Can't read sequential addresses in external EEPROM
Results 1 to 3 of 3
Threaded View
    Jan 2010
    Default Can't read sequential addresses in external EEPROM
    I am using a PIC18F2420 with a Microchip 25LC1024 128k x 8 EEPROM.
    To get my technique down on using the MSSP I wrote the test code below to write data to the first 2 locations in the EEPROM then to read them back.
    If I do two separate reads it works but when I keep the CS low to perform a sequential read and clock the next data byte out of the EEPROM I always get FF.
    What am I missing here?
    '25LC1024 128k x 8 EEPROM
    'PIC18F2420
    CS Var PORTB.2
    dummy_data Var Byte
    Data_Byte1 Var Byte
    Data_Byte2 Var Byte
    DEFINE OSC 32                  	'32 Mhz Osc
    TRISB=%00000000			'Set CS as an output
    TRISC=%00010000			'Set SPI data in, data out and clock out
    SSPSTAT = %01000000    		'Sample in middle, TX rising clock edge
    SSPCON1 = %00100010 		'No collision/overflow, enable port,idle low,Fosc/64
    High CS
    Gosub Write_SPI_data
    Gosub Read_SPI_data
    Gosub Read_SPI_Data_Sequential
    Write_SPI_Data:
    Gosub Write_Enable
    Low CS
    SSPBUF = %00000010		' Send Opcode for WRITE sequence
    While SSPSTAT.0 = 0: Wend 	' Wait for completion
    dummy_data = SSPBUF
    SSPBUF = %00000000		' Send MSByte of EEPROM address
    dummy_data = SSPBUF
    SSPBUF = %00000000		' Send Middle Byte of EEPROM address
    dummy_data = SSPBUF
    SSPBUF = %00000000		' Send LSByte of EEPROM address
    dummy_data = SSPBUF
    SSPBUF = %00000111		' Send data byte
    dummy_data = SSPBUF
    High CS
    Gosub Write_Enable		' Write Enable Latch is reset after
    			             '  WRITE instruction successfully
                                                       ' executed so re-enable.
    Low CS
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    SSPBUF = %00000001		' Send LSByte of next EEPROM address
    dummy_data = SSPBUF
    SSPBUF = %00010000		' Send data byte
    dummy_data = SSPBUF
    High CS
    Read_SPI_Data:			' This works
    Low CS
    SSPBUF = %00000011		' Send Opcode for READ sequence
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    SSPBUF = %00000000		' Send LSByte of next EEPROM address
    dummy_data = SSPBUF
    SSPBUF = %00000000		' Send dummy data byte to clock data out of EEPROM
    Data_Byte1 = SSPBUF		' Get data from address 0. Should be %00000111
                                                       ' and it is.
    High CS                                         ' End of first READ sequence
    Low CS				' Perform next READ sequence
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    dummy_data = SSPBUF
                                                       ' out of EEPROM.
    Data_Byte2 = SSPBUF		' Get data from address 1. Should be
                                                       ' %00010000 and it is.
    High CS				' End of second READ sequence
    Read_SPI_Data_Sequential:	             ' This doesn't work
    Low CS
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    SSPBUF = %00000000		' Send dummy data byte to clock next data out of EEPROM
                                                       ' %00000111 and it is.
    				' Internal address pointer is
                                                       ' automatically incremented
                                                       ' out of EEPROM.
                                                       ' %00010000 but is %11111111
    High CS				' End of READ sequence
    Write_Enable:
    'Set the write enable latch (enable write operations)
    Low CS
    SSPBUF = %00000110		' Send Opcode for WREN
    dummy_data = SSPBUF
    High CS
  1. Replies: 1
    Last Post: - 28th January 2010, 22:15
  2. How to define constants that specify eeprom addresses
    By DwayneR in forum mel PIC BASIC Pro
    Last Post: - 8th December 2009, 04:07
  3. Cleaning up code
    Last Post: - 2nd December 2009, 07:14
  4. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 19:59
