PBP3 and MPLAB 8.83
Results 1 to 7 of 7
    May 2009
    Default PBP3 and MPLAB 8.83
    I am trying to compile a program using pic basic pro under MPLAB 8.83. The following is the build information.
    Executing: "C:\PBP3\PBPMPLAB.BAT" -ampasmwin -k# -p16F883 "walltimer.pbp"
    PBPMPLAB.BAT 4.0.0.0
    Using MPASM from C:\Program Files\Microchip\MPASM Suite\.
    Executing: "C:\PBP3\PBPX.EXE" -ampasmwin -k# -p16F883 "walltimer.pbp"
    PICBASIC PRO(TM) Compiler 3.0.1.4, (c) 1998, 2011 microEngineering Labs, Inc.
    All Rights Reserved.
    BUILD FAILED: Tue Feb 07 18:05:37 2012
    The assembler has 0 errors yet the Build failed. Any ideas on how to find out why the build failed?
    Graham
    Default Re: PBP3 and MPLAB 8.83
    Can you post your code too?
    Are you using MCSX as an editor?
    If you do, have you selected the correct PIC from the pull down menu?
    Executing: "C:\PBP3\PBPMPLAB.BAT" -ampasmwin -k#   -p18F2620 "Test2620.bas"
    Executing: "C:\PBP3\PBPX.EXE" -ampasmwin -k# -p18F2620 "Test2620.bas"
    PICBASIC PRO(TM) Compiler 3.0.4.4, (c) 1998, 2011 microEngineering Labs, Inc.
    Loaded C:\Program Files\Microchip\MPLAB IDE\Projets\Test2620.COF.
    BUILD SUCCEEDED: Wed Feb 08 18:41:48 2012
    Here is the success screen ...
    first : you should update your PBP version ...
    Then try running the " PBP_MPASM_Connector " located in the "C:\PBP3\MPASM-MPLAB_SETUP" folder ...
    Alain's got eagle's eye, I say!
    I saw 3.0.1.4 and was sure it was the latest update.
    Bravo Alain.
    May 2009
    I downloaded the latest PBP3 update and installed. I still get same results. Tested with some older programs and everything works fine. If I compile using MCSX then it compiles ok. The only thing different is that I do not get the message " Loaded C:\Program Files\Microchip\MPLAB IDE\Projets\Walltimer.COF"
    Executing: "C:\PBP3\PBPMPLAB.BAT" -ampasmwin -k# -p16F882 "walltimer.pbp"
    Executing: "C:\PBP3\PBPX.EXE" -ampasmwin -k# -p16F882 "walltimer.pbp"
    BUILD FAILED: Thu Feb 09 16:21:30 2012
    May 2009
    Thank you for your replys. The problem has been resolved by deleting the project and creating a new project. Everything is now working correctly.
    With PBP3 you need MCSX editor.
