I2CWrite Problem
Results 1 to 7 of 7
    May 2012
    Default I2CWrite Problem
    Hi everyone,
    I'm trying to send a simple 16 bits of data with the !2CWrite, but in Proteus I2C Debugger, i see the message separated.
    The odd thing is when the Device ID is $78, it works, with other value, it simple break the message...
    Can anyone understand what's going on?
    __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L
    __CONFIG _CONFIG1H, _FOSC_INTOSCIO_EC_1H
    __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOR_OFF_2L & _BORV_2_2L & _VREGEN_OFF_2L
    __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
    __CONFIG _CONFIG3H, _MCLRE_OFF_3H & _PBADEN_OFF_3H
    __CONFIG _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    DEFINE OSC 8 ' Velocidade padrão do 18F2550 qd em Internal Oscilator
    ' Default HSEROUT/IN do PIC #
    '------------------------------ Time Variables ------------------------------
    I2C_Address VAR Byte ' I2C - Comandos
    Address_To Var Byte ' I2C - Comandos
    Command var Byte ' I2C - Comandos
    Command_2 var Byte ' I2C - Comandos
    SDA VAR PortB.6
    SCL VAR PortB.7
    '----------------------------- Initial Settings --------------------------------
    UCON.3 = 0 ' USB Disable, RC4 e RC5 Digital Input Only
    UCFG.3 = 1 ' USB On-chip transceiver disabled
    ADCON1 = %00001110 ' (5) Vss Referência, (4) Vdd Referência, (3-0) AN0 = Analog, restantes ANx Digitais
    ADCON0 = %00000000 ' (5-2) An0 Selected, (0) A/D Module Off
    ADCON2 = %10000000 ' (7) Right Justified, (5-3) A/D Acquisition Time - 0 Tad, (2-0) A/D Clock - FOSC/2
    CMCON = 7 ' (2-0) 111-> Comparator Off
    OSCCON = %01110000 ' (7) Enter Slepp Mode on Sleep Instruction, (6-4) 8 MHz, (1-0) 1x--> Internal Oscilator 00--> Primary Oscilator ???
    ' OSCTUNE = %00011111 ' Serve para fazer uma pequena afinação da velocidade do Clock do Processador
    IntCon = %10010000 ' (7) Global Int Enabled, (4) Int0 - Enabled
    IntCon2 = %00000000 ' (7) Pull_Ups Enabled, (6) Int0 - On Falling, (5) Int1 - On Falling, (4) Int2 - On Falling
    IntCon3 = %00011000 ' Int1 - Priority Bit Off, (3) Int1 Enabled, (4) Int2 Enabled
    TRISA = %00000001
    TRISB = %00001111
    TRISC = %10110000 ' O C.2 é definido como In, só qd é ligada a rega (PWM On), é q passa a Out.
    '# Setup's #
    Pause 500 ' Delay p PowerUp de todos os Devices
    I2C_Address = $76
    Address_To = $02
    Command = $54
    Command_2 = $70
    Menu:
    I2C_Address = I2C_Address +1
    I2cWrite SDA,SCL,I2C_Address,Address_To,[Command,Command_2]
    Pause 500
    goto Menu
    Nuno
    Default Re: I2CWrite Problem
    makes no sense at all, in pbp i2c address are 7 bits + r/w bit at bit0
    so i2c write to $76 and to $77 are writes to the exact same address
    I2C_Address = I2C_Address +2
    will get a "NEW" address
    May 2012
    Hi Richard and thanks for the reply.
    The I2C_Address = I2C_Address +1 is only to show that 16 bits of data work when I2C_Address is equal to $78, in other cases, it don't work.
    Nuno
    still makes zero sense .
    if no slave device responds with an ack then the pbp code will terminate the transaction
    sending data to random or incorrect address' will achieve and prove nothing at all
    what are you really doing and what is the slave device , how is connected
    Aug 2011
    richard's correct in that if I2CWRITE doesn't get an ACK in response to writing a byte it immediately sends a STOP and returns with the CARRY flag set.
    Unfortunately, it never checks the return value so it continues on with the rest of the bytes in the I2CWRITE statement (here you have four of them).
    Since it just sent a STOP, it sends a START again, the next byte in the statement (which is now treated as a slave address), gets another NACK, sends STOP, etc, etc until all the bytes are sent.
    It should really terminate the entire I2CWRITE statement when it gets a NACK to the the first byte (the slave address), but it doesn't... it just erroneously continues on writing what amounts to garbage to whatever "address" it runs across.
    Not what i find . it may vary by pic18/16 and/or pbp version
    i my test the transaction terminates at the first nak and is followed by a "funny start" dud transaction , the data in the sq brackets is never sent
    Name:  Screenshot 2023-03-19 152852.png
    pic18f45k80
    'OSCTUNE.6 = 1 ; Enable 4x PLL
    OSCCON = 110000
    TRISD=000110 'set PORTD
    define OSC 16
    DEFINE I2C_SLOW 1
    ADR VAR BYTE
    ADR2 VAR BYTE
    CMD  VAR BYTE
    ADR=$48
    ADR2=$70
    SDA VAR PORTD.3
    SCL VAR PORTD.2
    CMD= $48
    FEDO:
    I2CWRITE SDA,SCL,ADR,[5]
    I2CWRITE SDA,SCL,ADR2,CMD,[3,4]
    PAUSE 250
    I2CWRITE SDA,SCL,ADR,[0]
    I2CWRITE SDA,SCL,ADR2,$48,[2,7]
    PAUSE 250
    GOTO FEDO
    edit
    might be a proteus artifact also, i have not scoped it
    Aug 2011
    That produces a slightly different result, but it's still wrong... there are extra transactions after getting a NACK to the first byte (slave address).
    "S 02 N P" shouldn't be there, and I have a hunch that if you change "ADR2=$70" to something else you'll find that is wrong too.
    I didn't bother trying to figure out exactly what it's sending, but it's not really what's in the remaining I2CWRITE statement.
    I looked at the asm code in both cases and there's nothing I see to look at the ack/nack result of sending a byte, except to send a STOP and reset the internal state so the next byte starts a new transaction. There's nothing to "skip over sending the remaining bytes" in the I2CWRITE.
  1. problem with I2CWRITE command
    By hatzukitzuki in forum mel PIC BASIC Pro
    Last Post: - 14th October 2010, 22:35
  2. I2CWRITE problem
    By Art in forum mel PIC BASIC Pro
    Last Post: - 29th January 2010, 03:01
  3. Problem with I2Cread and I2CWRITE function
    By Tony85 in forum mel PIC BASIC Pro
    Last Post: - 6th June 2006, 20:03
  4. Another I2CWRITE problem
    By ErnieM in forum mel PIC BASIC Pro
    Last Post: - 20th May 2006, 21:57
  5. I2CRead / I2CWrite Problem?
    Last Post: - 31st October 2005, 18:26
