Manometer project continued.
Results 1 to 13 of 13
    Apr 2011
    NSW, Australia
    Default Manometer project continued.
    OK, I have the math to a point where it is calculating somewhere near the number I want.
    I have connected the hardware. A MPXV4006 pressure sensor which is connected to a MCP3201 ADC which in turn goes via SPI to a 18F14K50 PIC.
    Attached is the setup.
    ' Variables
    SCK     VAR PORTB.6 'Clock pin
    CS     VAR PORTC.1 'Chip Select Active low
    SDI     VAR PORTB.4 'Data In pin
     COUNTS var word
     lbit var COUNTS.byte0
     hbit var COUNTS.byte1
    Define LOADER_USED 1
    INCLUDE "MODEDEFS.BAS"
    DEFINE OSC 12
    DEFINE SHIFT_PAUSEUS 10  'gives a 50KHZ clock pulse
    TRISB.4 =1               ' set PortB 4 as an input
    TRISB.6 =0               ' set PortB 6 as an output
    TRISC =%00000000
    knots var long
    knotsRem var long
    HIGH CS
    START:
    LOW CS
    PAUSEUS 50 'delay after CS goes low for conversion to start. Probably not needed
    SHIFTIN SDI,SCK,2,[counts\14]  ' using mode 2 for SPI
    high cs
    'knots = ((SQR(counts*100))*1563)/10000
    'knotsRem = (SQR(counts*100)*1563)//10000
    'serout2  portb.7,396,[ #Knots,".",dec3 knotsRem,"  ",#counts,",","   Knots",13,10]
    serout2  portb.7,396,[ #lbit,"   ",#hbit,13] ' Just send out ADC value to start
    GOTO START:
    I can see the data coming in on the scope. If I move the plunger of the syringe, I get the data changing, but always get a Zero when I send it out to the serial port.
    I havent used the shiftin command before. It looks right so I'm not sure where I am going wrong.
    Any help would be appreciated.
    TIA
    aajgss
    Default Re: Manometer project continued.
    If your data to see on terminal is in the counts variable, you have this line commented out.
    Apr 2011
    NSW, Australia
    Thanks Ioannis,
    I changed it to counts, Unfortunatly no difference, but at least if it was working I wouldn't have seen it anyway. Thanks for the tip.
    I also Added
    ANSELH.2 = 0
    This then worked, however I must say when I read the datasheet for the 18F14K22 I interpret it that it should be digital so it wouldnt be necessary to add this statement so I am a bit confused. Maybe another 40 or 50 reads and it might sink in!!!
    regards
    aajgss
    Apr 2011
    NSW, Australia
    I now have everything working and calculating air speed
    I used "DEC1" to only print out to one decimal point.
    Running the program gave some strange results. On occasion the count would increase, but the Knots value woud reduce.
    By printing out all of the remainder, I could see what was going on.
    eg for 2577 counts, the value would be 110.7 and for 2579 counts the value would be 110.1. The problem being in the true value
    2577 counts is 110.457 and 110.501. The "DEC1" would give the digit either the 1 or 7 and not the 4 or the 5 as I expected (read hoped)
    How can I get the first digit?
    thanks
    aajgss
    What does your code look like now?
    Apr 2011
    NSW, Australia
    Hi Dave,
    Code is attached. Thanks for looking
    DEFINE OSC 12
    ANSELH.2 =0
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    ANSEL =%10000000      ' Enable ADC channel-AN2
    ANSELH =%0000
    OSCCON=%01100000
    TRISA =%00001111                        ' Set ports A3-A2-A1-A0 as inputs
    TRISC =%01001000
    knots var long
    knotsRem var long
    zero var word
    zeroSw var portc.6
    i var byte
    avg var word
    HIGH CS
    START:
    for i = 1 to 10
    LOW CS
    PAUSEUS 150 'delay after CS goes low for conversion to start. Probably not needed
    high cs
    avg = counts + avg
    next
    counts = avg/10
    avg=0
    if zeroSw then  zero = counts                               'Get value at zero pressure
    if zeroSw then high portc.2
    counts = counts -zero  'set zero point
    if counts >65000 then counts= 0                           'in case of underflow
    knots = (((SQR(counts*10000))*65500)/301)/10000
    knotsRem = ((SQR(counts*10000)*65500)/301)//10000
    serout2  portb.7,396,[ #Knots,".",Dec1 knotsRem," Knots   ",#counts,"   ",#zero,10,13]
    GOTO START:
    aajgss
    Try DEC2 then try DEC3 to see what the command does.
    Then take a look at DIG
    4.17.7. DIG
    DIG returns the value of a decimal digit. Simply tell it the digit number (0 - 4 with 0 being the rightmost digit) you would like the value of, and voila.
    B0 = 123 ' Set B0 to 123
    B1 = B0 DIG 1 ' Sets B1 to 2 (digit 1 of 123)
    Add a DIG statement to your code to "pull" the DIGit you want.
    Apr 2011
    NSW, Australia
    Thanks Dave,
    I looked at both as you suggested. These are the results
    Number 40.8914
    DEC2 returns the value 1
    DEC4 RETURNS
    Number 50.143
    Apr 2011
    NSW, Australia
    Hit the end button before finished.
    Results
    DEC 1
    47.6 Knots   686
    46.8 Knots   9598
    46.7 Knots   8727
    46.2 Knots   9162
    47.6 Knots   686
    46.4 Knots   8074
    46.2 Knots   9162
    46.7 Knots   8727
    46.2 Knots   9162
    46.8 Knots   9598
    DEC 2
    46.28 Knots   5028
    46.69 Knots   3069
    46.28 Knots   5028
    46.81 Knots   5681
    46.93 Knots   893
    46.39 Knots   7639
    46.62 Knots   9162
    46.16 Knots   6116
    46.81 Knots   5681
    46.04 Knots   7204
    DIG 1
    43.1 Knots   3910
    42.4 Knots   6946
    43.7 Knots   3475
    43.8 Knots   6086
    44.3 Knots   438
    43.6 Knots   4563
    43.5 Knots   5651
    43.5 Knots   5651
    43.8 Knots   6086
    43.8 Knots   6086
    DIG 2
    49.0 Knots   7016
    49.5 Knots   8539
    49.0 Knots   5058
    49.9 Knots   8975
    50.4 Knots   498
    50.4 Knots   498
    49.0 Knots   5058
    49.4 Knots   7451
    49.6 Knots   4622
    49.0 Knots   5058
    The value before Knots is what is the result of whether I have used DEC 1or 2 and DIG 1 or 2. The value fi=ollowing is the knotsRem variable.
    The DEC1 and 2 seem to make sense, although not displaying the first digit but the DIG 1 and 2 look to return the 2nd digit for DIG1 and 3rd digit for DIG2
    Before I was confused - now I'm way past that!!
    Looking at the manual there doesn't seem to be anywhere that left justifies a number.
    aajgss
        NUM VAR WORD
        NUM = 12345
        NUM_DIG VAR BYTE
        BOOT:
        SEROUT2 TX,BAUD,[$d,$a]
        'RETURNS 12345
        SEROUT2 TX,BAUD,["NUM= ",DEC NUM,$d ,$a]
        'RETURNS 345
        SEROUT2 TX,BAUD,["NUM= ",DEC3 NUM,$d ,$a]
        NUM_DIG = NUM DIG 4 'RETURNS 1
        SEROUT2 TX,BAUD,["NUM_DIG4= ",DEC NUM_DIG,$d ,$a]
        NUM_DIG = NUM DIG 3 'RETURNS 2
        SEROUT2 TX,BAUD,["NUM_DIG3= ",DEC NUM_DIG,$d ,$a]
        NUM_DIG = NUM DIG 2 'RETURNS 3
        SEROUT2 TX,BAUD,["NUM_DIG2= ",DEC NUM_DIG,$d ,$a]
        GOTO BOOT
    Apr 2011
    NSW, Australia
    Hi Dave,
    I think I understand where your heading with this.
    Where I can see a problem with what I am doing is I dont have a constant number of digits in the remainder. It could be 1,2,3 or 4 characters long, So DIG2 would pick the right number if the remainder was in the hundreds, but the wrong number if the result was in the thousands.
    If I remember back to Q Basic days there was a Left$ or Right$ and number of characters command, but I cant see anything like that in PBP.
    Am I seeing this right or not?
    aajgss
    Nope...
    Try something like this.
    IF NUM_REM >= 9999 and <= 1000 THEN
    DIG3 NUM_REM
    IF NUM_REM >= 999 and <= 100 THEN
    DIG2 NUM_REM
    Apr 2011
    NSW, Australia
    Ah Yes,
    A good solution, thanks. Using that method I could also now look at the second digit and if >= 5 round up to the next value.
    aajgss
