DT-ints and elapsed timer compilation errors.
Results 1 to 12 of 12
    Feb 2004
    Michigan, USA
    Default DT-ints and elapsed timer compilation errors.
    Hi Guys,
    I'm having some compiler issues when trying to create a program around DT's interrupts and elapsed timer. In the below code, if I comment out
    @ INT_ENABLE TMR1_INT ; Enable Timer 1 Interrupts
    then the program will compile.
    INCLUDE "DT_INTS-18.bas"
    INCLUDE "ReEnterPBP-18.bas"
    INCLUDE "Elapsed_INT-18.bas" ; Elapsed Timer Routines
    INT_Handler TMR1_INT, _ClockCount, PBP, yes
    'GOSUB ResetTime ' Reset Time to 0d-00:00:00.00
    'GOSUB StartTimer ' Start the Elapsed Timer
    This is the error dump MPLAB produces if I do not comment out that line.
    ERROR: Unable to execute mpasmwin.Warning[205] C:\USERS\LAPTOP1\DOCUMENTS\MCS\94700-1 DUAL UV.ASM 2062 : Found directive in column 1. (endm)
    Warning[206] C:\USERS\LAPTOP1\DOCUMENTS\MCS\94700-1 DUAL UV.ASM 2063 : Found call to macro in column 1. (INT_CREATE)
    Warning[206] C:\USERS\LAPTOP1\DOCUMENTS\MCS\94700-1 DUAL UV.ASM 2061 : Found call to macro in column 1. (INT_Handler)
    Error[116] C:\USERS\LAPTOP1\DOCUMENTS\MCS\94700-1 DUAL UV.ASM 616 : Address label duplicated or different in second pass (Z0001C)
    Error[116] C:\USERS\LAPTOP1\DOCUMENTS\MCS\94700-1 DUAL UV.ASM 679 : Address label duplicated or different in second pass (Z0001D)
    Error[116] C:\USERS\LAPTOP1\DOCUMENTS\MCS\94700-1 DUAL UV.ASM 732 : Address label duplicated or different in second pass (Z0001E)
    Error[116] C:\USERS\LAPTOP1\DOCUMENTS\MCS\94700-1 DUAL UV.ASM 763 : Address label duplicated or different in second pass (Z0001F)
    Any idea what I may be missing?
    18F1320, int osc at 8MHZ, PBP 2.6A, MPLAB IDE 8.20a
    Default Re: DT-ints and elapsed timer compilation errors.
    some spaces this
    as the error msg says " Found directive in column 1. (endm)"
    should be
    Feb 2004
    Michigan, USA
    Oh wow, thanks! I didn't realize it was so tabulation sensitive. This removed a few errors but still a couple left to clear. I'm thinking of commenting out that area of the include as it pertains to functions this pic doesn't have.
    ERROR: Unable to execute mpasmwin.Error[116]   C:\USERS\LAPTOP1\DOCUMENTS\MCS\94700-1 DUAL UV.ASM 616 : Address label duplicated or different in second pass (Z0001C)
    won't help at all
    Name:  Screenshot 2021-09-17 135436.jpg
    the assembler gets a bit picky about old stuff like dt ints these days if coff generation is enabled.
    coff is now pretty much useless for pbp since it is no longer supported in mplabx for source level debugging
    OK
    Richard, I'm impressed! You are noting things I never knew! I don't use ancient PICs like the 18F1320, but never would have guessed your answer. Nice work, and thanks for sharing your wisdom.
    Feb 2004
    Michigan, USA
    I'm using old stuff I don't see an option to enable or disable generation of COFF files in this super old version of MCS+. 3.0.0.1 I think, MPLAB is 8.20a, mpasm is 5.30, and pbp is 2.60a.
    Name:  Screenshot 2021-09-17 143507.jpg
    if its not there then u need an upgrade
    OK
    Jmgelba, your join date is 2004, which means you aren't green (new). Like anything, Microchip has evolved with newer PIC offerings sporting more power, more Peripherals, and at cheaper prices. MCP abandoned MPLAB in favor of MPLABX. PBP3 has evolved. Even the dated dtInts has evolved, thanks to contributions from the community. The software versions you are using are extremely outdated. To upgrade to the current PBP3.1 software will cost you $50 US. However, upgrading to the last version of PBP3.0 is free. PBP3.x works with MPLABX v5.35 or older. Is there a reason you have not taken advantage of these free upgrades?? Many folks in the past have been pleasantly surprised by how many of their challenges were magically solved just by updating their software. Give it a try and let us know if it helps at all.
    Feb 2004
    Michigan, USA
    There has to be something else going on too. I'm using software that was used when these interrupts where first written. I did just upgrade to the free 4.0.0.0 version of MCS+ so I'll try that. No option to not generate a COFF though.
    Feb 2004
    Michigan, USA
    I haven't touched a pic in years. I really don't do much with firmware at all. I'm completely out of date, have no skills, and forgot all the stuff I learnt a decade ago. All I want to do is run a timer for 60, 90, or 120 seconds while monitoring a pin for a high to low transition that stops the timer and jumps to a different location in the program. Should be super simple but I'm dumb and crazy busy with other stuff.
    I'll take a look around for that 3.0 free upgrade.
    OK
    In addition to the forums, ME Labs offers this:
    https://melabs.com/resources/index.htm?source=footer
    Feb 2004
    Michigan, USA
    So I got a copy of PBP3, MCS4, MPLABX IDE 5.50, and yeah, same result. Plus a whole bunch of other issues such as programmer issues (fixed) makefile issues (not fixed) MCS not connecting to MPLAB correctly (not fixed.)
    I have upended a setup that's created several programs and programmed hundreds of chips, only to be worse off than before lol.
  1. Compilation errors
    By aratti in forum mel PIC BASIC Pro
    Last Post: - 8th September 2010, 15:12
  2. Compilation errors
    By mikebike in forum mel PIC BASIC Pro
    Last Post: - 6th September 2010, 09:29
  3. Elapsed_Demo.bas compilation errors
    By Dick Ivers in forum mel PIC BASIC Pro
    Last Post: - 1st March 2010, 23:44
  4. Compilation errors - strange
    By tetanus4 in forum mel PIC BASIC Pro
    Last Post: - 24th October 2009, 19:04
  5. Replies: 3
    Last Post: - 1st July 2008, 21:07
