PLEASE HELP...read write issues
Results 1 to 6 of 6
    Feb 2011
    Angry PLEASE HELP...read write issues
    I've been working on this code and im not getting any numbers but a blinking cursor. I want to display the decimal values that i've stored in the eeprom on my lcd screen. I can't figure out if it's the array that is throwing things off.
    MC var byte[4]
    Y var byte
    X = 0
    Data @0, 5, 4, 3, 2, 1 'stores values into EEPROM
    pause 2000 'let lcd start up (2sec wait)
    Loop:
    lcdout $FE, 1, "Program is starting"
    pause 3000
    lcdout $FE, 1
    lcdout $FE, $C0
    for x = 0 to 4
    read x, Mc[x]
    lcdout $FE, dec1 MC[x]
    next x
    lcdout $FE, 1
    lcdout $FE, "End of program"
    pause 3000
    lcdout $FE, 1
    goto loop
    Default Re: PLEASE HELP...read write issues
    Your array is [4] bytes, but you read your array in 0-4, which goes up to 5 bytes. So you either should change your array to 5, or just read 0-3.
    Loveland CO USA
    If you think the LCD is the problem....Have you tried "hello world" to the LCD? Try something very simple first.
    Quote Originally Posted by ronsimpson View Post
    Yeah, . . . I was kind of wondering if it was displaying his other text too.
    Feb 2011
    I get everything else when having text show up on LCD...LCD not the problem
