sht_75 and SHT XX pgm correction
Results 1 to 6 of 6
    Jun 2008
    Varese , Italy
    Default sht_75 and SHT XX pgm correction
    I have found a problem in the pic basic pro program used to compute relative humidity and dew point . Those program are available in this forum.
    I will like now to post the corrected program that allows correct computation of RH_tc and dew point even if the temperature is below 0 deg C.
    I hope it could help someone!
    Ambrogio
    quote:
    for S_RH=100 TO 3500 STEP 50 ' change them as needed to generate an output list
    for s_t=1000 to 8000 step 500 ' change them as needed to generate an output list
    if S_T => 4000 then
    TEMP=S_T-4000 ' TEMP *100
    SIGNtc="+" ' POSITIVE
    TEMP=4000-S_T ' TEMP *100
    SIGNtc="-" ' NEGATIVE
    DEBUG "S_T=",DEC S_T," T=",SIGNtc,DEC TEMP/100,".",DEC1 TEMP/10
    COMPUTE_RH_T:
    WY=405*S_RH
    WY=DIV32 100
    WX=S_RH*S_RH
    WX=DIV32 1000
    WX=WX*28
    WX=DIV32 100
    RHLIN=WY-WX-400 ' RH_LINEAR
    WY=(8*S_RH+1000)/10
    IF SIGNTC="+" THEN
    IF TEMP> 2500 THEN
    WX=(TEMP-2500)*WY
    WX=DIV32 100
    RHTC=RHLIN+WX/100
    WX=(2500-TEMP)*WY
    WX=DIV32 100
    RHTC=RHLIN-WX/100
    WX=(2500+TEMP)*WY
    WX=DIV32 10000
    RHTC=RHLIN-WX
    DEBUG " S_RH=",DEC S_RH," RHlin=",DEC RHLIN/100,".",DEC1 RHLIN/10," RHtc=",_
    DEC RHTC/100,".",DEC1 RHTC/10,"%"
    COMPUTE_DP: ' COMPUTE DEW POINT....................................
    '** Dewpoint Calculation
    ' See: SENSIRION Application Note "Dewpoint Calculation"
    ' logEW = (0.66077+7.5*T/(237.3+T)+(log(RH)-2)
    ' DP = ((0.66077-logEW)*237.3)/(logEW-8.16077)
    TempDP=Temp/10
    logEW=6608
    'sign=TempDP.bit15
    if s_t<4000 then ' we are below zero °C
    sign=1
    sign=0 ' we are above zero °C
    wz=ABS TempDP
    wx=(7*wz)+(wz/2)
    'debug "Wx=",dec wx,13,10
    if sign=0 then
    wy=2373+wz
    wy=2373-wz
    wj=wx/wy
    For ix=15 to 0 step -1
    wx=(wx//wy)<<1
    wz.bit0(ix)=wx/wy
    next ix
    wx=(-sign^((wj*10000)+(wz**10000)))+sign
    logEW=wx+logEW
    wx=RHtc/10
    wj=(NCD wx) - 1
    wx=wx<<(15-wj)
    wz=0
    For ix=14 to 0 step -1
    wy=wx**wx
    wz.bit0(ix)=wy.bit15
    bt=~wy.bit15
    wx=wy<< bt+(bt & wx.bit15)
    next ix
    wx=((wj*4000)**49321)+(wz**6021)
    logEW=wx+logEW-30000
    sign=logEW.bit15
    logEW=(-sign^(((ABS logEW)+2)/4))+sign
    wx=1652-logEW
    sign=~wx.bit15
    wx=ABS wx
    wy=20402-logEW
    wj=wx/wy
    wx=(wx//wy)<<1
    wz.bit0(ix)=wx/wy
    Next
    DP=((23730**wz)+5)/10
    DP=(-sign^DP)+sign
    'debug "DP=",DEC2 ABS DP/10,".",DEC1 ABS dp,13,10
    'debug "dpC=",rep "-"\sign,dec abs DP/10,".",dec1 abs DP,13,10
    'lcdout ins,line3,"dp=" ,DEC2 ABS DP/10,".",DEC1 ABS dp
    'lcdout ins,line4,"dp=" ,rep "-"\sign,DEC ABS DP/10,".",DEC1 ABS dp
    DEBUG " dp=", rep "-"\sign,DE
    next s_t
    next s_rh
    unquote.
    Default Re: sht_75 and SHT XX pgm correction
    Hi There
    Can I ask that you post the complete corrected program, I am trying to get the sensor working with a 16F913 and are having issues. Another question in all the examples nobody use I2CREAD and I2CWRITE is there a reason?
    Andre
    Jun 2008
    Varese , Italy
    this is what Sensirion says about the interface :
    quote
    The serial interface of the SHT7x is optimized for sensor
    readout and effective power consumption. The sensor
    cannot be addressed by I2C protocol, however, the sensor
    can be connected to an I2C bus without interference with
    other devices connected to the bus. Microcontroller must
    switch between protocols.
    unquote.
    I would like to see the complete program too. I have one working here since about 2011 and I am interested if something new is available .
    Ambrogio
    Jun 2008
    Varese , Italy
    here I am again,
    Any possibility to see the final complete code ... ?
    I knew there was a problem in dew point calculation at negative temperature ) °C ) ... any advice ?
    ambrogio
    Mine still gives the same value no matter what I do, will work on it again this weekend.
    Jun 2008
    Varese , Italy
    I am still searching for a really working code of this sensor ... if any
    Ambro
