RF sensor network
Results 1 to 11 of 11
    Sep 2003
    Vermont
    Question RF sensor network
    Greetings,
    I would like to create a mini wireless network that will transmit data between a number of sensors placed around the perimeter of an area. The sytem needs to make sure the data packets get to their destination, which may be out of range from any one sensor. The intermediete transceivers need to therefore accept a data packet for another sensor, and retransmit it if the destination sensor does not respond. I have heard if star, ring, and mesh patterns for data transfer, but if all sensors are weighted the same in importance, how does one make sure the info gets to it's destination without bogging down the network while every other sensor retransmits the data?
    Ron
    You need a protocol to achieve this... Do a web search for "Token Passing" as one solution...
    http://www.cisco.com/univercd/cc/td/...ng.htm#xtocid3
    G8RPI's Avatar
    G8RPI Guest
    If you want an off the shelf solution, The new ZigBee standard should do what you want.
    Robert G8RPI.
    Sep 2003
    Vermont
    Thanks for the suggestions. I will do a little more research, and also do my best not to reinvent the wheel.
    Ron
    gluphus's Avatar
    gluphus Guest
    Default zigbee
    I am starting my first zigbee project this month.
    I would like to have more cooks in the kitchen (so to speak) as to make this go well. If anyone is interested, PM or email me.
    My current setup is PICBasic Pro, PicDemZ, Chipcon CC2420.
    We plan to port to CC2430 in the summer.
    Sep 2006
    Mexico
    Quote Originally Posted by gluphus
    Hello gluphus, do you have some code examples in picbasic? i have picdemz and cc2420 too.
    Thanks in advance
    Soon I will test the Xbee's from MaxStream. They seem to be very easy to use with long range (up to 1.5Km).
    I 'll post the results and sample codes if anyone is interested. They are based on Zigbee protocol.
    Sep 2006
    Mexico
    Thanks Ioannis. I will try to buy the started kit.
    gluphus's Avatar
    gluphus Guest
    Default zigbee...yup
    Yes, I have code examples for the msstate (Dr. Reese) Zigbee* stack.
    I am currently working on hardening the zigbee phy layer, in effect making one only have to worry about a mysql db and picbasic on the RFDs.
    Raflex, you can email me at dthusma at hotmail and/or instant messenger.
    Payatronico's Avatar
    Payatronico Guest
    Talking ayudame gebus...
    you maybe need another kind of sensors managers like Neuron chips, then can handle the comunication and can tell you if the package was delivery or not.
    http://www.toshiba-components.com/pr...hip/index.html
    Sep 2006
    Mexico
    Interesting... Thanks
  1. Generic RF Receiver
    By dhouston in forum Code Examples
    Last Post: - 8th September 2009, 14:35
  2. Interfacing 16F88 to RF module
    By scomi85 in forum General
    Last Post: - 19th February 2009, 12:52
  3. RF designs
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 14th June 2006, 07:50
  4. Generating RF from a PIC
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 26th January 2006, 20:26
  5. Interfacting RF Module
    By rastan in forum General
    Last Post: - 10th November 2004, 22:27
