Help with btc Player re-creation from Darrel Taylor
Results 1 to 4 of 4
    Dec 2006
    Brasil, Sao Paulo, Campinas
    Default Help with btc Player re-creation from Darrel Taylor
    Hello Darrel Taylor,
    I apreciate very much your article "btc Player re-creation". I created my hardware using a 18F452 and worded fine now! However I would like to know about your btc_converter used to generate the .asm files (soungs and number from your examples). Can you to post the converter used and to explain about the process to create the files? The format exported by Btc3.exe from Roman Black is diferent and don't work into TestRBsound.pbp. I would like to increase my sound library with more, like point, degrees, celsius,km/h, meters, hours, minutes, seconds,latitude, longitude,sine,cosine...because it is a very very good tool to projects with soungs, clock, gps...
    Please Darrel, help all to improve our library! How can I help you? Are you interested?
    Aug 2003
    Default Re: Help with btc Player re-creation from Darrel Taylor
    Hi, I got your email about this, but might as well answer it here.
    The talking thing I've used in all my projects is RB's algo, and and asm program to run the chip.
    Basically, it's like a talkbot brain, but before they existed. Mine connects to a pic with a 5 bit parallel interface,
    and has a signal line output to indicate it's playing in case you need to know when the current sample has finished.
    These days I'd just go for the talkbot brain, and it's software, since I do believe it's open source,
    should be easier to load samples, and you should be able produce your own hardware.
    Dec 2006
    Thanks Art,
    Walter Dunkel (scalerobotics) also help me with btc. He writed an example using numbers, and I want to do a talking clock with it. The firts tests was a sucess! Now I know to create my sounds!
    Thank you again
    Aug 2003
    Cool, pretty much what I did.
    You might want a pin set high from the pic that is making the sound
    while it is playing, so the other chip knows exactly when to send the code for the next sample,
    rather than waiting a certain amount of time before sending the next sound code,
    especially if you are assembling a bunch of numbers to recreate speech.
    (that is if you are using a separate chip for playing the sound).
  1. Darrel Taylor Interrupts and MultiCalc
    By AvionicsMaster1 in forum General
    Last Post: - 14th February 2012, 06:18
  2. Timer1 and Timer2 interrupts, Darrel Taylor
    By ronbowalker in forum mel PIC BASIC Pro
    Last Post: - 17th December 2009, 18:38
  3. To Mr. Darrel Taylor once again
    By atwoz in forum mel PIC BASIC Pro
    Last Post: - 10th December 2009, 19:10
  4. Darrel Taylor Elapsed Timer
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 01:22
  5. @Darrel Taylor Interrupt ;-)
    By Robson in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 00:59
