Masking a number
Results 1 to 7 of 7
    Jan 2013
    Default Masking a number
    I'm programming a PIC in Oshonsoft basic, and have come across a problem.
    When using SINGLE as a variable. When two numbers as a variable should be equal. e,g, a=0 b=0 If a=b then turn on LED. When these numbers should natch they don't. It's something to do with rounding up. Someone told me too quickly for me to understand, how to use MASKING, but I didn't quite follow.
    Can anyone explain how to do this in Basic please, or if possible Oshonsoft basic. I know this isn't an Oshonsoft forum.
    Camerart.
    Default Re: Masking a number
    if a and b are int type variables and a=0 b=0 then If the statement a==b does not return a true result then that is a bug in Oshonsoft basic {unless Oshonsoft basic is weird}
    however if a and or b are of a float type then a true result is not guaranteed ( at least in c or c++ ) for equals type comparisons .
    digit masking of float data types is an invalid action , only int data types can be meaningfully masked
    since this is a pbp forum (where Oshonsoft basic vagaries not really known) you need to provide more info about your available variable types for a more detailed answer
    Jan 2013
    Hi Richard,
    I tried it in Oshonsoft, using a calculation where 1 then = 0.995. when a and b (both = 1) are tried, the variable keeps rounding up and down, so I'll have to find how to get over the Oshonsoft problem.
    I'm not good at maths, so can you explain what 'digit masking of float types is an invalid action' please. I think that INT = a whole number with nothing after the decimal point??
    C.
    pbp has no floating point type vars so a discussion about floating point arithmetic on this forum is probably inappropriate
    a value like 0.995 is a float type .
    google "comparing floating point numbers" for an explanation
    for your second question
    I think you mean
    I'm not good at maths, so can you explain why 'digit masking of float types is an invalid action' please
    see this link for how a computer stores a floating point number (I would assume Oshonsoft uses ieee754 32 bit floats) masking floats is entirely inappropriate
    http://www.h-schmidt.net/FloatConverter/IEEE754.html
    Jan 2013
    Ok, thanks. C.
    Jan 2013
    I think you mean
    Hi R,
    It appears that I'm not good at English either
    Thanks, I'll check the link.
    C.
  1. Bit masking rules
    By muddy0409 in forum General
    Last Post: - 10th March 2009, 16:48
  2. Bit Masking and Or?
    By dbachman in forum mel PIC BASIC Pro
    Last Post: - 24th February 2009, 16:19
  3. Is Number Odd?
    By T.Jackson in forum Off Topic
    Last Post: - 11th June 2008, 17:53
  4. Masking address bits
    By Demon in forum mel PIC BASIC
    Last Post: - 19th November 2005, 02:34
