ICSP with MCLR as input
Results 1 to 3 of 3
    Feb 2009
    Southern California
    Default ICSP with MCLR as input
    I am converting a project into a surface mount version and wanted to add the ability to do ICSP since you never know when you need to update code. I have two 18F45K22 chips and one 12F629 chips. I was able to get the two 40 pin guys working, but the 8 pin is giving me trouble. I have removed all the extra hardware from the circuit that connects to the MCLR line and the data/clock lines so they go only to the header. If I put a blank chip in I can get the ICSP to work once, but have to take the chip out and blank it to program it again in circuit. I believe the problem is related to my setting the MCLR (GPIO3) as an input.
    I saw on the melabs website they recommended
    TRISIO = $FF
    PAUSE 1000
    to allow for programming on power up. I went to 5000 just because and had no luck.
    My configs are set up as:
        __config _HS_OSC & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BOREN_ON & _CP_ON & _CPD_ON
    I have attached the schematic motherboard.pdf, though I have pulled the LED on the clock line, the resistor on the VPP line and I took out the microchip that is connected to the data line just to be safe.
    Thanks for taking a look
    David
    Feb 2012
    PERTH AUSTRALIA
    Default Re: ICSP with MCLR as input
    try setting _MCLRE_OFF in config to _MCLRE_ON , as it is looking for a digital input
    If you are using a Pickit2, try enabling the 'Use Vpp first program entry' option under tools; I suspect that should solve the problem, from the symptoms you describe.
  1. Q: using MCLR for Input on 12F683
    By picster in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 15:25
  2. MCLR line input only
    Last Post: - 10th April 2008, 23:14
  3. Mclr As Input Pin?
    By omid_juve in forum mel PIC BASIC Pro
    Last Post: - 24th December 2007, 06:33
  4. RA5/MCLR input in 16f88
    By kacho in forum mel PIC BASIC Pro
    Last Post: - 5th April 2005, 17:21
  5. 16f688 and MCLR (ra3) as input
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 1st March 2005, 18:15
