12F683 Logic Output Problem?
Results 1 to 6 of 6
    Feb 2012
    Default 12F683 Logic Output Problem?
    I wrote some program but it is not working completely: It is for mosfet motor controller, HPWM section works (in TEKYON subroutine) But I can't take high logics from GPIO.0 and GPIO.5 I added program. Are there any problem?:/ I tried with 4 12F683 but all have same problem.:/
    @ device pic12f683, fcmen_off, ieso_off, intrc_osc, wdt_off@ device pic12f683, pwrt_off, mclr_off, protect_off
    ADCON0.7 = 1      ' Right justify result
    ANSEL = 111000 ' Set AN3 analog, rest digital
    CMCON0 = 7        ' Analog comparators off
    INTCON = 000000
    OSCCON = 100000 ' Internal 4MHz osc
    WPU = 0 ' Internal pull-ups = off
    trisio=10000
    output gpio.0
    output gpio.5
    'Define ADCIN parameters
    Define ADC_BITS 8 ' Set number of bits in result
    Define CCP1_REG GPIO 'PWM Output on gpio
    Define CCP1_BIT 2 'Bit 2
    Posit var Word
    Speed var byte
    x var byte
    Tekyon:
    ADCIN 3, Posit
    HPWM 1,posit,12000
    high GPIO.0
    low GPIO.5
    Goto Tekyon
    Default Re: 12F683 Logic Output Problem?
    Not sure about your TRIS statement, the forum might have messed it up.
    What do you have GPI0.5 set for in the TRIS?
    Feb 2012
    I added spaces:
    trisio= % 00010000
    It looks like it should work. Back up and write a program to blink an LED on GPIO.1 and 5. Just to test.
    Aug 2004
    Hi
    You are setting gpio.5 as input with trisio = 100000
    Only gpio.3 must be set to work as adc.
    Then the correct trisio = 1000. Or = 8
    Greetings...
    Ruben de la Pena .
    Aug 2004
    Sorry, my mistake...
    I did not see the data sheet and I have not used this Pic.
    I read you need use AN3 as adc input and I assumed this was at Gpio.3.
    It is at Gpio.4, then you need set trisio.4 as input and the correspondent pin at Ansel.
    But Trisio.5 MUST BE CLEARED to work as output.
    Greetings...
    Ruben de la Pena V.
