Re: Fan causing noise in audio circuit
Originally Posted by
The Master
Sorry, I'm not sure what you mean by "bobbin" (not in an electronics sense anyway).
What can I say now?
http://en.wikipedia.org/wiki/Bobbin
"in an electronics sense", the noise is generated at the ground of the circuit.
So, "in an electronics sense", a "bobbin" is used as the last component going to the ground of the power supply.
In other words, the "bobbin" is placed between the ground of the circuit and the ground of the power supply.
Usuallly, people make mistake by placing the "bobbin" to the positive supply and it makes no difference.
The Master
Are you clear what I mean by "bobbin" now?
