Can i measure 2 secs with pulsin?
Results 1 to 12 of 12
    Feb 2010
    Default Can i measure 2 secs with pulsin?
    just like that, Can I measure 2 seconds with pulsin? or what is the max value that i can store in a variable with pulsin?
    what i want to do is, hold a button just when i turn on the pic, and if the button is 2 seconds-hold or more do something
    And another question,
    if i want to store more tan one byte with serin this will work?
    serin porta.1,N2400,["A"], var1, var2, var3 'for 3 vars???
    California, USA
    No, 2 seconds is too long for pulsin.
    According to the manual:
    "The resolution of PULSIN is dependent upon the oscillator frequency. If a 4MHz oscillator is used, the pulse width is returned in 10us increments. If a 20MHz oscillator is used, the pulse width will have a 2us resolution. "
    Since the pulsin will return a WORD, the max pulse length is 65535 x 10uS (for a 4MHz clock) which is only 0.655 seconds.
    For a 20MHz osc it would only be 0.131 seconds.
    steve
    Feb 2010
    thanks steve, can you tell me how i can measure a 2 seconds button-pressed?
    I'll give you a hint... how many 1/2 seconds in 2 seconds? How many 1/10 of a second in 2 seconds? That's if you want to do it in the "foreground"... hmmm...
    MyVar = 0 ' zero on entry
    WHILE INPUTPIN = desired state
    PAUSE 500 ' 1/2 second delay
    MyVar = MyVar +1
    WEND
    When it exits just check the value in MyVar.
    Yep.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2007
    USA, CA
    Quote Originally Posted by Byte_Butcher View Post
    steve
    And what would be the problem with using a 1MHz clock?
    YES--Of COURSE you can use Pulsin for a 2 second pulse! Most PIC's have internal clocks that are capable of it. Heck, if you need a faster clock for other stuff, just slow down (i.e. change osccon) right before the pulsin and put it back after.
    California, USA
    Quote Originally Posted by tenaja View Post
    Well heck... I never thought of just slowing the clock down for the pulsin measurement!
    Good idea!
    steve
    Feb 2010
    Thanks a lot Bruce and Tenaja, both ideas are great. Will tray both
    Bruce one thing, your while...wend statemet, will be a inifinite loop if I left the button pressed, doesn't? I did the next code, will work?
            if PORTA.0 = 1 THEN
            PAUSE 2000
            if PORTA.0 = 1 THEN
            gosub PROGRAMAR
    Feb 2010
    Tenaja there is a problem, when i code this:
          OPTION_REG = $07
          ANSEL      = $00     'para hacer funcionar todas las E/S como digitales
          TRISA      = $07     'Configura PORTA <5:3> salidas y PORTA <2:0> salidas
          TRISC      = $00     'Configura PORTC <5:0> todas salidas
          INTCON     = $00     'Interrupciones deshabilitadas
          OSCCON     = $47     'Oscilador 8MHz
          DEFINE OSC 1         '8MHz
    inicio:
          pulsout PORTC.5,25000
          goto inicio
    i get an Error:
    Error c:\picmicro\mcstud~1\pbp246\pbppic14.lib 6152 : [255] Unidefined Sybol 'PAUSEUSL'
    looking in pbppic14.lib it seems that the lowest frecuency that can be handled by PBP is 3.58MHz, but pic16f684 can handle since frecuency from 31KHz.
    But inclusive having that error I sumulate the HEX, and works, my question is, this error will give me headache????
    --EDIT--
    I took away the line
    DEFINE OSC 1 'for 1MHz oscillator
    and code was compiled just fine, the only thing is that PAUSE increments are bigger
    with DEFINE OSC 1
    PAUSE 100 'has a duration of 5mS
    without DEFINE OSC 1
    PAUSE 100 'has a duration of 400mS
    Wink
    For pulsin,
    You also can play with the internal oscillator ... if your chip, like the 16F88 has a configurable internal osc ...
    use the " classic " 4 or 8 Mhz speed, and switch, on the fly, to 31 Khz or 125 Khz ... just changing osccon IRCF bits, when needed ...
    note the BUTTON command can be configured to have a 250ms debounce time ( DEFINEs ...) ... 8 x 250 ms make 2 seconds.
    which is much, much simpler !!! ( matches Bruce's idea ...)
    Feb 2010
    Acetronics,
    i really don't understand very well how it's works BUTTON, but, it will work if I use BUTTON just when PIC is turned on.
    By example the following flow,
    1. turn on PIC and if button is pressed 2 seconds GOTO X, or
    2. turn on PIC and if button is not pressed run normally.
    Wink
    Hi, Lugo
    let's suppose your button B is active LOW
    DEFINE BUTTON_PAUSE 250
    FOR I = 1 to 8
       Delay = 0                                ' reset check time
       BUTTON B,0,255,0,Delay,1, Incr          ' Check if button pressed for 250 ms , IF yes, increment I and recheck
       GOTO Main                              ' If not jump to main
       Incr:
    NEXT I                                    ' If checked 8 times we enter Setup routine
    Setup_routine :
    Main :
    Note there's NO DELAY to enter main routine if button hasn't been pressed ... either test will be left as soon as button is released ...
  1. Replies: 17
    Last Post: - 12th April 2014, 02:17
  2. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 08:02
  3. Microcontroller with 2 way paging application problem
  4. CCP1 and CCP2 to measure 2 frequencies together
    By bobonapoletano in forum mel PIC BASIC Pro
    Last Post: - 28th December 2005, 07:34
  5. PULSIN and RCTIME
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 4th November 2004, 14:45
