Math problems with div32
Results 1 to 3 of 3
    Sao Paulo - Brazil
    Default Math problems with div32
    Hello Guys !
    I have a piece of code that is giving me some troubles when my program runs over several hours without stop.
    Here goes what I´m doing :
    Hour var Byte
    Minutes var Byte
    Seconds var Byte
    Time var Word
    TempA var word
    Kilometers var word
    Hundreds var word
    Time = (3600 * Hours) + (60 * Minutes) + Seconds
    TempA=(((Kilometers * 10) + Hundreds) * 3600)
    VM=DIV32 (Time)
    The problem is that the variable "Time" goes over 32767 after 9 hours (or so), and I have, frequently trips over 14 hours.
    does some one have any idea o how to simplify the math ?
    Thank you very much !
    Sérgio Pinheiro
    Default Re: Math problems with div32
    Try this:
        IF Time > 32767 THEN
            Time = Time >> 1
            TempA = ((Kilometers * 10) + Hundreds) >> 1
            TempA = TempA * 3600
            VM=DIV32 (Time)
            TempA = (((Kilometers * 10) + Hundreds) * 3600)
            VM=DIV32 (Time)
    Sao Paulo - Brazil
    Thank you Henrik !
    I´ll try this tomorrow in the morning and I´ll let you know if it worked !
    regards !
  1. Sonic Depth Meter code & Math problems 12F683
    By johnnylynx in forum PBP3
    Last Post: - 1st November 2013, 05:04
  2. PBPL Math...new math takes more cycles...Always?
    Last Post: - 10th February 2008, 10:22
  3. Div32
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2007, 20:26
  4. math problems (again)
    By lab310 in forum mel PIC BASIC Pro
    Last Post: - 28th November 2005, 22:43
  5. math problems - large numbers
    By Tomasm in forum mel PIC BASIC Pro
    Last Post: - 16th February 2004, 07:48
