Hello Dear,
I built a circuit and ran the LED on off code. I am using U2 programmer. I got an error 'ilegal opcode' when I defined the config fuses in the code. The code works fine without config fuse inserts but then I have to pick them in the programmer every time I download the code into the chip. Is there a way around?
Thank you,
IapIllc
Oops! I typed 828A instead of 628A in the subject line and I can't change it now.
