A tft addin for pbp3 - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 142
  1. #81
    Default Re: A tft addin for pbp3
    did a bit more fiddling with the buttons
    we now have rounded corners and self centering title text , and self scaling title text size too.
    the flash bit now has a flasheader cmd to read image nams and x y sizes .
    this demo has the flash bits commented out
    ps the button x,y value now is the centre of the button (was bottom lh cnr) and each button can have its own size still
  2. #82
    fixed touch module cs pin not initialised to unselected state on boot up and had some vars being used without being cleared first (real amateur hour stuff)
    now with sliders, might try to get the touch module on the spi bus next (should then be able to read touch x,y ps about 16 times faster than bit banging with shiftin )
    Excellent work Richard
    Rui
  5. #85
    This is so great work Richard. I believe you will put many here in the temptation to try at least the project.
    I am very anxious too, but unfortunately our country is still under capital control and no orders can be placed on ebay etc...
    done a bit more
    have added tft_sleep tft_wake tft_on tft_off subs, added DRAWRRECT usercmd (draw round cornered rectangle).
    change way buttons are defined . can have rectangular buttons , a button colour scheme and the button "title" text is now stored in pgm memory
    attached is a demo for a pic18f2520 using sleep/ wake on touch interrupt , backlight modulation using a pnp trany bc557 (full 10 bit)
    can supply cct if req
    Oct 2013
    Hello people
    if someone tried Richard's example with PIC18F2520 or PIC18f4520
    I tried his example with PIC18F4520 and unfortunately not working. I have just a white screen.
    If someone can send me a hex file or an example of code that works with the PIC18F4520 so that I know if my screen working properly or it is damaged.
    my connection from TFT to PIC
    tft_dc_bit con 8 ;ie bit 3 PORT B.3
    tft_cs_bit con 32 ;ie bit 5 PORTB.5
    tft_rst_bit con 16 ;ie bit 4 PORTB.4
    tft mosi PORTC.5
    tft sck PORTC.3
    when I change value of this variable the led intensity is change on port C.2 , so PIC is working
    cont=50 ;half brightness
  8. #88
    Oct 2013
    Is it possible that I destroy my TFT-display because my power supply for PIC18f4520 is 5volt?Communication between PIC and ILI9341 is on 5 volt.
  9. #89
    these displays are 3.3v devices . the only pin that is different is the vcc pin that leads to a 3.3v ldo regulator . my displays function ok with vcc =3.3v . one has a jumper to bypass the regulator if desired but this has not been necessary .
    see schematic
    ps the schematic shows the mclr pullup resistor connected to gnd , this is wrong it should be vcc
  10. #90
    Oct 2013
    OK,it works now.I replace a voltage regulator on EASYPIC 5 board from 5V to 3.3V and it works.
    What I need to do to send JPG picture to TFT display?
  11. #91
    start about post#41 I have provided some python code to convert arduino c code files generated by the "UTFT ImageConverter565.exe PGM " TO a pbp compatible format.
    be aware that a 200x200 pixel image takes 80,000 bytes of flash memory. an external flash chip is more practical for this sort of thing , I have provided code to do that also
  12. #92
    some more ways to define and animate buttons
    Oct 2013
    Because I'm not a good programmer there is a few things that are not clear to me.
    Where I can download the Arduino utft ImageConverter 565.exe.I found only a online converter on Rinky-Dink Electronics web page.
    What is the purpose of this file "flash.py.TXT" and where I must copied this file.
    When I get a image file from ImageConverter565 how I can send this file to external Flash memory w25q32.
  14. #94
    where can I get ImageConverter565
    to find the image converter just google arduino utft library
    I got mine from here
    http://www.rinkydinkelectronics.com/library.php?id=51
    download the utft.zip ,its in the utft/tools folder
    flash.py.TXT needs to be renamed to flash.py
    its a python 2.7 script . you will need to install python 2.7 on to your pc
    to be able to run it
    #flash.py extract
    import os
    import time
    from Tkinter import *
    import serial
    import glob
    ser=serial.Serial("com27",38400)
    ser.flush()
    ser.timeout=.005
    there are some python apps that mat need to be installed too see above (os,time,Tkinter,serial,glob) most come preinstalled
    the code also wants a serial port (or it will crash and burn) mine uses com27 you can edit file to suit your setup , whatever port you supply needs to exist and be available for python to use
    this code can either make a pbp.bas include image file or transfer the image directly to external Flash memory via the serial port when used with my flash add in
  15. #95
    Oct 2013
    I download python 2.7.10 version for windows and when I run it I get some errors.
    When I open script FLASH.py and pres F5 button run module I got this message:
    Python 2.7.10 (default, May 23 2015, 09:40:32) [MSC v.1500 32 bit (Intel)] on win32
    Type "copyright", "credits" or "license()" for more information.
    >>> ================================ RESTART ================================
    Traceback (most recent call last):
    File "C:\Python27\flash.py.TXT", line 6, in <module>
    import serial
    ImportError: No module named serial
  16. #96
    as I said you need to install some python extensions too
    the serial module is pyserial
    http://www.lfd.uci.edu/~gohlke/pythonlibs/
  17. #97
    back in post #54 I uploaded another python script 565-pbp.py that code is a bit simpler , it just converts the data . also if you intend to use an external flash chip with my flash code then your pic18 needs to have two mssp ports . I found buffering image data between flash and tft with them on the same port was just too tedious and slow and gave up on the process , its doable but complicated .
  18. #98
    Oct 2013
    I managed to run a python script FLASH.py and ImageConvertor565
    in the FLASH .py scripts can I put COM.1 as default port to communicate with PIC chip?
    On which the port and pin I connects serial communication between PC and PIC
    PIC RX-pin is ?
    PIC TX-pin is ?
    What is the maximum number of buttons possible to make the TFT screen.
    I tried to make a four keys and the fourth button is not working. The first three are working.
    here's the code for PIC18F4520 that I use:
    '*  Name    : pic18f2520_tft_demo.pbp                           *
    '*  Notice  : Copyright (c) 2015 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 8/28/2015                                         *
    '*  Notes   : sleep, pwm brightness (10 bit pwm)                *
      CONFIG  OSC = INTIO67
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRT = OFF
      CONFIG  BOREN = SBORDIS
      CONFIG  BORV = 3
      CONFIG  WDT = OFF
      CONFIG  WDTPS = 512
      CONFIG  CCP2MX = PORTC
      CONFIG  PBADEN = OFF
      CONFIG  LPT1OSC = OFF
      CONFIG  MCLRE = ON
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
     DEFINE NO_CLRWDT 1
     #DEFINE TOUCH_SCREEN 1
    '#DEFine  dbug 1
     ;-----------connection----------
    ;        pic                     tft
    ; <tft_port.tft_dc_bit >-------< dc   >
    ; <tft_port.tft_cs_bit >-------< cs   >
    ; <tft_port.tft_rst_bit>-------< rst  >
    ; <msspx.sdo >-----------------< mosi >
    ; <msspx.sck >-----------------< sck  >
    ; <back_light>-----------------< led  >   via pnp cct
        tft_port var latb
        back_light var latc.2   ;portc.2
        cont var word     ;  backlight level
        WIDTH   con  320 ; 160   X     MUST MATCH TFT MODULE
        HEIGHT   con 240  ; 128   Y
    ' my TOUCH_SCREEN connection definitions
     T_CLK    VAR   PORTa.7
     T_INPin  VAR   PORTa.4
     T_OUTPin VAR   PORTa.6
     T_INT    VAR   PORTb.0
     T_CS     VAR   LATb.2
     number_of_buttons con 4
     number_of_sliders con 1
            INCLUDE "TFT_SPI.pbpmod"        ;glcdc
            include "tft-ILI9431.bas"
            'INCLUDE "flash_spi.pbpmod"
            include "TOUCH_TFT.PBPMOD"      ;uncomment  to use TOUCH_TFT
            INCLUDE "font7x8.bas"
        latb=255   ;  make sure tft etc are not selected ie all cs high
        TRISA=111111
        TRISB=000011
        TRISC=010011
        TRISD=000000
        PORTD=0000000
        OSCCON = 110000         'Internal 8 Mhz Osc
        OSCTUNE=000000        'PLL ON
        cont=500               ;half brightness
        DEFINE OSC 32
        buff var byte[32]
        t2con=5
        PR2 = 255;
        CCPR1L = cont>>2;             ;set pwm
        ccp1con=12|((cont&3)<<4);
        SSPCON1=$20  ;$20-21-22 works 20 IS FASTEST
        SSPSTAT=$40
        TEXTSIZE=4
        gosub tft_init
        gosub TOUCH_INIT
          #ifdef dbug
        trisb.7=0    ;DEBUG OUT
        latb.7=1
        pause 4000
        Serout2 PORTb.7,84,["ready ", 13,10]
        #ENDIF
        glcdc  font7x8       ;SET FONT
        bg=$ffff
        fg=0
        fillrect 0,0,WIDTH,height    ;cls
        MAKEBUTTON  30,180,0,50,   "CLEAR"
        MAKEBUTTON  90,180,1,50,   "SLP"
        MAKEBUTTON  150,180,2,50,  "LED"
        MAKEBUTTON  210,180,3,50,  "VISNJA"
        MAKESLIDER  100,80,0
        slider_index  =0
        the_slider = slider_index *SL_SZ  ; set slider indexing properly
        slider_FG[the_slider ]=$ffe0    ;set slider bar colour if default not desired
        slider_count[the_slider]=cont/10
        bg=0
        INTCON2.6=0
        fg=$7FF
        DRAWBUTTON  0
        DRAWBUTTON  1
        DRAWBUTTON  2
        DRAWBUTTON  3
        slider_index  =0
        slider_MODE[the_slider]=0    ;FORCE DRAW OF SLIDER
        DRAWSLIDER  0
    LOP:
        GOSUB  CK_BUTTON
        IF      BUTTON_STATE[0]=1   THEN
            BUTTON_STATE[0]=0
            fg=0
    ELSEIF   BUTTON_STATE[2]=1   THEN
              TOGGLE PORTD.0
              BUTTON_STATE[2]=0
      ELSEIF   BUTTON_STATE[3]=1   THEN
              TOGGLE PORTD.1
              BUTTON_STATE[3]=0
    elseIF      BUTTON_STATE[1]    THEN
               if BUTTON_STATE[1]==2 then     ; shut it all down
                gosub tft_sleep
                 ccp1con=0
                 back_light=1
                 intcon=$10
                 @ sleep
                 @ nop
                 intcon=0
                 gosub tft_wake
                 CCPR1L = cont>>2;
              BUTTON_STATE[1]=0
        slider_index  =0
        IF   slider_MODE[the_slider]&1 THEN         ; adjust brightness
            cont = 1000 - slider_COUNT[0]*10
            CCPR1L = cont>>2;
            slider_MODE[the_slider]=slider_MODE[the_slider]&$FE
            TEXTSIZE=2
            fg=$7FF
            ARRAYWRITE buff,[dec3 slider_COUNT[the_slider],0]
            GLCDSTR 50,10 ,buff
     goto LOP
    VISNJA button not working.When I touch them nothing is happend.
  19. #99
    Oct 2013
    I have several questions about the code pic18f2520_tft_demo.pbp.
    how I can change color of screen wallpaper from black to yellow
    how I can changes color of buttons from red to green and how to change color of outline on buttons
  20. #100
    I have used rx2/tx2 (the code could be altered to use tx1/rx1)
    this is the limiting factor
    button_flg VAR BYTE ;1 BIT PER BUTTON make it a word to have up to 16 buttons
    button state is not defined when buttons are created easiest solution is to insert a clear command
        TRISA=111111
        TRISB=000011
        TRISC=010011
        TRISD=000000
        PORTD=0000000
       clear
        DEFINE OSC 32
        buff var byte[32]
        t2con=5
        PR2 = 255;
    the screen colour has two properties fg (foreground) bg (background)
    set them as you like
    use fg=bg and fillrect to clear an area
    button_scheme var word[4] ; [background,text,border,animated (background or border) ]
    defaults
    button_scheme[0]= $1f
    button_scheme[1]= $0
    button_scheme[2]= $7ff
    button_scheme[3]= $ffff
    buttons can have different animations too
    button_action.0[1]=1 ;flash text for this button1
    button_action.0[2]=0 ;flash outline for this button2 ; default action
  21. #101
    Oct 2013
    Why I can not write lovercase letters only capital letters work?When I write lovercase letter I got only a bad piksel on screen.
    Buttons now work excellent.
  22. #102
    are you using the font that has lowercase chars in it ?
    the first font has chr 32 to 90 post#54
    the second has chr 32 to 127 post#67
  23. #103
    Oct 2013
    Yes,wrong include I use,now it is work.
    I create a counter,and when I touch the button counter increase e his value for 1.Each press increase counter for 1.
    COUNTER=COUNTER+1
    Is it possible to make that when i press a button and hold pressed the counter increase his value throughout the whole period when it pressed
  24. #104
    yes good idea , I have added an auto repeat property to buttons
      button_rpt.0[3]=1             ;button3 auto rpt
    Jan 2011
    Sydney, Australia
    Hi Richard,
    I am having some issues compiling your TFT_Demo program and hope you can steer me in the right direction.
    I am using Microcode Studio 5.0.0 5 and PBPX 3.0.7.4
    When I first compile I get a "Syntax Error (195)". The line of code is "fillcircle 60 , 60 , 20"
    I have looked through the include files and cannot find a USERCOMMAND for "fillcircle". What am I missing?
    Attempting to move on, I commented out the offending fillcircle line of code and tried to compile again.
    Now I get four ASM ERROR message "Address label duplication or different in second pass".
    (Z001D9) (Z001DA) (Z001DB) (Z001DC)
    I am very keen to get my new TFT Touchscreen operational so any advice on how to correct the above issues would be greatly appreciated.
    I have attached all relevant files (main program, includes etc.) for your reference.
    Cheers
    Barry
    VK2XBP
    hi barry
    the address dup messages come from having coff file generation turned on when using dt_ints , don't know why ,wish it wouldn't
    see the attached screen shot to remedy that
    the syntax error i think comes from not using the latest tft-spi.pbpmod file
    I have uploaded the latest just incase I stuffed up
    I did stuff up , seems I forgot to upload the latest version with fillcircle command in it .
    apologies to all,
  28. #108
    Jan 2011
    Sydney, Australia
    Thanks Richard - that did the trick!
    Everything compiles and programs.
    Now to breadboard it and make it work
    Cheers
    Barry
    VK2XBP
  29. #109
    Jan 2011
    Sydney, Australia
    Hi Richard,
    I have had a small amount of success getting this thing going but still having a few problems.
    Firstly, your .pdf circuit diagram appears to have another mistake (apart from the MCLR issue)
    You show the LED connection on J2 as being Pin 9 however I believe it should be Pin 8 - or at least that's what is printed on the PCB silkscreen.
    I made the necessary adjustments but still nothing. I am getting a nice 50% duty cycle PWM signal (~7.8kHz) on CCP1.
    In frustration I connected the LED connection (J2 Pin 8) to the wiper of a 10k pot and adjusted it between 0V and 3.3V.
    Once I got to around 3V the screen came to life - or at least half of it did
    I think I might have a dodgy TFT screen.
    I can see the elapsed timer counting and some of the reset button but most of the right side of the screen is scrambled with a big black ovoid shape in the middle.
    Looks like I need to do another eBay purchase but don't really want to have to wait 3-4 weeks for it to arrive!
    Thanks for all your help thus far. I will be in touch again once I have a new screen to play with.
    Cheers
    Barry
    VK2XBP
  30. #110
    your right about the schematic I have uploaded a correct version , I have replaced the transistor with a pch mosfet (saves two resistors) but it still loses a little brightness and is no better than the transistor version
    I had similar issues with mine , turns out the sil connector was very poorly soldered a bit of rework fixed it
  31. #111
    Dec 2007
    Finland
    Thanks for the schematic update. Now I have to start gathering all needed components.
    Why you have selected BS250, which has quite huge Rds(on), it is round 10 Ohm or more @3.3V. Why not go with a good PFET like IRLML9301TRPbF, which has ~100-200mOhm Rds(on) @3.3V. Also price is half of the BS250. With this FET you will not burn energy in transistor -> LED will be brighter.
  32. #112
    Oct 2013
    I tried to test the repetitively button, it works but not as expected.
    When I touch the button the counter starts counting, and its value increases every 300ms for one and then suddenly accelerate and in few mS in increase his value very quikly and then slow down.
    If it happens to someone else or just me?
  33. #113
    because it comes in a t092 package I can use in a breadboard for testing , yes a IRLML9301TRPbF would probably be better but they only come in a sot23 package.
    visnja30 repetitively button, it works but not as expected
    I would need to see your code to be sure ,button auto repeat works for me just fine . auto repeat won't begin until long_press_threshold has been reached and will repeat @ repeat_press_rate
    these constants in the TOUCH_TFT.PBPMOD file control button timing . they may need adjusting depending on OSC and "gosub CK_BUTTON " loop rate
    repeat_press_rate con 100 ;button auto repeat rate (must be less than long_press_threshold)
    long_press_threshold con 300 ; min time for a BUTTON long press result
    short_press_threshold con 20 ; min time for a BUTTON pressed result
  34. #114
    I put a bug in the CK_BUTTON: subroutine in the TOUCH_TFT.PBPMOD file , it stops a long_press being detected
    should be this
    IF button_count[the_button] >= long_press_threshold THEN
    instead of
    IF button_count[the_button] > long_press_threshold THEN
    I will post a amended version when I finish getting the >64k code location problem solved for strings
  35. #115
    some updates
    CK_BUTTON: subroutine in the TOUCH_TFT.PBPMOD file fixed
    const txt strings can now be anywhere in addressable pgm memory
    button txt strings can now be anywhere in addressable pgm memory
    pin definitions for tft dc/cs/rst have been simplified
    eg. for tft cs on bit 5 instead of tft_cs_bit con 32 is now
    tft_cs_bit  con 5
    some changes to the touch add in
    now ready for 16 buttons ,makebutton is optimised a bit better, bank 0 dependency relaxed
    finally worked out why fillcircle was so slooooow
    a much faster solution
    Oct 2013
    I include file flash_spi.pbpmod there is two labels with the same name FL_IMG: is it OK or one labels is too much?
  39. #119
    its ok the same label is use twice but it is conditional,only one is selected depending on the display type when the code is compiled
    #ifdef st7735
    FL_IMG:
    or
    #ifdef ILI9431
    FL_IMG:
  40. #120
    some further refinements , drawarc (45deg arc ) fillarc (45 deg pie slice ) and a proper fillrrect (fill round cornered rectangle) and drarrrect , also fixed errors for button macros that had no text option selected
  1. Replies: 0
    Last Post: - 25th September 2013, 18:33
  2. code examples / libraries for ILI9320 2.8" TFT LCD Module
    Last Post: - 6th June 2013, 08:50
  3. I really need some help with PBP3
    Last Post: - 26th February 2012, 16:05
  4. What's with PBP3?
    Last Post: - 10th August 2011, 17:09
  5. Experience of driving TFT screens?
    By isaac in forum General
    Last Post: - 26th September 2008, 00:15
Members who have read this thread : 6
