A to D to A help
Results 1 to 8 of 8
    Jun 2011
    Default A to D to A help
    Im new at this so please be gentle. I'm using a pic185252 and a ltc1661 d to a.
    The circuit needs to take a voltage reading from a flow sensor sample that
    voltage by a set number of samples (16,32,64 etc.. this number will be chosen in
    a varible with the inital flash of the mcu) take that voltage go to a 256 point
    lookup table in the flash to convert this voltage reading to a flow rate number
    this flow rate number will then be multiplied by a scalar (variable in inital flash)
    this flow number will then be used with a 64point lookup table in the eeprom (64
    ponts set with inital flash) to convert it back to a different voltage..
    the first table will be 256 points from 0-6 volts
    the second table will be 64 points with flow values from 0 to 388 kg/hr, 0 to 777
    kg/hr, 0 to 1555 kg/hr, 0 to 2332 kg/hr, 0 to 3110, and 0 to 3888. the range will
    be selected with a variable in the inital flash. the table will convert these flows
    back to voltages.
    all the tables will need interpolation.
    My friend helped me write a simple code to just do a direct voltage conversion but i think I need to rework the whole thing for what i'm trying to do now..
    here is the code for the first one
    ' Uses 18F252 and 20MHz external clock.
    ' The lookup table contains 65 values, from 0 to 6V input.
    ' communicates with PC through serial port.
    ' Has an added 32 sample average on the input.
    Define OSC 20   ' use 20 Mhz clock
    Define  ADC_BITS     10
    Define  ADC_CLOCK    3
    Define  ADC_SAMPLEUS 24
    ' initial EEPROM values (output = input)
    EEPROM [216,0,217,0,219,0,223,0,229,0,237,0,246,0,0,1,12,1,_
              22,1,30,1,42,1,55,1,69,1,86,1,104,1,_
              124,1,143,1,163,1,184,1,202,1,219,1,237,1,254,1,15,2,_
              32,2,49,2,66,2,82,2,98,2,114,2,130,2]
    EEPROM 128,[146,2,161,2,177,2,192,2,207,2,222,2,237,2,252,2,11,3,_
              26,3,40,3,55,3,70,3,84,3,99,3,113,3,_
              128,3,142,3,156,3,170,3,183,3,197,3,210,3,223,3,236,3,_
              249,3,255,3,255,3,255,3,255,3,255,3,255,3,0,4]
    adval VAR WORD      ' analog input value
    outputval VAR WORD  ' output value
    tempval VAR WORD    ' temporary
    tablehigh VAR WORD  ' high table value
    tablelow VAR WORD   ' low table value
    tempval2 VAR WORD   ' temporary #2
    avgarray VAR WORD[32]' array for averaging input samples
    countnum VAR byte   ' integer for counting sample array
    arraysum VAR WORD   ' summing variable for average
    TRISA = 255         ' portA => input
    ADCON1 = %10000010  ' Set PORTA to analog and PORTE to digital
    TRISB = %00000000 ' Port B set for output
    HIGH PORTB.2      ' Serial D-A chip select off
    countnum = 0
    clearloop:          ' zero out array
    if countnum != 32 then
        avgarray[countnum]=0
        countnum = countnum + 1
        goto clearloop
    countnum = 0
    arraysum = 0
    loop:  ' start of main loop
        Adcin 0, adval
        arraysum = arraysum - avgarray[countnum]  'subtract value at countnum
        avgarray[countnum] = adval                'store new value in array
        arraysum = arraysum + adval               'add to sum value
        adval = arraysum >> 5                     'divide by 32
        if countnum = 32 then
        countnum = 0
        tempval = adval >> 3    ' shift input for table lookup
        tempval2 = tempval & %1111111111111110 ' clear last bit for WORD lookup
        'get table high and low values
        READ tempval2+2,tablehigh.BYTE0
        READ tempval2+3,tablehigh.BYTE1
        READ tempval2,tablelow.BYTE0
        READ tempval2+1,tablelow.BYTE1
        'Table Interpolation
        tempval = adval & %0000000000001111 ' get interpolation value
        IF tablehigh >= tablelow THEN       ' get space between table values
        tempval2 = tablehigh - tablelow     '
        ELSE                                '
        tempval2 = tablelow - tablehigh     '
        ENDIF                               '
        tempval = tempval2 * tempval        'multiply high/low diff by interp value
        outputval = tempval >> 4            'divide by table spacing
        IF tablehigh >= tablelow THEN       ' offset table value by calculated
        outputval = outputval + tablelow    ' interpolation value
        ELSE                                '
        outputval = tablelow - outputval    '
        ENDIF                               '
        tempval = outputval << 2   ' shift output left 2 bits(LTC1661 DtoA)
        tempval = tempval + %1001000000000000   ' add control code(load DAC A)
        LOW PortB.2     ' Enable DtoA chip
        Shiftout PORTB.0,PORTB.1,1,[tempval\16] ' Serial output to DtoA conv
        High PORTB.2    ' Deselect DtoA chip
        goto loop       ' repeat main loop "forever"
    Miami, Florida USA
    Default Re: A to D to A help
    Awdgsx,
    What is your question? What do you need help with?
    Anonymous
    Jun 2011
    well the first one is how do I store a table into the flash memory instead of the EEPROM
    Miami, Florida USA
    Use the WRITECODE and READCODE commands. These commands cannot be used in all the chips. Refer to the manual for more info.
    Anonymous
    Jun 2011
    Thank you!
    Apr 2006
    New Hampshire USA
    Red face Re: A to D to A help
    See:
    Making Program Code Space your playground...
    http://www.picbasic.co.uk/forum/showthread.php?t=137
    Thank you Melanie!
    I would do something around some in the following
    http://www.picbasic.co.uk/forum/showthread.php?t=1999&
    Jun 2011
    So like this for my table..
    WRITECODE 16384 , 1011
    WRITECODE 16385 , 2014
    WRITECODE 16386 , 3014
    WRITECODE 16386 , 4050
