RMW Read modify write
Results 1 to 13 of 13
    Feb 2010
    Default RMW Read modify write
    This is simple Led-blink code that does not work.
    LED5 flashes normally, and LED 4 stable HIGH.................
    Using a 12F1822 (RA4 is not open collector in this PIC).
     __CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
     __CONFIG _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_OFF & _BORV_HI & _LVP_OFF
        DEFINE OSC 32
        LED5 VAR PORTA.5
        LED4 VAR PORTA.4
        OSCCON = %01110000
        ANSELA = %00000011  ' AN0 = ANALOG PIN , C1IN0- = ANALOG PIN
        TRISA =  %00000000
    LOOPA:
         LED4 = 1
         LED5 = 1
         PAUSE 100
         LED4 = 0
         LED5 = 0
         PAUSE 100
         GOTO LOOPA
    when LOOPA modified as above works fine and both LEDs blinking.
    LOOPA:
         LED4 = 1
         LED5 = 1
         PAUSE 100
         LED4 = 0
         PAUSEUS 2  <---
         LED5 = 0
         PAUSE 100
         GOTO LOOPA
    EDIT : instead of the 2us pause , i tried another command like modifying a variable , XX = 1 and still works.
    So the conclusion is , two LEDx = 0 commands in the row cannot be processed normally (although LEDx = 1 works) .
    The UFO's coming ...
    Cheers!
    Default Re: Now , This is a bug ...
    Just my guess: RMW (read modify write) takes too long to execute before being asked to RMW again, thus the nops make it work.
    Yes, classic symptoms of read-modify-write.
    So, now it's not a bug anymore - just sub optimal coding combined with capacitance on the output, high clock frequency and the hardware implementation of the PIC itself.
    If the PIC has a LAT register (which yours do have) then use it instead of the PORT register for things that may suffer from RMW issues.
        LED5 VAR LATA.5
        LED4 VAR LATA.4
    I moved your thread because it is a clear example of RMW and can help others (like me).
        LED5 VAR LATA.5
        LED4 VAR LATA.4
    See Henrik, that's the part I left out due to lack of confidence, due to being a sub optimal coder I was thinking it however. Really my FIRST example where I could see that as the issue, thanks for the validation . . . (Backup?) So now I am reasonably sure I was correct. Thanks.
    Feb 2010
    Thumbs up Re: RMW Read modify write
    Thank you guys!
    Very clear response...
    Feb 2012
    PERTH AUSTRALIA
    Default Re: RMW Read modify write
    when using the whole port as a data i/o bus is specifying LAT control possible or required for the port ?
    Hi Sheldon,
    Yes, it's possible. It's not required but generally recommended (I'd say).
    You say i/o but you can't use LAT to read the state of the pins when in input mode. If you read LAT you get the state of the output latch, not the state of the actual pins.
    Feb 2012
    PERTH AUSTRALIA
    glcd_fs     var LATD.0     ' Font Select pin   High = 6x8 , Low = 8x8
        glcd_wr	 	var	LATD.1	   ' Write control pin ( Active Low)
        glcd_rd	 	var LATD.2	   ' Read control bit  ( Active Low)
        glcd_ce	 	var LATD.3	   ' Chip enable control bit  ( Active Low)
        glcd_cd	 	var LATD.4	   ' Command (high) and Data (low) toggle bit
        glcd_rst	var LATD.5	   ' Reset control bit (Active Low)
        glcd_tris 	var TRISE	   ' Data bus direction
        glcd_dat	var PORTE	   ' LCD 8 bit data bus
        glcd_sta0	var PORTE.0	   ' Status Bit 0  - Status Read - Command excute capability      - 0 = not avaialble / 1 = Available
        glcd_sta1	var PORTE.1	   ' Status Bit 1  - Status Read - Data Read/Write capability     - 0 = not avaialble / 1 = Available
    yes the 8 bits of the port are used as both input / output
    i would think PBP uses the LAT registers in the above use ???
    i um PBP uses the LAT
    Not sure I understand the question, if there is any....
    In short:
    * To put data on the bus, write to the LATx register
    * To read data from the bus, read from PORTx register
    If you do
    glcd_wr	 	var	LATD.1
    You can do glcd_wr = 1 but you can not do HIGH glcd_wr. HIGH/LOW etc only works on PORTx
    Feb 2012
    PERTH AUSTRALIA
    as this is 8bit data port with the TRIS set at $00 or $FF
    would PBP uses LAT port registers internally ?
    assuming you have lat registers on your pic chip , porte is not equal to late they are separate registers . check the memory map of your chip.
    pbp has no glcd native functions, whether your "glcd library" uses late is completely dependent on how the library was written .
    if you define your "data bus" as porte I would expect it will not use lat regs (that would probably require two defines , one for each direction)
    and lastly rmw has no impact at all when you are writing to the whole port
    Feb 2012
    PERTH AUSTRALIA
    thanks richard
  1. PLEASE HELP...read write issues
    By nomad77 in forum mel PIC BASIC Pro
    Last Post: - 17th March 2011, 14:39
  2. Write/Read DS1996
    By Bosse in forum Forum Requests
    Last Post: - 9th September 2008, 00:25
  3. DS1996 Read/Write
    By Bosse in forum Serial
    Last Post: - 30th October 2007, 13:36
  4. Read and write to sd card
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 28th October 2007, 19:47
  5. Read Modify Write problem?
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 18th November 2005, 21:02
