scrolling text input? for pic18f4520 with 2x16 lcd
Results 1 to 18 of 18
    Feb 2012
    Default scrolling text input? for pic18f4520 with 2x16 lcd
    I tried googled, but couldn't get what I want, probably got the searching terms wrong
    basically I want to input letters like in the below video, scroll from 0 to Z
    could anyone tell me what is this method call? I do need sample codes, to work with too
    thanks alot for reading
    Apr 2007
    Pennsylvania, USA
    Default Re: scrolling text input? for pic18f4520 with 2x16 lcd
    There is no scrolling text in that video. That is just the cursor showing which digit is to be changed, and a set of buttons to toggle the value of that digit. Is this what you are trying to do? Do you have an LCD setup with the ability to display characters onto it already?
    Shawn
    Feb 2012
    Quote Originally Posted by spcw1234 View Post
    oh yes, I have the buttons and lcd integrated, and is displaying "hello world"
    Apr 2007
    Pennsylvania, USA
    You need to create a variable to display that the button will toggle.
    Do you have some code started that you can post up?
    Shawn
    Aug 2003
    Something like:
    value var word
    incvalue var word
    cursorposition var byte
    **LCD setup code here **
    LCDOUT $FE, $0F        'turn blinking cursor on
    cursorposition = 0    'reset cursor position
    dostuff:
    LCDOUT #value DIG 3
    LCDOUT #value DIG 2
    LCDOUT #value DIG 1
    LCDOUT #value DIG 0
    IF upbutton = 1 THEN
    IF cursorposition = 0 THEN
    value = value + 1
    IF cursorposition = 1 THEN
    value = value + 10
    value = value + 100
    value = value + 1000
    IF downbutton = 1 THEN
    value = value - 1
    value = value - 10
    value = value - 100
    value = value - 1000
    IF leftbutton = 1 THEN
    IF cursorposition > 0 THEN
    LCDOUT $FE, $10        'move cursor left
    cursorposition = cursorposition - 1
    IF rightbutton = 1 THEN
    IF cursorposition < 3 THEN
    LCDOUT $FE, $14        'move cursor right
    cursorposition = cursorposition + 1
    IF confirmbutton = 1 THEN
    '** go back to, or continue the main program here
    goto dostuff
    Aug 2003
    oops, straight after the dostuff: label,
    LCDOUT $FE,2                                    'LCD cursor return home
    FOR count = 0 TO cursorposition
    NEXT count
    to set up the display for the next frame.
    None of this is tested, but you should get the idea.
    Might want to compare cursor position with 0,1,2 and 3 when checking the buttons instead of only 0 and 1 no?
    Can you even use cursor position 0? Or does it start at 1?
    I think you have them backwards, the units would be at position 3, tens at position 2 and so on.
    But yeah, that's a perfect starting point to start building on.
    Aug 2003
    Whoops, ... copy & paste & forgot to adjust
    value = value - 1
    value = value - 10
    IF cursorposition = 2 THEN
    value = value - 100
    IF cursorposition = 3 THEN
    and do the same with te up button.
    Also need a pause for button debounce, so
    straight after each button check
    cursorposition = 0 is the thousands position.
    The thousands digit is the first to be printed to LCD,
    so no movement needs to occur from cursor home command.
    Aug 2003
    And the other thing you mentioned...
    I need to build a generic test circuit before posting code
    Just to be sure, I wasn't being sarcastic.
    I wanted to post an attempt, but it's easier for me to pick at others.
    Feb 2012
    thanks, I will try out myself this week, get back here with any progress and problem
    Aug 2003
    Not taken that way at all... good catches
    Feb 2012
    guys
    I manage to get the lcd working with the cursor responding to the left right navigation button
    now , I have a problem with the change of letter
    lets say if I want the 1st letter to be from 0,1,2,3,..,9,A,B,C
    I am thinking of 012345679ABC as a string, then move from bit to bit
    or should I get an array of 13, then point to it
    This is totally off the top of my head, no code:
    Use an array with 1 element for each character on display.
    - if 4 characters, then use 4 elements starting at 0.
    Store the position of each character in the array.
    - character 1 starts at 0 on startup, so array(0)=1.
    Use a lookup table to display each character.
    Lcdout (clear screen)
    For element = 0 To 3 (if using 4 characters)
    Lookup array(element),[0,1,2,3,4,5,6,7,8,9,A,B,C],byteout
    Lcdout byteout at next position on display
    Next element
    -syntax must be corrected.
    - never used lookup so not sure if it starts at 0 or 1.
    - I remember concatenating characters on the same LCD line, somewhere.
    Ok Art, now it's your turn.
    Aug 2003
    Well since I was invited it's either what you said, or look up from on-chip eeprom if all lookup tables are going to end up the same.
    Much nicer if it was just numeric values, and you could just increment/decrement each byte with the up/down button pushes.
    After that first attempt, I'm not going to code it without a test circuit here...
    Feb 2012
    cool, I just need some hints on the algorithm , or rather a better way of writing...
    shouldn't have any problem writing the code myself
    thanks again, lets hope my weekend will be fruitful
    Aug 2003
    Actually if it's just "0,1,2,3,4,5,6,7,8,9,A,B,C"
    You should still just increment or decrement the values and use LCDOUT outputting the hex byte values.
    That string is still sequential when expressed in hex format. Just a value from 0 to 12.
    Feb 2012
    I am going to do this
    hexadecimal increment/decrement from 0 to C
    position 1 to 4
    store the position 1-4 to a temp location
    all 4 temp location , combine into a string
    eg
    going to input A123 memory
