        PAUSE 20
        WHILE UPBT=0:WEND
        PAUSE 20
    IF DNBT=0 THEN
        MENUITEM=MENUITEM-1
        PAUSE 20
        WHILE DNBT=0:WEND
        PAUSE 20
    IF LBUT=0 THEN
        IF MENUITEM=1 THEN
            TVE=TVE+1
            GOSUB SETTIME
        IF MENUITEM=2 THEN
            RICXVI=RICXVI+1
            GOSUB SETTIME
        IF MENUITEM=3 THEN
            DGE=DGE+1
            IF DGE>7 THEN DGE=1
            GOSUB SETTIME
        PAUSE 20
        WHILE LBUT=0:WEND
        PAUSE 20
    IF RBUT=0 THEN
        IF MENUITEM=1 THEN
            TVE=TVE-1
            GOSUB SETTIME
        IF MENUITEM=2 THEN
            RICXVI=RICXVI-1
            GOSUB SETTIME
        IF MENUITEM=3 THEN
            DGE=DGE-1
            IF DGE<1 THEN DGE=7
            GOSUB SETTIME
        PAUSE 20
        WHILE RBUT=0:WEND
        PAUSE 20
    it could be simplified even more, but...
    OK
    You could create a bit Flag. When the Button is pressed, the Flag is toggled. When you get to a reasonable point in Code1 Routine, check your Flag. If it has toggled (is now a 1 for example), use GOTO to jump to Code2. Put "IF Flag = 0 THEN : GOTO Code1" in convenient spots throughout in Code2, etc.
    debounce button check... and instead of while-wend .... use for/next pause here is 2 second check so if holding button > 2 seconds, can advance MENUitem then check again for release
    HERE:
    IF UPBT=0 THEN
    pause 50
    IF UPBT=0 THEN ..............................#debounce check
    MENUITEM=MENUITEM+1
    PAUSE 20
    for a=1 to 20
    pause 50................................................ ............# if 2 second press, advance item and wait again
    IF UPBT=1 THEN ---leave to somewhere .................# XXXXX WHILE UPBT=0:WEND
    next a
    goto HERE
    First I would read all button input at once. Debounce and then decide what to do.
    This is like a state machine coding and you will not loose any keypress, especially if it is interrupt driven. Or if you do not want interrupts, then a tight loop can do the job just fine.
    Spaghetti coding unfortunately leads to such results.
    Thanks everyone. I've modified that code in the way that it now works - there is additional check for MENUITEM value inside a button press loop, but the question is still active - why the code above slows down in that way? That's simply not logical.
    if there is room, you could put some 'temporary' code to serout or debug at a few locations and see where it isn't doing what is expected ! looks like there are quite a number of 'states' your program could be looping through.
  1. Final Button Code
    By WarPony in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2008, 14:14
  2. Help with code, button
    By xobx in forum mel PIC BASIC Pro
    Last Post: - 15th July 2007, 17:52
  3. Entering the number from keypad...
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 27th April 2007, 09:02
  4. Code entering endless loop
    By Blackhawk in forum mel PIC BASIC
    Last Post: - 26th November 2006, 09:12
  5. Code check -- button not working
    Last Post: - 2nd March 2006, 22:43
Members who have read this thread : 10
