Why is this code not working(pwm on a 16f628a)
Results 1 to 9 of 9
    Default Why is this code not working(pwm on a 16f628a)
    So I am testing out pbp and am trying to get an led to fade on, stay on, then fade off. Here is my current code
    STARTMAIN:
    if button=0 then
        For Duty=0 to 255 Step 1
            PWM LED4,Duty,Cycle
        Next
        led4=1
        For Duty=255 to 0 Step -1
            PWM LED4,Duty,Cycle
        Next
        LED4=0
    LED4=0
    GOTO STARTMAIN
    What happens is that when I press the button, the led fades on, then turns off for a second, then fades off. Why is this happening?
    Default Re: Why is this code not working(pwm on a 16f628a)
    How is the LED connected to the PIC?
    EDIT: And what did you use as CONFIG and TRIS settings?
    positive end is connected to the pin, negative end is grounded
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_OFF & _MCLRE_OFF & _BODEN_OFF & _LVP_OFF
    Define OSC 4
    LED4 VAR PortA.1
    button VAR PortA.2
    CMCON = 7
    VRCON = 0
    PortA=0
    PortB = 000100
    T1CON = 000011
    TRISA = 000100
    TRISB = 000000
    and this code works though, which is really confusing me
    new:
    if button=0 then
        led4=1
        led4=0
    goto new
    Totally wild guess, confirm your programmer is setting the low voltage programming fuse properly:
    http://www.picbasic.co.uk/forum/show...ht=#post113491
    (still looking at datasheet)
    EDIT: Darn, I remember reading another thread that was missing one more config to disable analog, can't find it now.
    It must be something with the PWM, either config or syntax.
    What if you use variables like this?
    http://www.picbasic.co.uk/forum/show...ht=16f628a+pwm
    Aug 2008
    Portugal
    Try this code insted
    STARTMAIN:
    if button=0 then
     For Duty=0 to 255
      PWM LED4,Duty,Cycle
     Next
     high led4
      PWM LED4,Duty,Cycle
     Next
    low led4
    GOTO STARTMAIN
    If you read the PBP Manual you will see that the PWM command after execution turn the pin input.
    Thanks and Regards;
    Gadelhas
    May 2008
    Italy
    Did you declare the variable CYCLE? Did you give a value to such a variable?
    If not then PWM command will not work.
    Cheers
    Al.
    Quote Originally Posted by gadelhas View Post
    STARTMAIN:
    if button=0 then
     For Duty=0 to 255
      PWM LED4,Duty,Cycle
     Next
     high led4
      PWM LED4,Duty,Cycle
     Next
    low led4
    GOTO STARTMAIN
    thanks, so high and low still work when the pin is a input, interesting.
    not interesting, it is explained in the manual...
