detect overflow of multiply/ div32 result
Results 1 to 14 of 14
    Default detect overflow of multiply/ div32 result
    I want to multiply two word vars and then do a div32 divide where a or b can be 0-$ffff
    dummy = a * b
    result = div32 100
    is there a way to detect if the result is > $ffff so I could
    try
    result = div32 1000
    etc etc.
    till there is no overflow
    or oh for a icd that works that could monitor r(x)
    Sep 2009
    Default Re: detect overflow of multiply/ div32 result
    You can using */ or **.
    ** will return byte 2 and byte 3 of result, ignoring byte 0 and byte 1.
    So you can do something like this:
    Dummy = a ** b
    If dummy=0 then
        dummy = a*b
        result = div32 100
        multiplicator=1
        dummy = a * b
        result = div32 1000
        multiplicator=10
    perfect thanks for that
    Sep 2009
    I don't know maximum value of that variables, but if it is $FFFF then maximum number is $FFFE0001, or 4,294,836,225.
    So maybe you need to divide with more 10000,100000 etc.
    Just use select case or ELSEIF to determine with what value you need to divide.
    I did this , not tested yet
             mult=1
              ;remaining time in seconds =  (left * LAPSE )/100
             REMTIMEHOU = left ** lapse
             while  REMTIMEHOU
             mult=mult*10
             if lapse >  left  then
                 REMTIMESEC = lapse /mult
                 REMTIMEMIN = left
                 REMTIMESEC = left/mult
                 REMTIMEMIN = lapse
             REMTIMEHOU = REMTIMESEC ** REMTIMEMIN
             wend
            select case mult
            case 1
                REMTIMEHOU = left * lapse
                REMTIMESEC = div32 100
                REMTIMEHOU=REMTIMESEC//3600
                REMTIMESEC=REMTIMESEC/3600
            case 10
                REMTIMESEC = div32 1000
            case 100
                REMTIMESEC = div32 10000
            case else
                ; wtf  error
            end select
              REMTIMEMIN=REMTIMESEC//60
              REMTIMESEC=REMTIMESEC/60
              ARRAYWRITE buff,["REMAINING ",DEC2 REMTIMEHOU,":",DEC2 REMTIMEMIN,":",DEC2 REMTIMESEC,0]
              GLCDSTR 25,80 ,buff
    Last edited by richard; - 15th September 2015 at 10:51. Reason: took out redundant if
    Sep 2009
    I just noticed, that you can easily overflow variable mult after just 5 iteration.
    You can just store number of 0 in that variable, or something...
    was hoping 3 iterations will be enough, but your right
    one day I'm going to write a python pbp calculator with
    pbp math functions including ** , */ and div32
    using unsigned bytes and words
    trial and error is tedious and I hate surprise results
    Sep 2009
    It's not complicated...
    C=A*/B is same as C=(A*B)/$FF
    C=A**B same as C=(A*B)/$FFFF
    Richard... I would pay for that
    I have a lot of trouble with that kind of pbp math.
    I always have to compile and test and that takes forever !
    If there was a simulator for pbp math it would be a life saver for sure !
    Rui
    true but if you go on to a div32 then the result needs to be <$8000000
    and that the div32 divider needs to be < $8000
    and my meat calculator can't do /256 very easily
    here is a start for a pbp calculator
    with more bells and whistles
    Hi guys,
    I hope i'm not hijacking this thread but...
    Maybe my mind is set to work with decimal only and this might be a dumb question but i cant understand what we can get from these operations
    If A=1234 and B=5678 then
    A*B=7006652 ( which in bynary is 0110 1010 ... )
    I know that this operation keeps the higher 2 bytes 0110 1010 so
    A**B= 106
    Having said that, i know how they work... so my question is, when and why are these operations used?
    its mainly about speed of execution and code size.
    eg miles to kilometre conversion k=m*1.609
    pbp has no floats so the 1.609 needs to be scaled up and then the result scaled back
    this will work :-
    you could do 1.609*1000=1609
    k=m*1609 /1000
    (k=m*1609
    div32 1000)
    this is better :-
    using 1.609 * 256 = 411
    so k=m*411/256 (eq to k=m*/411)
    and will give you smaller faster code
    and has a larger input range before overflowing also
    Thanks for the explanation Richard,
    It's crystal clear now
    Rui
  1. multiply oscillators
    By ozzieB in forum mel PIC BASIC Pro
    Last Post: - 7th April 2009, 08:41
  2. Retrieving 32bit Multiply Result
    Last Post: - 28th January 2008, 15:15
  3. 18F4620 hardware multiply
    By eric180db in forum mel PIC BASIC Pro
    Last Post: - 28th November 2007, 12:54
  4. Replies: 3
    Last Post: - 13th August 2006, 05:16
  5. Can't multiply by 2!
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 29th October 2004, 14:24
