Help interface BenQ GSM Modem to IC16F62A
Results 1 to 6 of 6
Threaded View
    Oct 2008
    Default Help interface BenQ GSM Modem to IC16F62A
    I got a BenQ Gsm Modem, so far I got it running sending AT commands from PC to GSM module via hyperterminal using USB to serial converter. The GSM module is operates in 3.3v, Pic16F628A on 5v.
    Questions:
    1.] Obviously I going to need a voltage divider between the module and PIC, but how can I or can Imake Pic16F628A operate on a 3.3v, based on the datasheet in can operates 2.0-5.5v
    2.] I want to try using the following setup connection(refer to the attach image) and the code below..
    Include "modedefs.bas"	' Include serial modes
    'Definitions
    DEFINE OSC 4			'for 4 Mhz
    'DEFINE OSC 8			'for 8 Mhz
    DEFINE HSER_TXSTA 20h	'hardware assign
    DEFINE HSER_RCSTA 90h	'
    DEFINE HSER_BAUD 9600	'for 9600 Baud rate
    DEFINE HSER_SPBRG 12	'
    DEFINE HSER_CLROERR 1	'
    TRISB=%00000000
    PORTB=%00000000
    ' Send signal tp PWON
        HIGH PORTB.7
        PAUSE 500
        Low PORTB.7
        PAUSE 3000
    start:
    HSEROUT ["AT",13]                    'Send AT to modem followed by a CR
    HSERIN 5000, start, [WAIT("OK")] ' wait 5sec to reply.
    PAUSE 1000
    goto start
    Where it simply waits for 'OK'. Can I use PortC.6 (with max232) to COM Port at the same time?
    thanks,
    mbox
