[REQ] Reading Dip-switches on 628A PortB - Issue on PortB.3 and PortB.4
Results 1 to 7 of 7
    Jan 2006
    North of France
    Question [REQ] Reading Dip-switches on 628A PortB - Issue on PortB.3 and PortB.4
    Hi all.
    I want to finish this very simple PIC 16F628A code but I have a mistake I don't understand :
    What I need is to read the PortB value (0 - 255) but PortB.3 and PortB.4 return zero everytime.
    8 Dipswitches are connected on PortB to VCC and the total value is reported on an serial LCD screen.
    I don't use X-tal and nothing else my LCD is connected on the PIC for the moment except 2 resistors between VCC and PortA.2 / PortA.3 for a future I2C use.
    My serial transmission is okay @9600 without X-tal and my issue is not there.
    I try since 3 days and now all my hairs are on the floor ;O)
    I think I need something to add in the head of the code but what ?
    Any help is welcome.
    Thanx a lot and cheers from France.
    Here is my code :
    @ device PIC16F628A, INTRC_OSC_NOCLKOUT, wdt_off, pwrt_on, mclr_off, protect_off 'Utilisable avec PM
    Include "modedefs.bas"         ' Mode definitions for Serout
            CMCON    = 7           ' Turn OFF all analog features, all is now digital
    ;        VRCON    = 0          ' Disable A/D Voltage reference, I don't need that in this code
    ;        INTCON.7 = 0          ' Disable interrupts, I don't need that in this code
            Define OSC        4    ' Set Xtal Frequency
    	DEFINE I2C_SCLOUT 1    ' I'll use I2C communication
            Clear
            TRISA = 0              ' All Port A output
            TRISB = 255            ' All PortB input
        	LOW PORTA		           '
            SYMBOL SDA           = PORTA.2     ' I2C SDA (R 10k to VCC)
            SYMBOL SCL           = PORTA.3     ' I2C SCL (R 10K to VCC)
            SYMBOL DIP1          = PORTB.0
            SYMBOL DIP2          = PORTB.1
            SYMBOL DIP3          = PORTB.2
            SYMBOL DIP4          = PORTB.3
            SYMBOL DIP5          = PORTB.4
            SYMBOL DIP6          = PORTB.5
            SYMBOL DIP7          = PORTB.6
            SYMBOL DIP8          = PORTB.7
            LCDPIN             Var PORTA.1     ' Serial LCD
            ADDR1              VAR BYTE
            ADDR1                = $C2         ' Fixed I2C address for PLL 5055
            PLLBASE            VAR WORD
            TMP                VAR WORD
            PLL                VAR WORD
            PLLLO              VAR PLL.LOWBYTE
            PLLHI              VAR PLL.HIGHBYTE
            FMHZ	           var WORD
            FKHZ	           var WORD
            PLLBASE              = 19200       ' Lowest freq
            BAUDRATE            CON N9600      ' For use with LCD
            pause 1000                         ' wait for the LCD to startup
    MAIN:
         TMP = PORTB * 2
         PLL = PLLBASE + TMP
         I2CWrite SDA,SCL,ADDR1,[PLLHI,PLLLO,$8E]          ' send command to PLL
         Serout LCDPIN, BAUDRATE,[12]                      ' Clear screen
         Serout LCDPIN, BAUDRATE,["PortB= ", #PORTB]       ' Print PortB value (0-255)
         Pause 1000
    GoTo MAIN
    Default Re: [REQ] Reading Dip-switches on 628A PortB - Issue on PortB.3 and PortB.4
    OPTION_REG.7 = 0 'enable pullups
    Jan 2006
    North of France
    Unhappy Re: [REQ] Reading Dip-switches on 628A PortB - Issue on PortB.3 and PortB.4
    Wow, you are right Dick, with this line, my code work better cause changes on dipswitches are immediately detected.
    Thanx for your eye of the tiger :O)
    But... PortB.3 and PortB.4 seems to be always unconnected.
    I replaced my PIC628A by another one to check if these 2 pins were died and I have the same issue with a new PIC.
    Not solved.
    Connect the dip switches to GND not Vcc
    Enable portb pullups
    yourvar var byte
    yourvar = portb
    yourvar ^ %11111111 'invert all 8 bits of the variable
    'send the decimal value of yourvar to LCD screen
    Jan 2006
    North of France
    Thumbs up Re: [REQ] Reading Dip-switches on 628A PortB - Issue on PortB.3 and PortB.4
    Quote Originally Posted by Dick Ivers View Post
    yourvar var byte
    yourvar = portb
    Hi Dick,
    I did what you said and now, it works like the 1st time, my switches aren't inverted and I have to connect to GND a pin to see its value. With the first mod you gave me, all was inverted and VCC had to be used but it was not a problem for me.
    With this small piece of code, I've learned a lot of things but I already have my PortB.3 and my PortB.4 returning every time a zero.
    Well... You'll think I'm stupid... I've checked all the hardware, my PIC is not directly connected, there is a DIL support under and I've found this DIL support is defective and have no connection on 2 pins !!!
    Yes, it was a hardware error ! Arrrgh.
    Your help was really useful, now I know how to have simple pull-ups how to invert bits variable and with this both tips, how to make a pull-down it's better for my PCB.
    Thanx a lot, this file is now closed for me.
    Aug 2010
    Maryland, USA
    Quote Originally Posted by RCtech View Post
    NEVER happens in a SIM!!!
    RC that is not at you, but to support the SIM guys!!
    -Bert
    NEVER happens in a SIM!!!..
