Finding variables in RAM
Results 1 to 5 of 5
    Sep 2005
    Campbell, CA
    Default Finding variables in RAM
    I need to pass large arrays between PBP and ASM - larger than the BANKA limit. If I define an array in PBP, what is the best way to find the start location (in RAM) of that array in ASM? I'm using an 18F8723.
    Charles Linquist
    Sep 2005
    Campbell, CA
    I guess another question could be - does CH?RP work for RAM variables?
    Charles Linquist
    Sep 2005
    Campbell, CA
    I ran a test. It does. Problem solved.
    Charles Linquist
    Charles,
    Since you are using an 18F. You might want to use the FSR's and the LFSR instruction to access your arrays.
      LFSR  FSR0, _MyArray
      MOVF  _Idx, W
      MOVFF PLUSW0, _Destination
    Sep 2005
    Campbell, CA
    Thank you Darrel. I'll try it tomorrow.
    Charles Linquist
