What happens if interrupt breaks PULSIN, PULSOUT, ADCIN, PWM, etc statements?
Results 1 to 11 of 11
    Default What happens if interrupt breaks PULSIN, PULSOUT, ADCIN, PWM, etc statements?
    Hello.
    Say there is some code, which runs in loop, and measures frequency at one pin, measures voltage at another pin and does something extra.
    There is also an interrupt configured, so when signal on certain pin gets high, another piece of code is launched, which will take about 1 millisecond to execute. What will happen? as I understand, all above mentioned operations will be disrupted, and measurements need to be retaken, correct?
    Default Re: What happens if interrupt breaks PULSIN, PULSOUT, ADCIN, PWM, etc statements?
    If you're using PBP ON INTERRUPT then nothing happens because it always waits for the current command to "complete" before servicing the interrupt.
    If you're using "real" interrupts (in ASM or using DT-INTS for example) then it's different:
    If an interrupt occurs in the middle of a...
    ...PULSOUT command the width of the generated pulse will be extended by the amount of time that the interrupt takes.
    ...PULSIN command the measured width will be off by (up to) the amount of time that the interrupt takes.
    ...PWM command the PWM "signal" will just stop being generated for the duration of the interrupt. (Not applicable for HPWM of course).
    ...ADCIN command generally nothing happens. There's usually no harm in sampling the signal longer than needed and once sampled the actual conversion is done without software.
    Generally speaking whatever the PIC is doing is put on hold for the duration of the interrupt + context save/restore. This means that ALL commands using software timing will be affected.
    Yes I want to use "real" interrupts, since the task is to be executed in time. Thanks a lot.
    So if I understood correctly, if PULSOUT was generating "1" at moment of triggering, output will be held "1" till the interrupt completes? that is bad....
    Correct, if you have PULSOUT generating a 100us pulse and an interrupt occurs while the pulse is being generated the actual pulsewidth will be "extended" for the duration of the interrupt. Bad, perhaps, but that's how interrupts work, they interrupt whatever the processor is doing (ie keeping track of time in order to generate a 100us wide pulse) and goes off doing something else, more important. If generating the 100us pulse is the most important/critical task then perhaps THAT should be done using interrupts.
    Ok, so I have to move additional routine, which will ensure that output is "0", when interrupt will happen.
    Aug 2003
    If the application allows you can disable interrupts while
    those commands are running, and re-Enable straight after.
    No good for some applications such as a real time counter
    but in others you coupd get away with it.
    Two more interrupt/timer/pwm questions, if you don't mind.
    1. Is it possible to configure timer to enable-disable hpwm generator at predefined time amounts? say, 1 second on, 1 second off. So all this code will run in background, without taking CPU time?
    2. Is it possible to change interrupt type on the fly? Say, interrupt was set to rising edge, it happened, and now changed to falling edge ?
    1) For a short answer I would say no, not really but a standard timer interrupt can easily be used (which then obviously uses a combination of hardware (the timer) and software (the interrupt service routine). For a 100% hardare solution, I guess it depends on which PIC you're using and what features/peripherals it's got. It's possible that it's doable by combining for example the special event triggers and/or the configurable logic cell available on some devices but I haven't looked into it so I can't say for sure if it's possible or not.
    2) Sure, no problems with that.
    Thanks!
    For the #1, I've read 16F1829 datasheet, and it says that it can emulate 555 timer in hardware, so I guess, it might be possible to do what I want.
    For the #2, I see this In the following way:
    Interrupt was set to rising edge, it happened, and code is launched, which does what it should do, in loop. Same time, interrupt type is changed to falling edge, so when signal on interrupt pin gets low, code is terminated and main code execution continues. This is what I want to do.
    Feb 2012
    Can you just turn the interrupt off just before executing the Pulsout command and then turn it back on just after it is complete?
  1. Pulsin alternative for 2khz pwm
    Last Post: - 5th January 2014, 19:19
  2. Pulsin vs. Interrupt RPM measurement
    By Tobias in forum General
    Last Post: - 31st December 2009, 01:29
  3. 18f4550 USB and pulsin or pulsin alternative
    By vacpress in forum mel PIC BASIC Pro
    Last Post: - 15th January 2009, 13:14
  4. pulsout pulsin on same pin - timing?
    Last Post: - 15th January 2009, 07:21
  5. Pulsin to pulsout with up than 4MHZ crystal ?
    By RCtech in forum mel PIC BASIC
    Last Post: - 18th May 2006, 19:23
