I am new to pbp and i have created this 10k thermistor based temrature monitor on my own and it is working very fine without any problem, but my code is very long and takes a lot of memory, is there any alternative way write this code in short form
'i have taken thermister readings manually from -20c to 57c and
'result is stored as 8 bit values
'circuit is simple 16f877A
' 0.25 watt10k resistor 10k thermistor
' to ground---/\/\/\-----to An2-----/\/\/\---------to +5v
CLEAR
DEFINE LCD_DREG PORTD
DEFINE LCD_DBIT 4
DEFINE LCD_RSREG PORTE
DEFINE LCD_RSBIT 0
DEFINE LCD_EREG PORTE
DEFINE LCD_EBIT 1
DEFINE LCD_LINES 2
DEFINE LCD_BITS 4
DEFINE LCD_COMMANDUS 2000
DEFINE LCD_DATAUS 50
Low porte.2
DEFINE ADC_BITS 8
DEFINE ADC_CLOCK 3
DEFINE ADC_SAMPLEUS 50
trise=0
TRISA = %11111111
TRISD = %00000000
ADCON1 = %00000010 'set port a ANALOG
t vAR word 'create to read thermistor 8 bit value
x var word ' to show result from 0 to 57 C
main: 'this loop is to read from 0 to 57c because pbp dont show
' result in minus values
adcin 2,t
if t=<63 then gosub minus
if t => 64 and t=<65 then
x=0
if t => 66 and t=< 67 then
x = 1
if t => 68 and t=< 70 then
x = 2
if t => 71 and t=< 72 then
x = 3
if t => 73 and t=< 74 then
x = 4
if t => 75 and t=< 77 then
x = 5
if t => 78 and t=< 79 then
x = 6
if t => 80 and t=< 82 then
x = 7
if t => 83 and t=< 85 then
x = 8
if t => 86 and t=< 87 then
x = 9
if t => 88 and t=< 90 then
x = 10
if t => 91 and t=< 92 then
x = 11
if t => 93 and t=< 95 then
x = 12
if t => 96 and t=< 97 then
x = 13
if t => 98 and t=< 100 then
x = 14
if t => 101 and t=< 102 then
x = 15
if t => 103 and t=< 105 then
x = 16
if t => 106 and t=< 108 then
x = 17
if t => 109 and t=< 110 then
x = 18
if t => 111 and t=< 113 then
x = 19
if t => 114 and t=< 116 then
x = 20
if t => 117 and t=< 118 then
x = 21
if t => 119 and t=< 120 then
x = 22
if t => 121 and t=< 123 then
x = 23
if t => 124 and t=< 126 then
x = 24
if t => 127 and t=< 129 then
x = 25
if t => 130 and t=< 131 then
x = 26
if t => 132 and t=< 134 then
x = 27
if t => 135 and t=< 136 then
x = 28
if t => 137 and t=< 139 then
x = 29
if t => 140 and t=< 141 then
x = 30
if t => 142 and t=< 144 then
x = 31
if t => 145 and t=< 146 then
x = 32
if t => 147 and t=< 149 then
x = 33
if t => 150 and t=< 151 then
x = 34
if t => 152 and t=< 153 then
x = 35
if t => 154 and t=< 156 then
x = 36
if t => 157 and t=< 158 then
x = 37
if t => 159 and t=< 160 then
x = 38
if t => 161 and t=< 163 then
x = 39
if t => 164 and t=< 165 then
x = 40
if t => 166 and t=< 167 then
x = 41
if t => 168 and t=< 169 then
x = 42
if t => 170 and t=< 171 then
x = 43
if t => 172 and t=< 173 then
x = 44
if t => 174 and t=< 175 then
x = 45
if t => 176 and t=< 177 then
x = 46
if t => 178 and t=< 179 then
x = 47
if t => 180 and t=< 181 then
x = 48
if t => 182 and t=< 183 then
x = 49
if t => 184 and t=< 185 then
x = 50
if t => 186 and t=< 187 then
x = 51
if t = 188 then
x = 52
if t => 189 and t=< 190 then
x =53
if t => 191 and t=< 192 then
x = 54
if t = 193 then
x = 55
if t = 194 then
x = 56
if t = 195 then
x = 57
if t> 195 then
goto outofrange
lcdout $fe,1
lcdout $fe,$80, "SENSOR ",dec3 t
lcdout $FE,$C0, "TEMPRATURE ",DEC2 X,"c"
outofrange:
adcin 2,t
if t < 196 then
lcdout $fe,1
lcdout $FE,$C0, "out of range"
goto outofrange
minus: 'this loop is created to show minus values
adcin 2, t
if t=> 64 then goto main
if t=>60 and t =<63 then
lcdout $FE,$C0, "TEMPRATURE -01c"
if t=>57 and t =<59 then
lcdout $FE,$C0, "TEMPRATURE -02c"
if t=>55 and t =<56 then
lcdout $FE,$C0, "TEMPRATURE -03c"
if t=>53 and t =<54 then
lcdout $FE,$C0, "TEMPRATURE -04c"
if t=>51 and t =<52 then
lcdout $FE,$C0, "TEMPRATURE -05c"
if t=50 then
lcdout $FE,$C0, "TEMPRATURE -06c"
if t=>48 and t =<49 then
lcdout $FE,$C0, "TEMPRATURE -07c"
if t=>46 and t =<47 then
lcdout $FE,$C0, "TEMPRATURE -08c"
if t=>44 and t =<45 then
lcdout $FE,$C0, "TEMPRATURE -09c"
if t=>42 and t =<43 then
lcdout $FE,$C0, "TEMPRATURE -10c"
if t=>40 and t =<41 then
lcdout $FE,$C0, "TEMPRATURE -11c"
if t=>38 and t =<39 then
lcdout $FE,$C0, "TEMPRATURE -12c"
if t=37 then
lcdout $FE,$C0, "TEMPRATURE -13c"
if t=36 then
lcdout $FE,$C0, "TEMPRATURE -14c"
if t=>34 and t =<35 then
lcdout $FE,$C0, "TEMPRATURE -15c"
if t=>32 and t =<33 then
lcdout $FE,$C0, "TEMPRATURE -16c"
if t=31 then
lcdout $FE,$C0, "TEMPRATURE -17c"
if t=30 then
lcdout $FE,$C0, "TEMPRATURE -18c"
if t=>28 and t =<29 then
lcdout $FE,$C0, "TEMPRATURE -19c"
if t=>26 and t =<27 then
lcdout $FE,$C0, "TEMPRATURE -20c"
if t <26 then
lcdout $fe,1
goto minus
