Conditional default config's
Results 1 to 11 of 11
    Aug 2010
    Maryland, USA
    Default Conditional default config's
    I wish I could have a define, something like
    DEFINE DCFG 1
    in my program. Then when it compiles, the default configs in the .INC would be skipped. Is this hard to do? I am happy to add an IF Then to my inc's if someone wants to point me at how to pass the variable's to the INC file.
    -Bert
    Default Re: Conditional default config's
    I have not tried it with configs but an include file might work.
    Aug 2010
    Maryland, USA
    I have been trying this:
    ifdef DCFG
      LIST
            __CONFIG    _CONFIG1L, _CPUDIV_NOCLKDIV_1L & _USBDIV_OFF_1L
            __CONFIG    _CONFIG1H, _FOSC_HS_1H & _PLLEN_OFF_1H & _PCLKEN_ON_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
            __CONFIG    _CONFIG2H, _WDTEN_ON_2H & _WDTPS_512_2H
    then in my program
    DEFINE DCFG 1
    the most I can figure is the DEFINE is not being passed to the .INC file. So either it can't , or I just don't know how to do it. I am hoping I just don't know how yet.
    Now I am pretty sure this will always evaluate false as I never get the overwrite error. If i change to
    ifndef DCFG
    I always get the error. So I think the code added to the .INC works, just have no way to pass DCFG
    -Bert
    Bert,
    Comment out the default configs in the .inc file like normal.
    ;*  18F4520.INC                                                 *
    ;*  By        : Leonard Zerman, Jeff Schmoyer                   *
    ;*  Notice    : Copyright (c) 2010 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 05/21/10                                        *
    ;*  Version   : 2.60a                                           *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            "Error: PM does not support this device.  Use MPASM."
            NOLIST
            LIST
            LIST p = 18F4520, r = dec, w = -311, w = -230, f = inhx32
            INCLUDE "P18F4520.INC"   ; MPASM  Header
    ;        __CONFIG    _CONFIG1H, _OSC_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    ;        __CONFIG    _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
    ;        __CONFIG    _CONFIG3H, _CCP2MX_PORTC_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
    ;        __CONFIG    _CONFIG4L,  _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L
            NOLIST
            LIST
    EEPROM_START EQU 0F00000h
    BLOCK_SIZE EQU 32
    Copy the defaults or create your own in a .cfg file like this ...
    18F4520.cfg
      ifndef CONFIGOVERRIDE
    INCLUDE that file from the .bas file
    '*  18F4520.BAS                                                 *
    '*  By        : Leonard Zerman, Jeff Schmoyer                   *
    '*  Notice    : Copyright (c) 2004 microEngineering Labs, Inc.  *
    '*              All Rights Reserved                             *
    '*  Date      : 12/29/04                                        *
    '*  Version   : 2.46                                            *
    '*  Notes     :                                                 *
    BANKA   $0000, $007F
    BANK0   $0080, $00FF
    BANK1   $0100, $01FF
    BANK2   $0200, $02FF
    BANK3   $0300, $03FF
    BANK4   $0400, $04FF
    BANK5   $0500, $05FF
    'EEPROM  $F00000, $F000FF
    LIBRARY "PBPPIC18"
            include "PIC18EXT.BAS"
    PORTL   VAR     PORTB
    PORTH   VAR     PORTC
    TRISL   VAR     TRISB
    TRISH   VAR     TRISC
            include "PBPPIC18.RAM"
            include "18F4520.cfg"
    '*----------------------* EOF 18F4520.BAS *---------------------*
    Then in your main program, you can do what you wanted.
    DEFINE CONFIGOVERRIDE
    HTH,
    Aug 2010
    Maryland, USA
    Thanks Darrel. I suppose that is what Dave was pointing at, but I didn't get it. That will do what I want, (be able to use defaults conditionally). So we CAN pass things to the .BAS just not the .INC?
    Now to refresh the python skills or work on liberty basic and parse the files so I can be lazy and not do it by hand. OK I know it will be far easier to just open the files and change them. But what will I learn that way??
    -Bert
    That is not what I was thinking.
    I did not know
    even existed.
    Thanks Darrel!
    Aug 2010
    Maryland, USA
    Hi Dave,
    I don't think
    DEFINE CONFIGOVERIDE
    is a pre existing anything. I think it could have been
    DEFINE BERTISLAZY
    and have the same effect. In the .CFG file, the
    ifndef CONFIGOVERIDE
    or
    ifndef BERTISLAZY
    tells PBP or MPASM (not clear here) to see if the DEFINE exists. If not then do the following code. If it does exist then endif.
    I am going to have a play with this and verify this is how it works. I will report back if anyone is intrested.
    BTW, the reason I want this is so I can test forum code that uses the default config's, without having to change things all the time for my own code.
    -Bert
    I am interested.
    DEFINE's are currently only passed on to the assembler unchanged, and do not directly affect PBP code.
    Those DEFINES are added to the ASM after the .inc file, but before the .bas file.
    This allows them to affect the library code that is included from the .bas file, but the items in the .inc file have already been processed.
    The example above was for an 18F.
    For a 16F, the .cfg file should be a little different
    ' -- 16F877a.cfg --
      ifndef PM_USED
          __config _XT_OSC & _WDT_ON & _LVP_OFF & _CP_OFF
    The usage in the main program is essentially the same.
    @      __config _HS_OSC & _WDT_ON & _LVP_OFF & _CP_OFF
    A better method has been developed by Charles and Leonard that allows defaults to be overridden automatically, and the new style CONFIG statements to be used in your programs as well.
    It will be available in the coming months, so you may not want to spend to much time editing all the files.
    Hi, Darrel
    Petty good news !!! re-Commenting defaults @ each PBP patch release became a bit boring ...
    Aug 2010
    Maryland, USA
    Oh too cool!!! Does this count as me getting my wish?
    -Bert
