TOTAL = TEMP
THOU = TOTAL/1000
TOTAL = TOTAL//1000
HUNS = TOTAL/100
TOTAL = TOTAL//100
TENS = TOTAL/10
ones = TOTAL//10
'SEVEN SEG LOOKUP
LookUp ONES,[124,72,61,109,75,103,119,76,127,111],LCD_ONES
LookUp TENS,[124,72,61,109,75,103,119,76,127,111],LCD_TENS
LookUp HUNS,[124,72,61,109,75,103,119,76,127,111],LCD_HUNS
LookUp THOU,[124,72,61,109,75,103,119,76,127,111],LCD_THOU
If Temp < 1000 then LCD_THOU = 0 'Suppress leading zeros
If Temp < 100 then LCD_HUNS = 0
If Temp < 10 then LCD_TENS = 0
'PORTB.0 = DATA
'PORTB.1 = CLOCK
'PORTB.2 = LOAD DATA
PORTB.2 =0 'LOAD DATA AY0438
ShiftOut PORTB.0,PORTB.1,0,[LCD_ONES,LCD_TENS,LCD_HUNS3,LCD_THOU] 'SEND 4 BYTES
PORTB.2 =1 'Latch DATA
Below is from your code I used the calculator in windows accessories to convert
the hex to decimal for the above Lookup statements
' RETLW 0x7e = 0 124
' RETLW 0x48 = 1 72
' RETLW 0x3D = 2 61
' RETLW 0x6D = 3 109
' RETLW 0x4B = 4 75
' RETLW 0x67 = 5 103
' RETLW 0x77 = 6 119
' RETLW 0x4C = 7 76
' RETLW 0x7F = 8 127
' RETLW 0x6F = 9 111
