Pentax IR Remote
Results 1 to 24 of 24
    Feb 2005
    Default Pentax IR Remote
    I want to make an infrared remote for the new pentax cameras for doing timelapses, as any timelapse shooter it involves triggering a IR sequence every X amount of time. The interval part is pretty straightforward, I want a little help regarding the IR sequence.
    Here is the required pulse train:
    What would be the best way to send this thru a pic 12F683 pin? First I tought about using PWM or HPWM but these are limited to 32Khz
    Thanks in advance!
    Pablo
    Feb 2005
    This is what I got so far, I need to test it tomorrow with a camera, in simulation it looks OK, but I'm open to suggestions for improvement.
    I need to code the operator input side of the program where the user selects with a pot the interval, now it just triggers once a second
    '*  Name    : pentax.BAS                                        *
    '*  Author  : PEU based on examples from www.rentron.com        *
    '*  Notice  : Copyleft (c) 2011                                 *
    '*          : No Rights Reserved on derived work                *
    '*  Date    : 04-Jan-11                                         *
    @ #define IRTX GPIO  ; Define port to use for IR out
    @ #define PIN 2      ; Define port pin to use for IR out
    @ device pic12f683,INTRC_OSC_NOCLKOUT , wdt_on, mclr_off, protect_off
      GPIO.2 = 1       ' IR LED off   -----|<|----/\/\/\----+5
      TRISIO.2 = 0     ' Output for IR signal
      CMCON0 = 7        ' Comparators disabled
      ANSEL = 0        ' A/D disabled
    ' IR carrier generator routines. Freq.inc.
      Cycles VAR BYTE    ' Number of carrier cycles
      PAUSE 100
      GOTO OverFreq  ' jump over pulse routines
    ' Generate "Cycles" number of ~38.4kHz pulses
    _Pulse38
       bcf IRTX,PIN     ; 1uS, LED=on
       goto $+1         ; + 2uS = 3uS
       goto $+1         ; + 2uS = 5uS
       goto $+1         ; + 2uS = 7uS
       goto $+1         ; + 2uS = 9uS
       goto $+1         ; + 2uS = 11uS
       goto $+1         ; + 2uS = 13uS
       bsf IRTX,PIN     ; 1uS, LED=on
       nop              ; + 1uS = 10uS
       decfsz _Cycles,f ; + 1uS = 11S
       goto _Pulse38    ; + 2uS = 13uS
       return           ; Return to caller
    OverFreq:
        sleep 1 'sleep one second
        gosub trigger 'send trigger pulse
      GOTO Main
    Trigger:            'generate pentax trigger pulse
      Cycles = 255
      CALL Pulse38
      Cycles = 244
      CALL Pulse38
      pauseus 3000
      cycles = 37
      CALL Pulse38
      pauseus 1000
      cycles = 37
      CALL Pulse38
      pauseus 1000
      cycles = 37
      CALL Pulse38
      pauseus 1000
      cycles = 37
      CALL Pulse38
      pauseus 1000
      cycles = 37
      CALL Pulse38
      pauseus 1000
      cycles = 37
      CALL Pulse38
      pauseus 1000
      cycles = 37
      CALL Pulse38
      pauseus 5000        'end of stream
    Dec 2008
    Ploiesti, ROMANIA
    Or You can try something like this :
    @ device  pic12F683, XT_OSC, wdt_off, pwrt_on, mclr_off, protect_off, bod_off
    INCLUDE "MODEDEFS.BAS"
    GPIO      =       %00111011
    TRISIO    =       %00111011  ' ATTENTION !!!
    CCP1CON   =       %00001100  ' Mode select = PWM
    T2CON     =       %00000100  ' Timer2 ON + 1:1 prescale
    PR2       =       %00011001  ' Set PWM frequency to 39kHz
    ANSEL     =       %00000000
    CMCON0    =       %00000111
    but1 	var GPIO.0
    ; gpio.2 is CCPR1L
    CCPR1L = 0
    i	var byte
    if but1=1 then  do_command
    do_command:
    	CCPR1L=8
            pauseus 1300
    	CCPR1L=0
            pauseus 300
    for i=1 to 7
    	CCPR1L=8
            pauseus 100
    	CCPR1L=0
    	pauseus 100
    next i
    PAUSE 500
    Goto Main
    Feb 2005
    The code I posted had the duty cycle inverted, just modified the assembly routine (swapped BSF & BCF) and it works, just tested it with my pentax Kx. Im happy
    fratello: tested your code but it does not work, then I simulated it and the pulsetrain was very noisy maybe thats the cause.
    Here is the modified code:
    '*  Notes   : pablou at gmail dot com                           *
      PAUSE 100
    _Pulse38
       nop              ; + 1uS = 10uS
    OverFreq:
      GOTO Main
      Cycles = 255
      CALL Pulse38
      Cycles = 244
      CALL Pulse38
      pauseus 3000
      cycles = 37
      CALL Pulse38
      pauseus 1000
      cycles = 37
      CALL Pulse38
      pauseus 1000
      cycles = 37
      CALL Pulse38
      pauseus 1000
      cycles = 37
      CALL Pulse38
      pauseus 1000
      cycles = 37
      CALL Pulse38
      pauseus 1000
      cycles = 37
      CALL Pulse38
      pauseus 1000
      cycles = 37
      CALL Pulse38
    Actually - it should work either way, but your last version will be leaving the IR LED ON if the cathode is connected to GPIO.2.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2005
    You are right, I left it again the way you coded it and it works the same
    Thanks for the example BTW, without it I would be lost.
    I finished the full timelapse+remote code but Im keeping it to myself at this moment, the code I posted and a little thinking will serve as the foundation to do any remote trigger operation with Pentax cameras.
    Happy 2011
    Glad I could help, but I would like to see you share what you have. Unless, of course, it's something you plan to sell as a product.
    What goes around - comes around, and the folks you help along your way never seem to forget you..
    -Bruce
    tech at rentron.com
    Feb 2005
    Bruce, you are right again.
    After thinking about... lets say 2 minutes here is the code, I hope you and everyone else help me to make it better, there are a couple of things that can be improved for sure.
    Good thing about it is that you change the pulse train and bingo timelapse remote for another brand, or even better, add a dipswitch and make the remote multibrand.
    '*  Date    : 05-ENE-11                                         *
    '*  Version : 1.02                                               *
    @ device pic12f683,INTRC_OSC_NOCLKOUT , wdt_on, mclr_off, protect_on
      GPIO = 0
      TRISIO.2 = 0      ' LED IR
      TRISIO.1 = 0      ' LED testigo
      TRISIO.5 = 1      ' Input para interruptor normal abierto (con pulldown)
      CMCON0   = 7      ' Comparadores deshabilitados
      ANSEL = 0         ' A/D deshabilitado
      GIE       VAR INTCON.7  ' Global interrupt enable 1=ON, 0=OFF
      GPIE      VAR INTCON.3  ' Port change interrupt enable 1=ON, 0=OFF
      GPIF      VAR INTCON.0  ' Port Change Interrupt Flag bit
      ContaSec  var word    ' Contador de segundos
      TLFlag    var byte    ' Se programo el contador?
      IRLED     var GPIO.2  ' alias LED IR
      LED       var GPIO.1  ' alias LED testigo
      BOTON     var GPIO.5
      GIE = 0            ' Disable global ints
      GPIE = 1           ' Enable port change int
      IOC.5 = 0          ' Int-on-change for GPIO.5 disbled
      PAUSE 100         ' Pausita pa estabilizar todo al arranque
    ' Generate "Cycles" number of ~38.4kHz pulses   Bruce at www.rentron.com
    _Pulse38
       nop              ; + 1uS = 10uS
    OverFreq:
    contasec=0
    tlflag=0
    'Si el micro arranca con el boton apretado contar segundos
    while boton=1
    contasec = contasec + 1
    high led
    pause 50
    low led
    pause 950
    tlflag=1
    wend
    contasec = contasec - 1 ' descontar un segundo, algun dia mejorare la rutina
    'Loop del TimeLapse
    if tlflag = 1 then
        while boton = 0
            sleep contasec  ' dormir por el tiempo programado
            gosub trigger   ' disparar
            high led        ' prende LED testigo
            pause 50        ' sisi agrega 50ms, no me calienta en lo mas minimo :)
            low led         ' apaga LED testigo
        wend
    ' Se acabo el timelapse porque se apreto el boton
        for contasec = 1 to 15  ' avisarle al usuario parpadeando el LED testigo
            high led
            low led
        next
      IOC.5 = 1          ' Int-on-change for GPIO.5 enabled
      GPIO = 0
      Main:                 ' Loop principal
        @sleep              ' Dormir
        while boton=0       ' Mientras no se aprete el boton no dejar pasar
        wend
        GPIF = 0           ' Clear port change interrupt flag
        gosub trigger       ' Disparar
        pause 50
      GOTO Main
    Trigger:                ' Generar el pulso de disparo PENTAX
      Cycles = 255
      CALL Pulse38
      Cycles = 239
      CALL Pulse38
      pauseus 3000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 5000              ' Fin del tren de pulsos PENTAX
      END                       ' Fin
    Sorry for spanish comments, google translate is your friend
    Pablo
    Feb 2005
    Feb 2005
    add resistors for LED, not included in schematic (and neither in my protoboard ) and a transistor for more IR range, measured 387 microampere in the main loop while in sleep and 8mA while triggering, can it be made to consume even less in case the switch is left on?
    Feb 2005
    Current version instructions:
    to enable timelapse function press pushbutton while powering ON the remote, the red led will flash each second passed, once you release the pushbutton this will be the interval time.
    to exit the timelapse mode, just press the pushbutton longer than the intervall, once out of the mode the red led will flash briefly.
    After exiting timelapse mode, if you press the pushbutton momentarily it will trigger once, if you keep it pressed it will trigger continuously.
    if you start the remote without the pushbutton pressed it will work like previous paragraph.
    While I was driving home I had an idea, why not add 2 more pushbuttons to easily have longer periods, one can be x10 seconds and the other minutes. And then, when outside the timelapse function these buttons can be programmed to trigger a certain amount of photos in a row, say for example 3 photos and 6 photos or any combination that can be programmed.
    Nifty project. Could even use a serial LCD and have a boat-load of options with a menu.
    -Bruce
    tech at rentron.com
    Speaking of intervalometers, did you see the one at http://www.doc-diy.net/photo/hdr-jack/#thecircuit ?
    It uses an atmel and is meant for a Canon, but the design is ingenious.
    Or this: http://cms.diodenring.de/en/electron...tervalltimerv2 ; based on 10F222, works with Canon, Nikon & the newer Pentaxs.
    Planning to build one for my Canon 500D...
    Anand
    Feb 2005
    Anand
    I started with a Canon A570is and CHDK but wanted to use the DSLR for its many advantages, built the diodenring timelapse but my brand new pentax K-x does not have the 2.5mm jack as my previous pentax K-100, stupid me I realized this AFTER building it so the only choice left was to build it using the IR sensor. Crossed many mails with Achim (from diodenring) he is a helpfull guy.
    Regarding the HDR-jack I think this can also be implemented via IR, but not looked into it yet.
    Regarding the program in this thread, I know the timing loop at the begining can be improved using a better way to count time. I could use some help there
    Pablo
    Quote Originally Posted by peu View Post
    Darrel has some great interrupt include files. It makes it pretty easy to do some great things with interrupts, and they can be very efficient as well. Here is a link to a timer example of his. http://darreltaylor.com/DT_INTS-14/elapsed.html
    http://www.scalerobotics.com
    Feb 2005
    interesting, never looked deeply into them, now that I did I have some warnings at compile time, maybe you can help me
    PIC12F683
    pbp 2.60b
    latest mapsm from MPLAB IDE v8.63
    Downloaded ReEnterPBP.bas and DT_INTS-14.bas from Darrel Site and placed at pbpw folder
    And Im trying the example you linked (http://darreltaylor.com/DT_INTS-14/elapsed.html)
    this example requires Elapsed_INT.bas which I found in this thread: http://www.picbasic.co.uk/forum/show...7473#post17473 also placed it at pbpw folder. Is this the current version?
    when I compile the example (using MPASM from microcodestudio) I get these errors:
    Warning[219] C:\progra~1\picbas~1\pbppic14.lib 2934 : Invalid RAM location specified.
    Warning[219] C:\progra~1\picbas~1\pbppic14.lib 2939 : Invalid RAM location specified.
    Warning[219] C:\progra~1\picbas~1\pbppic14.lib 3059 : Invalid RAM location specified.
    Warning[219] C:\progra~1\picbas~1\pbppic14.lib 3075 : Invalid RAM location specified.
    What Im doing wrong?
    Feb 2005
    the problem was the LCDOUT, doh! back to learning this interesting interrupt stuff
    Feb 2005
    Added the timer as suggested and it works! BUT, now I lost two things and I don't know why:
    1) the led thats supposed to flash once a second inside the time counting loop only flashes once.
    2) When outside the timelapse function in the previous version if I left the button pressed the camera shooted continuously, now it shots one time per press
    As a BONUS I translated all the comments to English
    '*  Version : 1.01                                               *
    ' 12F683.INC at picbasic folder has this defined already for MPASM use
    ' __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_ON
    '@ device pic12f683,INTRC_OSC_NOCLKOUT , wdt_on, mclr_off, protect_on
    INCLUDE "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas"
    INCLUDE "Elapsed_INT.bas"  ; Elapsed Timer Routines  by Darrel Taylor
      GPIO = 0
      TRISIO.1 = 0      ' Red LED
      TRISIO.5 = 1      ' Normal open pushbutton (w/ pulldown)
    '  GIE       VAR INTCON.7  ' Global interrupt enable 1=ON, 0=OFF
      ContaSec  var word    ' Seconds Counter
      TLFlag    var byte    ' Timelapse counter programmed?
      LED       var GPIO.1  ' alias red LED
      BOTON     var GPIO.5  ' pushbutton
      PAUSE 100          ' little pause to settle the processor after cold start
    GOTO OverASM     ' jump over ASM routines
    _Pulse38
       nop              ; + 1uS = 10uS
            INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
        INT_ENABLE  TMR1_INT  ; Enable Timer 1 Interrupts
    OverASM:    ' END of ASM routines
    contasec=0
    tlflag=0
    ' New timer
    GOSUB ResetTime           ' Reset Time to  0d-00:00:00.00
    GOSUB StartTimer          ' Start the Elapsed Timer
    while boton = 1           ' Loops while the button is pressed
            if SecondsChanged = 1 then 'if the seconds changed flash the red led
            high led
            pause 50
            low led
            SecondsChanged = 0      ' set flag back to 0
        tlflag=1                    ' This flags lets me know if the timer was used
    wend
    contasec = Seconds + (Minutes * 60) ' Total time elapsed
    gosub StopTimer
    'Loop del TimeLapse
    if tlflag = 1 then              ' if the timer was used continue
        while boton = 0
            sleep contasec  ' sleep programmed time
            gosub trigger   ' trigger
            high led        ' red LED on
            pause 50        ' little pause
            low led         ' red LED off
        wend
    ' Timelapse ended because the button was pushed
        for contasec = 1 to 15  ' flash red LED to let the user know
            high led
            low led
        next
      GPIO = 0
      Main:                 ' main Loop
        sleep              ; Sleep
       endasm
        while boton=0       ' wait for button push
        wend
        pause 50
        pause 200           ' debounce
      GOTO Main
    Trigger:                ' PENTAX pulse train
      Cycles = 255
      CALL Pulse38
      Cycles = 239
      CALL Pulse38
      pauseus 3000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 5000              ' end PENTAX pulse train
      END                       ' Fin   :)
    Feb 2005
    While debugging the firmware I took so many pictures that I decided to make a timelapse out of them
    Enjoy in 1080p
    Feb 2005
    Solved the trigger by holding button, ingenuity works
    I still can't figure out why the led does not blink while counting time at the first while wend
    And I noticed the ASM SLEEP does not work, consumption is the same (0.4mA) regardless I use it or comment it out. I replaced @ sleep with ASM SLEEP ENDASM to compile with MPASM do I need to add something else?
    changed code:
    '*  Version : 1.10                                              *
      GPIO = 0
    _Pulse38
       nop                  ; + 1uS = 10uS
    INT_LIST  macro         ; IntSource,        Label,  Type, ResetFlag?
        INT_CREATE          ; Creates the interrupt processor
    contasec=0
    tlflag=0
                            ' New timer
                high led
                pause 50      'should blink once a second but it doesn't
                low led
    wend
    gosub StopTimer
    'Loop del TimeLapse
        while boton = 0
        wend
            high led
            low led
        next
    GPIO = 0
    Main:                   ' main Loop
        SLEEP               ; Sleep
      endasm
      wend
      while boton=1         ' shoot while pressed
        high led            ' blink red LED
        pause 50
        low led
      wend
    GOTO Main
      Cycles = 255
      CALL Pulse38
      Cycles = 239
      CALL Pulse38
      pauseus 3000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      END                   ' Fin   :)
    Feb 2005
    Here is version 2 of the PENTAX / NIKON IR remote, yes, I added Nikon support, needs to be tested with a Nikon camera as I don't have one.
    Removed Darrel's Instant Interrupt elapsed timer because I was unable to make it work, also polished the code a little. As previous versions there is room for improvements, I hope someone else is interested in making it even better.
    The device while sleeping uses only one microampere, so its suitable to be used with a button 3v 2032 battery.
    You can add a second pushbutton but normally closed for power supply to briefly reset the remote to use it for timelapses again.[edit] or enable MCLR and use a normal pushbutton conecting pin 4 to GND and a 10k pull up resistor to VDD.
    Attached is the HEX file for 12F683
    '*  Notice  : Pablo E. Untroib (c) 2011                         *
    '*          : Free for personal use
    '*  Date    : 11-ENE-11                                         *
    '*  Version : 2.10                                              *
    '*          : Consumption while sleeping is 1 microamper        *
    @ DEVICE PIC12F683,INTRC_OSC_NOCLKOUT,WDT_ON,MCLR_OFF,BOD_OFF,PWRT_OFF
    @ #define PIN 2         ; IR LED output GND---/\/\/\---|<|--GPIO.2
    define OSC 4            ' Defines oscilator frequency
    'DEFINE DEBUG_REG GPIO  ' used at debug time
    'DEFINE DEBUG_BIT 4
    'DEFINE DEBUG_BAUD 2400
    LED       VAR GPIO.1    ' LED output GND---/\/\/\---|<|--GPIO.1
    ContaMili var byte      ' Miliseconds Counter
    BOTON     var GPIO.5    ' Key input (10K pull-UP w/switch to ground)
    CMCON0 = 7              ' All digital
    GPIO   = 0              ' Clear port on boot
    TRISIO = %00100000      ' GPIO.5 input, rest outputs
    _Pulse38
       nop                  ; + 1uS = 10uS
    contasec  = 0
    ContaMili = 0
    tlflag    = 0
    while boton = 0             ' Loops while the button is pressed
        contamili = contamili + 1
        if contamili = 8 then   ' I count 0 to 8 so I can flash the LED 100ms
            contamili = 0
            contasec=contasec + 1
            high led
            low led
    wend
    ' this is needed because the SLEEP takes about 2.3 seconds to react
    ' see SLEEP description in PBP manual
    if contasec > 2 then
        contasec = contasec - 2
    pause 1000              ' debounce pushbutton
    'Loop del TimeLapse
        while boton = 1
        wend
    WDTCON = 0              ' Disable WDT when not needed for power savings
        for contasec = 1 to 5
            high led        ' flash red LED to let the user know timelapse ended
            low led
        next
    ' Main loop works as a normal remote,
    ' one push triggers, hold pushbutton triggers continuously
        @ SLEEP             ' SLEEP until Key is pressed
        WHILE Boton = 0       ' Wait for Key release
        gosub trigger
        high led
        pause 200
        WEND
        low led
    GOTO Main
    Trigger:                ' PENTAX pulse train begins
      Cycles = 255
      CALL Pulse38
      Cycles = 239
      CALL Pulse38
      pauseus 3000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 1000
      cycles = 38
      CALL Pulse38
      pauseus 2000          ' end PENTAX pulse train with 2ms pause
      Cycles = 76           ' NIKON pulse train begins
      CALL Pulse38
      pauseus 28000
      cycles = 15
      CALL Pulse38
      pauseus 1580
      cycles = 15
      CALL Pulse38
      pauseus 3580
      cycles = 15
      CALL Pulse38
      pauseus 63200
      Cycles = 76
      CALL Pulse38
      pauseus 28000
      cycles = 15
      CALL Pulse38
      pauseus 1580
      cycles = 15
      CALL Pulse38
      pauseus 3580
      cycles = 15
      CALL Pulse38
      pauseus 2000          ' end NIKON pulse train with 2ms pause
    Instructions:
    Feb 2005
    Routing and Drilling the PCBs
    Nice!!!!
    Default Double clock and use HPWM
    I did a similar camera control several years back. I used HPWM which will go to 38+KHz if you define the oscillator as one value then load a crystal of twice that value.
    For example
    DEFINE OSC 10 but in practice load a 20 MHz crystal.
    HPWM 1, 127, 19400
    That shags all your other timings so it can get tricky with other delays and serial in/out but it works for me.
    HTH
    BrianT
