Thanks Steve.
I have the array working now, thanks to Pedja089 (Thanks!) and thanks to Steve (EarlyBird2) I have the bit manipulation going.
I have a solution using bit manipulation and Select Case statements which work completely and is more readable than my early attempts at multiple if the statements.
The array idea works well except I can't seem to figure out the timing; on 2 inputs (9 and 11) I have a timing function where an output stays high for 2 seconds then goes low.
For the array, I use
Table var byte[16] BANKA 'Array input is the value of the 4 inputs; 0-15 from the binary weight
tflag var table.3 'timer flag
TableIn var byte 'Entry into array from inputs
temp var byte 'Temp var to use as a debounce
and to get the table data is use
Table[0]=6
Table[1]=2
Table[2]=6
Table[3]=2
Table[4]=6
Table[5]=6
Table[6]=6
Table[7]=6
Table[8]=5
' Table[9]=0
Table[10]=5
' Table[11]=0
Table[12]=4
Table[13]=6
Table[14]=6
Table[15]=6
And for the main part I tried to use
'# Subroutines
Wait2sec: pause 2000
get_input:
TableIn=PORTA & %00110011 'Selects the correct input pins
TableIn=(TableIn & %00000011) + (TableIn & %00110000)>>2
'Selects A0,A1 then selects A4,A5 moves to A2, A3 and adds to A0,A1
'Therefore, the array entry is (Command - DPI - Bolt - Deadlck)
'# Startmain - where the MAGIC starts!
Startmain: 'Main wait loop
gosub get_input 'Get inputs
temp=TableIn
gosub get_input
if TableIn <> temp then goto startmain 'Var and temp var did not match so must have been noise, go back
if TableIn = 9 then
if tflag=1 then Main1X
unlock=0
unsecure=0
lock=1
pause 2000
lock=0
tflag=1
Main1X: lock=0
unlock=0
unsecure=0
goto startmain
PORTC=Table[TableIn] 'Sets the port output to the table byte
goto startmain 'Start all over
I use the timing function which seems to work for 1 condition but when I type
if TableIn = 9 or 11 then
as a substitute for just 1 function, it bombs.
The time flag beinig reset for all of the other conditions works for 1 condition but not for an OR condition?
What am I missing now?
-Steve
