A little HELP!!
Results 1 to 40 of 77
Thread: A little HELP!!
Threaded View
    Mar 2011
    Los Angeles, California
    Question A little HELP!!
    Okay so I am still struggling with this code. In television there are three forms of video standards for different parts of the world. There is NTSC, which is the American standard, PAL a European standard and SECAM another standard. Most of the world uses either the NTSC or PAL standard. The basic difference is weather the power is 50 cycles per second (PAL) or 60 cycles per second (NTSC) as this is used for the timing of the television electronics. Since this STV5730 seems to display an out of sync picture most of the time my guess is that the code has the PAL standard embedded somewhere in it. I can see a display for a short time with the characters in the PIC code then it goes back to a scrambled sync signal. I have never seem an "overlay" display where the characters are superimposed over the incoming picture. I am hoping someone with much, much more knowledge than I have can tell me what to change in the code? Thanks in advance.
    '*  Name    : English OSD                                       *
    '*  Author  : Ed Cannady                                        *
    '*  Notice  : Copyright (c) 2017 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 6/4/2017                                          *
    'OSDCSX.bas version 2.0
    'Incruser with STV5730A and PIC 18F2520 - 20 MHz
    'Source for PICBasic PRO
    'Risto Kõiva 2001, F1FCO & F6CSX, March 2003
    'Turns on F1UBZ insert (part RS232 / MAX232 useless) or demo board STV5730
    'Page mode, color bars
    'Cyclic change of background color
    '23cm or 70cm band display according to pin 18 status (RA1)
    '** HARDWARE DEFINITION **
    Define OSC 20
    	CMCON = 7 'put the 18F2520 in digital mode on PORT A
        ADCON1 = $0F
    	Clk VAR PORTC.4
    	Sda VAR PORTC.5
    	Csn VAR PORTC.3
    	Mute VAR PORTB.7 '0 if sync valid, 1 if no sync
        mode VAR PORTB.3 'pin # 9, 0 = Page mode, 1 = Mixed mode
    	On_off VAR PORTA.2 'Stop the incruser: pin # 1, 0 = off, 1 = on
    	Band VAR PORTA.1 'incrustation 23 cm if 0 or 70 cm if 1
    INPUT Mode
    INPUT Mute
    INPUT On_off
    INPUT Band
    OUTPUT Clk
    OUTPUT Sda
    OUTPUT Csn
    '** DEFINITION OF VARIABLES **
    	ICount VAR BYTE
    	Bit_Counter VAR BYTE
    	WData VAR WORD
    	C VAR WORD
    	B1 VAR BYTE
    	B2 VAR BIT
    	B3 VAR BIT
    	B4 VAR BIT
    	W1 VAR BYTE
    	W2 VAR BYTE
    '** START OF PROGRAM **
    	GOSUB Init 'initialization
    	GOSUB Mode_mixed 'Mixed mode by default
    	GOSUB Display_mixed
    	b1 = 1
    	b2 = 1
    	b3 = 1
    	c  = 0
    Looped:
    	B1 = On_off
    	IF b1 = 0 THEN Incrust_off 'monitors the On_off button
    	B4 = Band
    	IF b4 = 0 THEN
    		W1= $02
    		W2= $03
    		W1= $07
    		W2= $00
    	B3 = MODE 'reads MODE
    	IF b3 = b2 THEN Jump 'does not change anything
    	IF b3 = 1 THEN 'If MODE = 1: Mixed Mode, Picture Overlay
    		c = 0
    		GOSUB Mode_mixed
    		GOSUB Display_mixed
    		B2 = b3
    		GOSUB Mode_page 'Mode Page: Mire
    		FOR c = 0 TO 6
    		WData = $00CD: GOSUB Send '(tip at address 13)
    		WData = $1000 + ($201 * c): GOSUB Send 'background color change
    		GOSUB Display_page
    		PAUSE 2000
    		NEXT c
    		B3 = Mode 'reads mode
    		B2 = ~ b3 'b2 is not equal to b3, we do not jump and we start again
    	PAUSE 500
    	GOTO Looped
    Jump:
    	PAUSE 200
    	GOTO Looped
    '	disable debug
    'No overlay. We go into mixed mode and we delete the screen
    Incrust_off:
    		GOSUB Mode_mixed
    		PAUSE 100
    		b1 = 1
    		GOTO Looped
    'No Overlay
    Delete_Screen:
    	c = 0
        WData = 0: GOSUB Send 'tip top left of screen (0,0)
        c = 1
        FOR c = 1 TO 308 'on clears the screen with spaces (0B)
    	WData = $1700 + $0B: GOSUB Send '$1700: background disabled, white character not blinking
        NEXT c
    'display in overlay mode
    Display_mixed:
        WData = 0: GOSUB Send 'do not omit this line: position 0,0
        WData = $1780 + $6E: GOSUB Send 'flashing parable
        WData = $170B:        GOSUB Send 'space
        WData = $1700 + $11:  GOSUB Send 'F
        WData = $1700 + $06:  GOSUB Send '6
        WData = $1700 + $0E:  GOSUB Send 'C
        WData = $1700 + $1E:  GOSUB Send 'S
        WData = $1700 + $23:  GOSUB Send 'X
        WData = $1700 + $18:  GOSUB Send 'M
        WData = $1700 + $0C:  GOSUB Send 'A
        WData = $1700 + $1D:  GOSUB Send 'R
        WData = $1700 + $10:  GOSUB Send 'E
        WData = $1700 + $14:  GOSUB Send 'I
        WData = $1700 + $17:  GOSUB Send 'L
        WData = $1700 + $15:  GOSUB Send 'J
        WData = $1700 + $19:  GOSUB Send 'N
        WData = $1700 + $02:  GOSUB Send '2
        WData = $1700 + $03:  GOSUB Send '3
        WData = $1700 + $13:  GOSUB Send 'H
    	PAUSE 1000
    'display in page mode
    Display_page:
    'First line in Max Zoom
        WData = 0:           GOSUB Send 'do not omit this line: position 0,0 Line 0
        WData = $1F0B:       GOSUB Send 'space
        WData = $1F00 + $11: GOSUB Send 'F with blue background
        WData = $1F00 + $06: GOSUB Send '6
        WData = $1F00 + $0E: GOSUB Send 'C
        WData = $1F00 + $1E: GOSUB Send 'S
        WData = $1F00 + $23: GOSUB Send 'X
        WData = $100:         GOSUB Send 'line 1
        WData = $1700 + $1A:  GOSUB Send 'O with black background
        WData = $1700 + $39:  GOSUB Send 'p
        WData = $1700 + $26:  GOSUB Send ':
        WData = $1700 + $1C:  GOSUB Send 'Q
        WData = $1700 + $1F:  GOSUB Send 'T
        WData = $200:         GOSUB Send 'line 2
        WData = $1700 + $01:  GOSUB Send '1
        WData = $1700 + $04:  GOSUB Send '4
        WData = $1700 + $05:  GOSUB Send '5
        WData = $1700 + $27:  GOSUB Send '.
        WData = $1700 + $43:  GOSUB Send 'z
        WData = $1700 + $38:  GOSUB Send 'o
        WData = $1700 + $3E:  GOSUB Send 'u
        WData = $1700 + $00:  GOSUB Send '0
     'Color bars, 4 lines
     FOR iCount = $0 TO $3
        WData = $300 + $100 * iCount: GOSUB Send 'to the beginning of line 3
        WData = $1877:        GOSUB Send 'black
        WData = $1977:        GOSUB Send
        WData = $1A77:        GOSUB Send
        WData = $1B77:        GOSUB Send
        WData = $1C77:        GOSUB Send
        WData = $1D77:        GOSUB Send
        WData = $1E77:        GOSUB Send
        WData = $1F77:        GOSUB Send
        WData = $1F77:        GOSUB Send 'white
        NEXT iCount
    	WData = $700:         GOSUB Send
    	FOR iCount = $1 TO $8
        NEXT iCount
    	WData = $1700 + $5F:  GOSUB Send '*
    	WData = $1780 + W1:   GOSUB Send '2 or 7
       	WData = $1780 + W2:   GOSUB Send '3 or 0
       	WData = $1780 + $2C:  GOSUB Send 'c
       	WData = $1780 + $36:  GOSUB Send 'm
        PAUSE 1000
    WasteTime: 'timer 2 clock cycles
    	  nop
    	  nop
    StartCommunication: 'Start of transmission Fig 2 page 12 manual STV5730A
    	HIGH Clk: GOSUB WasteTime 'Clock to 1
    	LOW  Csn: GOSUB WasteTime 'Chip select to 0
    	LOW  Clk: GOSUB WasteTime 'Clock at 0
    StopCommunication: 'end of transmission
    	HIGH Csn: GOSUB WasteTime 'Chip select to 1
    SendOne: 'Send a bit 0
    	HIGH Sda: GOSUB WasteTime
    SendZero: 'sending a bit 1
    	LOW  Sda: GOSUB WasteTime
    OutByte: 'send a 16 bit word
    	FOR Bit_Counter = 1 TO 16
        IF wData.15 = 1 THEN 'MSB first
        GOSUB SendOne
        GOSUB SendZero
        WData = wData << 1
    	NEXT Bit_Counter
    Send:
    	GOSUB StartCommunication
    	GOSUB OutByte
    	GOSUB StopCommunication
    '------------------------------------------------- -------------------------------------------------- -------------------------------------------------- ---------'** INITIALIZATION (see page 12 of the DATA SHEET STV5730)
    Init:
    	HIGH Clk: HIGH Sda: HIGH Csn
    	WData = $3000: GOSUB Send 'Init STV5730
    	WData = $00DB: GOSUB Send
    	WData = $1000: GOSUB Send
    'PAGE MODE INITIALIZATION
    Mode_page:
    	WData = $00CC: GOSUB Send 'Registry initialization (tip at address 12)
    	WData = $150F: GOSUB Send 'Zoom
    	WData = $1201: GOSUB Send 'Color
    	WData = $1FC5: GOSUB Send 'Control
    	WData = $15A1: GOSUB Send 'Position (horizontal 33, Vertical 22)
    	WData = $193E: GOSUB Send 'Fashion
    	WData = $00C0: GOSUB Send 'Set row attributes (tip to first line address)
        WData = $10C4: GOSUB Send '(vertical position = 4, characters with border, characters displayed, horizontal position = 0)
    	WData = $10C8: GOSUB Send
    	FOR iCount = 0 TO 2
        WData = $10C0: GOSUB Send '(vertical position = 0, characters with border, characters displayed, horizontal position = 0)
    	NEXT iCount 'Same for the next 10 lines
        WData = $10C8
        GOSUB Delete_Screen
    Mode_mixed: 'INITIALIZATION IN JOINT MODE
    	WData = $1000: GOSUB Send 'Zoom (1pixel / dot - 1 pixel / line)
    	WData = $1204: GOSUB Send 'Color (red background, line, character background)
    	WData = $1FD4: GOSUB Send 'Control (mixed mode, character background controlled by BE, display on, color character by character attribute
    				'0.5s flashing, duty cycle 0.5, STV sync, PAL, external luminance level, normal full page mode
    	WData = $183E: GOSUB Send 'Mode (disconnected BAR, synch pulse detection, internal mute, 32-line mute time, re-inserted sync, 6dB video gain
    				'Color coder in use, video out2 = video in, video out2 low impedance, normal mode, no delay compensation,
    				'M sync with vertical sync
    	FOR iCount = 0 TO 10
    	NEXT iCount 'Same for the following lines
    	GOSUB Delete_screen
    Best, Ed
