max7219 4x 8x8 panels spi
+ Reply to Thread
Results 1 to 27 of 27
    Default max7219 4x 8x8 panels spi
    for pic16 with spi port . 5 digits 6x5 numeric font right justified with leading zero suppression
    Default Re: max7219 4x 8x8 panels spi
    A bit late but just noticed this valuable post! Thanks once again.
    Is this driver for such a display?
    looks the same
    Thanks!
    Really cheap toys to play with!
    Since I have on hand only 16F1827, I modified the code for the PortC pins but as expected does not work. Modifications in red.
    I really do not know what lata.5 does in your code. Maybe a led to sign start?
    '*  Name    : max7219 16f1825                                      *
    '*  Author  : richard                                              *
    '*  Notice  : Copyright (c) 2019                                   *
    '*  Date    : 25/2/2020                                            *
    '*  Version : 1.1                                                  *
    '*  Notes   : max7219   5 6x5 chrs on 4 8x8 panels                 *
    '*          : right justified leading zero suppression             *
    '*          : modified for pic16f1827                              *
                 __config        _CONFIG1,    _FOSC_INTOSC & _CP_OFF & _WDTE_OFF  &  _PWRTE_ON  &  _MCLRE_ON  & _CLKOUTEN_OFF
    define OSC 32
    goto overasm
    asm
    GetAddress macro Label, Wout
        CHK?RP Wout
        movlw low Label          ; get low byte
        movwf Wout
        movlw High Label         ; get high byte
        movwf Wout + 1
    endasm
    overasm:
    SSPCON1 = $20;
    SSPSTAT = $40;
    ANSELA = 0
    ANSELB = 0
    OSCCON = $70
    tmp      var byte
    dsp      var byte
    dspbuff  var byte[32]
    BUFF     var byte[16]
    cnt      var byte
    row      var byte
    drow     var byte
    srow     var byte
    col      var byte
    dcol     var byte
    aFont    var word
    fOffset  var word
    cga      var byte
    cgah     var byte
    ch       var byte
    chr      var byte
    inx      var byte
    mask     var word
    counter  var word
    bcnt     var byte
    ncnt     var byte
    number  var word
    clear
    'mxld     var portc.1
    'mxck     var portc.0
    'mxdi     var portc.2
    mxld     var portb.1
    mxck     var portb.4
    mxdi     var porta.6
    'trisc = %11111000
    'trisa = %11011110
    trisb = 0
    trisa = 0
    init:
        lata.5 = 1
        mxld = 1
        dsp = 11
        tmp = 5
        gosub xfer4
        dsp = 9
        tmp = 0
        gosub xfer4
        dsp = 12
        tmp = 1
        gosub xfer4
        dsp = 10
        tmp = 8
        gosub xfer4
        dsp = $b
        tmp = 7
        gosub xfer4
        dsp = $f
        tmp = 0
        gosub xfer4
    @ GetAddress _font,_aFont
    loopy:
        row = 1:col = 1
        gosub showrjbuf
        gosub  strchr
        gosub show
        counter  =  counter + 1
    GOTO loopy
    strchr:     ;null  terminated
        bcnt = 0
        while buff[bcnt]
            chr = buff[bcnt]
            gosub gcga
            bcnt = bcnt + 1
            col = col + 6
        wend
    show:
        for srow = 0 to 7
            GOSUB SHOWROW
        next
    showROW:
        	mxld = 0
       	    for dcol = 0 to 3
            	 SSPBUF = srow + 1
                 while !pir1.3:wend
                 pir1.3 = 0
                 SSPBUF = dspbuff[(srow<<2) + dcol]  rev 8
                 while !pir1.3:wend
                 pir1.3 = 0
            next
        	mxld = 1
    xfer4:
         for dcol = 0 to 3
             mxld = 0
             pir1.3 = 0
             SSPBUF = dsp
             while !pir1.3:wend
             pir1.3=0
             SSPBUF =tmp
             while !pir1.3:wend
             pir1.3 = 0
         next
         mxld = 1
    gcga:      ;ROW= 0-1 COL=0-28 CHR = SPACE,"0" TO ";"
        if chr = " " then chr = ";"   ;TRANSLATE SPACE TO ";"
        fOffset = (chr - "0")*3 + aFont  ; point to cga data
        drow = row  ;0 or 1
        mask = ~(63<<(col//8))
        inx = col/8
        for tmp = 0 to 2
            gosub unpack
            inx = (drow<<2) + col/8
            dspbuff[inx] = dspbuff[inx] & mask.lowbyte
            dspbuff[inx] = dspbuff[inx] | (cga<<(col//8))
            if  mask.highbyte then
                INX = INX + 1
                dspbuff[inx] = dspbuff[inx] & mask.highbyte
                dspbuff[inx] = dspbuff[inx] | (cga>>(8-col//8) )
                inx = inx + 3
                inx = inx + 4
    '        SROW=DROW
    '        GOSUB SHOWROW
    '        PAUSE 50
            drow = drow + 1
            dspbuff[inx] = dspbuff[inx] | (cgah<<(col//8))
                INX = INX+1
                dspbuff[inx] = dspbuff[inx] | (cgah>>(8 - col//8) )
    '        SROW=DROW
    '        GOSUB SHOWROW
    '        PAUSE 50
            drow = drow + 1
            fOffset = fOffset + 1
         next
    showrjbuf:    ;load  buff righ justified
        number = counter
        for ncnt = 0 to 4
            BUFF[ncnt] = $30
        next
        while number >10000
            buff[0] = buff[0] + 1
            number = number - 10000
        wend
        while number >1000
            buff[1] = buff[1] + 1
        wend
        while number>100
            buff[2] = buff[2] + 1
        wend
        while number >10
            buff[3] = buff[3] + 1
            number = number -10
        wend
        buff[4] = buff[4] + number
    lzr:       ;repress leading zeros
        for ncnt = 0 to 3
          if BUFF[ncnt] == $30 then
               BUFF[ncnt] = $20
        next
    unpack:
      asm
        CHK?RP  _fOffset
        MOVF _fOffset+1,W
        CHK?RP   EEADRH
        MOVWF EEADRH ;MS Byte of Program Address to read
        CHK?RP  _fOffset
        MOVF _fOffset,W
        CHK?RP   EEADR
        MOVWF EEADR ;LS Byte of Program Address to read
        CHK?RP   EECON1
        BSF EECON1, EEPGD ;Point to PROGRAM memory
        BSF EECON1, RD ;EE Read
        NOP
        NOP
        CHK?RP   EEDAT              ;UNPACK DATA
        RLF    EEDAT, W
        RLF    EEDATH, W
        CHK?RP  _cgah
        MOVWF   _cgah
        CHK?RP   EEDAT
        BCF    EEDAT,7
        MOVF   EEDAT,W
        CHK?RP  _cga
        MOVWF   _cga
        RST?RP
     endasm
    '//Font Generated by MikroElektronika GLCD Font Creator 1.2.0.0
    '//MikroElektrnika 2011
    '//http://www.mikroe.com
    '//GLCD FontName : Untitled5x6
    '//GLCD FontSize : 5 x 6
    'const unsigned short Untitled5x6[] = {
    font :      ;in packed format for pic16 dw lines
    ;@ db  0x0E,0x11,0x11,0x11,0x11,0x0E;                                                   // Code for char num 48  0
    @ dw    0x88e,0x891,0x711    ;
    ;@ db   0x04,0x06,0x04,0x04,0x04,0x0E;                                                  // Code for char num 49  1
    @ dw    0x304,0x204,0x704
    ;@ db   0x0E,0x11,0x08,0x04,0x02,0x1F;                                                  // Code for char num 50
    @ dw   0x88e,0x208,0xf82
    ;@ db   0x0E,0x10,0x1C,0x10,0x10,0x0E;                                                  // Code for char num 51
    @ dw    0x80e,0xe10,0x710
    ;@ db   0x01,0x01,0x05,0x1F,0x04,0x04;                                                  // Code for char num 52
    @ dw    0x81,0xf85,0x204
    ;@ db   0x0F,0x01,0x01,0x0E,0x10,0x0F;                                                  // Code for char num 53
    @ dw    0x8f,0x701,0x790
    ;@ db   0x0E,0x11,0x01,0x0F,0x11,0x0E;                                                  // Code for char num 54  6
    @ dw   0x88e,0x781,0x711
    ;@ db   0x1F,0x10,0x08,0x04,0x02,0x02;                                                  // Code for char num 55
    @ dw    0x81f,0x208,0x102
    ;@ db   0x0E,0x11,0x11,0x0E,0x11,0x0E;                                                  // Code for char num 56  8
    @ dw    0x88e,0x88e ,0x711
    ;@ db   0x0E,0x11,0x11,0x1E,0x10,0x0E;                                                  // Code for char num 57
    @ dw   0x88e,0xf11,0x711
    ;@ db   0x00,0x04,0x00,0x00,0x04,0x00;                                                  // Code for char num 58  ;
    @ dw    0x200,0,0x200
    ;@ db   0x00,0x00,0x00,0x00,0x00,0x00;                                                   // space
    @ dw     0,0, 0
    default sdo for that chip is rb2, for mxdi var porta.6 ​you need to set apfcon0.6
    nether do i , most probably a trigger for log analyzer
    Well, I was just about to post that logic analyzer keeps data at zero. I was watching that and could not think what was wrong...!
    Doh!
    Thanks Richard. Works now.
    What is the logic in the packing of the characters into words?
    uses half the amount of flash memory when using 7bit numbers [pic16 flash is 14 bits wide] so you need to pack it.
    it takes very little time for the pic to unpack so there is no real penalty for a huge saving
    Yes, OK. But from 6 bytes you went to 3 words. Cannot understand the calculation you did.
    ;@ db 0x0E,0x10,0x1C,0x10,0x10,0x0E; // Code for char num 51 "3"
    0E=00001110, 10=00010000 and all these makes 80E?
    0xE=0b00001110, 0x10=0b00010000
    7 high bits | 7 low bits
    0x10<<7 | 0x0e &0x7f = 0x80e
    0b000100000000000 | 0b0001110 = 0b00010000001110 <==> 0x80e [14 bits]
    After making the paper and pencil homework, I was amazed by your thinking! So simple, so clever, so efficient!
    Mikroe outputs the characters in columns but your data is in rows. Did you rotate them by hand or can GLCD do that?
    Well, results don't match.
    I do this:
    1. on GLCD Font Creator 5x6 is selected since that is what says in the program: '//GLCD FontSize : 5 x 6
    2. Then the character 48 is designed
    3.Then Export for GLCD
    The data do not match as can be seen. I am sure that I did something wrong, but what?
    thats glcd mode you need tft mode
    Yes, that did it.
    Question Re: max7219 4x 8x8 panels spi
    The 5x6 grid is not very roomy for good fonts. After a bit of experimenting I ended up with the rectangular fonts that follow. I thing they are readable from longer distance.
    @ dw 0x89F,	0x891,	0xF91      ; 0
    @ dw 0x206,	0x204,	0xF84      ; 1
    @ dw 0x81F,	0x9F,	0xF81      ; 2
    @ dw 0x81F,	0x81E,	0xF90      ; 3
    @ dw 0x489,	0xF89,	0x408      ; 4
    @ dw 0x9F,	0x81F,	0xF90      ; 5
    @ dw 0x9F,	0x89F,	0xF91      ; 6
    @ dw 0x81F,	0x410,	0x408      ; 7
    @ dw 0x89F,	0x89F,	0xF91      ; 8
    @ dw 0x89F,	0x81F,	0xF90      ; 9
    @ dw 0x200,     0x0,	0x200      ; :
    @ dw 0,0,0                         ; space
    A small demo video is uloaded here:
    I'm slowly working on an 18F version.
    Currently running on the 18F57Q43 using the SPI peripheral (planning to get to DMA eventually) but can work with MSSP or even SHIFTOUT.
    Supports an arbitrary width display (within limits of available RAM) but only one row (starting to second guess myself on that one). Pixel by pixel scrolling left/right/up/down is almost working. We'll see where this ends up in the comming weeks...
    you could always just add a driver to suit this and not have to reinvent the wheel font&graphics wise etc
    http://www.picbasic.co.uk/forum/showthread.php?t=24218
    i'm sure a max7219 driver would be easy enough to contrive and it would make multi row /column display simpler
    I'm slowly working on an 18F version....
    Very interesting work! Looking forward!
    now with scrolling
    '****************************************************************'*  Name    : max7219 16f1825                                      *
    '*  Version : 1.1                                                  *
    '*          : pic16f1825                                           *
                 __config    _CONFIG2, _PLLEN_ON & _LVP_OFF
    define OSC 32
    goto overasm
    asm
        CHK?RP Wout
        movwf Wout
        movwf Wout + 1
    endasm
    overasm:
    SSPCON1 = $20;
    SSPSTAT = $40;
    ANSELA = 0
    ANSELC = 0
    OSCCON = $70
    tmp      var byte
    dsp      var byte
    BUFF     var byte[16]
    cnt      var byte
    row      var byte
    drow     var byte
    srow     var byte
    col      var byte
    dcol     var byte
    aFont    var word
    fOffset  var word
    cga      var byte
    cgah     var byte
    ch       var byte
    chr      var byte
    inx      var byte
    mask     var word
    counter  var word
    bcnt     var byte
    ncnt     var byte
    number  var word
    clear
    mxld     var portc.1
    mxck     var portc.0
    mxdi     var portc.2
    trisc = %11111000
    trisa = %11011110
    lata.0=1
    init:
        lata.5 = 1
        mxld = 1
        dsp = 11
        tmp = 5
        gosub xfer4
        dsp = 9
        tmp = 0
        gosub xfer4
        dsp = 12
        tmp = 1
        gosub xfer4
        dsp = 10
        tmp = 8
        gosub xfer4
        dsp = $b
        tmp = 7
        gosub xfer4
        dsp = $f
        tmp = 0
        gosub xfer4
    'dspbuff[0]=$73
    'dspbuff[4]=$37
    counter=1235
        col = 1
        gosub showrjbuf
        gosub  strchr
    gosub show
    loopy:
    gosub rotate
    '    col = 1
    '    gosub showrjbuf
    '    gosub  strchr
    '    chr=":" + counter.0
    '    col = 27
    '    gosub  gcga
        gosub show
    '    counter  =  counter + 1
    GOTO loopy
        bcnt = 0
        while buff[bcnt]
            chr = buff[bcnt]
            gosub gcga
            bcnt = bcnt + 1
            col = col + 5
        wend
    show:
        for srow = 0 to 7
            GOSUB SHOWROW
        next
    showROW:
        	mxld = 0
       	    for dcol = 0 to 3
            	 SSPBUF = srow + 1
                 while !pir1.3:wend
                 pir1.3 = 0
                 while !pir1.3:wend
                 pir1.3 = 0
            next
        	mxld = 1
    xfer4:
         for dcol = 0 to 3
             mxld = 0
             pir1.3 = 0
             SSPBUF = dsp
             while !pir1.3:wend
             pir1.3=0
             SSPBUF =tmp
             while !pir1.3:wend
             pir1.3 = 0
         next
         mxld = 1
        fOffset = (chr - "0")*4 + aFont  ; point to cga data
        drow = 0
        mask = ~(31<<(col//8))
        inx = col/8
        for tmp = 0 to 3
            gosub unpack
                INX = INX + 1
                inx = inx + 3
                inx = inx + 4
            drow = drow + 1
                INX = INX+1
            drow = drow + 1
         next
        number = counter
        for ncnt = 0 to 4
            BUFF[ncnt] = $30
        next
        while number >10000
        wend
        while number >1000
        wend
        while number>100
        wend
        while number >10
        wend
        for ncnt = 0 to 3
               BUFF[ncnt] = $20
        next
    unpack:
        readcode foffset ,cgah
        cga=(cgah >> 4)
        cgah=(cgah&15 )
    rotate:
    asm
        bcf STATUS,C
        rrf   _dspbuff+3,f
        rrf   _dspbuff+2,f
        rrf   _dspbuff+1,f
        rrf   _dspbuff ,f
        btfsc  STATUS, C
        bsf   _dspbuff+3,7
        bcf STATUS,C
        rrf   _dspbuff+7,f
        rrf   _dspbuff+6,f
        rrf   _dspbuff+5,f
        rrf   _dspbuff+4 ,f
        btfsc  STATUS, C
        bsf   _dspbuff+7,7
        bcf STATUS,C
        rrf   _dspbuff+11,f
        rrf   _dspbuff+10,f
        rrf   _dspbuff+9,f
        rrf   _dspbuff+8 ,f
        btfsc  STATUS, C
        bsf   _dspbuff+11,7
        bcf STATUS,C
        rrf   _dspbuff+15,f
        rrf   _dspbuff+14,f
        rrf   _dspbuff+13,f
        rrf   _dspbuff+12 ,f
        btfsc  STATUS, C
        bsf   _dspbuff+15,7
        bcf STATUS,C
        rrf   _dspbuff+19,f
        rrf   _dspbuff+18,f
        rrf   _dspbuff+17,f
        rrf   _dspbuff+16 ,f
        btfsc  STATUS, C
        bsf   _dspbuff+19,7
        bcf STATUS,C
        rrf   _dspbuff+23,f
        rrf   _dspbuff+22,f
        rrf   _dspbuff+21,f
        rrf   _dspbuff+20 ,f
        btfsc  STATUS, C
        bsf   _dspbuff+23,7
        bcf STATUS,C
        rrf   _dspbuff+27,f
        rrf   _dspbuff+26,f
        rrf   _dspbuff+25,f
        rrf   _dspbuff+24 ,f
        btfsc  STATUS, C
        bsf   _dspbuff+27,7
        bcf STATUS,C
        rrf   _dspbuff+31,f
        rrf   _dspbuff+30,f
        rrf   _dspbuff+29,f
        rrf   _dspbuff+28 ,f
        btfsc  STATUS, C
        bsf   _dspbuff+31,7
    endasm
    font:
    @ dw 0x69,0x99,0x99,0x96
    @ dw 0x46,0x54,0x44,0x4F
    @ dw 0x69,0x98,0x61,0x1F
    @ dw 0x69,0x86,0x89,0x96
    @ dw 0x99,0x9E,0x88,0x88
    @ dw 0xF1,0x17,0x89,0x96
    @ dw 0x69,0x17,0x99,0x96
    @ dw 0xF8,0x84,0x42,0x22
    @ dw 0x69,0x96,0x99,0x96
    @ dw 0x69,0x9E,0x89,0x96
    @ dw 0x00,0x10,0x01,0x00
    @ dw 0x00,0x00,0x00,0x00
    Thanks for the new example.
    In real life does it look like the video? I mean it seems that the scrolling is not very smooth but stepping a bit. OK, since the resolution is not that great this is expected I guess.
    ITS as smooth as silk , can't say the same for the camera
    made a better parametric version too
    rotate:
    asm
        banksel _bcnt    ;ROW
        movlw   8
        movwf   _bcnt
        banksel _inx
        movlw   31         ;BUFFER SIZE
        movwf   _inx
    NROW
        banksel _inx
        movlw   high (_dspbuff)
        movwf   FSR0H
        movlw   low  (_dspbuff)
        movwf   FSR0L
        movf    _inx,W
        ADDWF   FSR0L,F
        bcf     STATUS, C
        rrf     INDF0 ,f     ;PER COLUMN
        addfsr  0,-1
        addfsr  0,-1
        addfsr  0,-1
        btfss   STATUS, C
        GOTO    NBNC
        addfsr  0,3
        bsf     INDF0,7
    NBNC
        movlw   4         ;ROW LENGTH
        SUBWF   _inx,F
        banksel _bcnt
        DECFSZ  _bcnt ,F
        GOTO    NROW
    endasm
    even nicer
    rotate:
    asm
        banksel _bcnt    ;ROW
        movlw   8
        movwf   _bcnt
        movwf   FSR0H
        movwf   FSR0L
        ADDWF   FSR0L,F
        banksel _bcnt
    NROW
        bcf     STATUS, C
        addfsr  0,-1
        addfsr  0,-1
        addfsr  0,-1
        btfss   STATUS, C
        GOTO    NBNC
        addfsr  0,3
        bsf     INDF0,7
        addfsr  0,-3
    NBNC
        addfsr  0,-1
        DECFSZ  _bcnt ,F
        GOTO    NROW
    endasm
    looks the same
    Is anyone else getting "video not available" for Richard's stuff?
    I can see Ioannis' video's properly.
    i pressed the wrong button on my youtube dashboard and deleted a bit of stuff , its not recoverable and the originals are lost too
  1. 8x8 keypad matrix...
    By mbox in forum General
    Last Post: - 9th October 2014, 18:43
  2. 8x8 Scrolling LED display (Simple example)
    By wellyboot in forum Code Examples
    Last Post: - 11th July 2013, 05:03
  3. DC/DC with MPPT for solar panels
    Last Post: - 14th May 2013, 02:26
  4. MY FIRST scrolling 8X8 LED
    Last Post: - 15th August 2008, 16:23
  5. SPI instead of SHIFTOUT - MAX7219
    By Momboz in forum mel PIC BASIC Pro
    Last Post: - 26th April 2008, 22:58
Members who have read this thread : 8
