Hello Everyone,
I am trying out FL IDE and get the same thing as in this FL1_6_0_0.pdf. The Code compiles fine inn the MCSEX IDE.
Hello Everyone,
CharlieM
Using PBP3
MCSPX
Hi Norm,
From what I can tell the paths are correct. The Path is C:\Users\Charlie\ Documents\PBP Projects. The project compiles fine using MCS.
CharlieM
Using PBP3
MCSPX
It's there but its called test.er instead of test.err
CharlieM
Using PBP3
MCSPX
Coming soon: FineLineIDE Code Collapse and AutoIndent!
The most requested feature Code Collapse and perfectly indented code "as you type" should be ready this month (May 2012)!
FL 2.0 is now in Beta.
Norm
Thank you. In fact and always i tried on an other computer i encountered the same problem( file corrupted wrong CRC..). I could obtain same in downloading the file "FineLineIDE.php?action=download1" which is the short cut for download with the help of a downloader, i renamed it in . rar and finally obtained the good file. What is the mystery??
Anyhow thank you again.
Thanks for writing such a nice editor, Norm.
I'm seeing this behavior with 2.0.0.0:
Source path is C:\Users\dlkerl\picstuff\oven
The path is identical in the error message, but the file name in the source directory only has one 'R': OVEN_V0_3.ER (empty file)
MCS launches PBP with no problems (PBP 2.45)
Unrelated question: Is it possible to stop automatic indentation of labels in ASM blocks?
Thanks-Dan
Hey Norm,
Could you make available the pre PBP3 version of FineLine. I am still having trouble on machines that do not have PBP3 with the current FineLine.
I have added an Archives Page.
See FineLineIDE.
Email me the trouble you are having.
I am presently at pre beta 2.1.0.0 and this would be a good time to do fixes.
Norm
Thanks Norm,
The problem is the same as mentioned in post #112 of this thread and if I recall correctly in another thread. When you added support for PBP3 older versions without the registration code from MeLabs does not work. The screen shot in post #112 is typical.
Sooner or later everyone will be updated... but in my case I have more than three machines with PBP and I really do not want to pay the fee multiple times. So I am still using PBP2.6x on a few.
Thank you for the program, upon start up i receive an access violation, it is probably because i have denied it access to the internet, can you tell me please why it calls home.
The .ER file is the PBP compiler text to assy error file.
The .ERR file is the MPSAM assy to hex error file.
Possibly the "Users" in C:\Users\dlkerl\picstuff\oven is throwing FL off?
Try compiling with your program file in a non Users directory.
Yes I should be able to disable all auto indent of assy lines if that would be best?
Anyone familiar with assy please advise.
I am presently finishing up the pre beta of FL 2.1.0.0 with several fixes.
Norm
