I'm an idiot and I don't know why! - CCP1_INT
Results 1 to 12 of 12
    Sep 2008
    Red face I'm an idiot and I don't know why! - CCP1_INT
    I've been learning about interrupts thanks to the fabulous work of Darrel. I've been able to get INT_INT, RX_INT, and RBC_INT working with no problems. But I can't figure out how to get CCP1_INT working. I've looked at others examples and still I am missing something. Will someone please show me how big of an idiot I really am?
    I've tried different configuration with TMR1...starting it, stopping it, leaving it out altogether with no luck.
    It doesn't get much easier than this....
    '16f628A
    DEFINE OSC 20
    CMCON = 7
    VRCON = 0
    TRISB  = %00011011
    TRISA  = %00010000
    CCP1CON = %00000101
    INCLUDE "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas"
    clear
            INT_Handler   CCP1_INT,  _ToggleLED,   PBP,  yes
    @ INT_ENABLE  CCP1_INT
    Mainloop:
            pause 1
            goto Mainloop
    ToggleLED:
        TOGGLE PORTA.0
    @ INT_RETURN
    What is triggering the interrupt on RB3?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2008
    pushbutton
    RB3 CCP1 input is an ST type, so it needs 0.8 * Vdd to meet the logic 1 input threshold.
    I can't really tell from your schematic, but it looks like you might have a voltage divider?
    -Bruce
    tech at rentron.com
    Sep 2008
    5.00v on Pin3
    Hmm ... should work. I just tested it with the older version of DT_INTS-14 & ReEnterPBP.
    Are you using the latest version? I haven't tried the newer rev yet.
    -Bruce
    tech at rentron.com
    Sep 2008
    I'm using version .93 Beta DT_INTS-14
    and version 3.2 ReEnterPBP.
    Using the same here, but tested it on real hardware with a pull-down holding RB3 low, and
    switch pulling it high when pressed. Works 100%.
    Is RB3 being held at ground until you press the switch?
    -Bruce
    tech at rentron.com
    Sep 2008
    Thanks Bruce for the feedback. I'll try to figure out "Whats Up With That"...
    Only wasted ~ 9 hours on it.....
    Sep 2008
    Sorry Bruce, didn't see the last portion of your post. I assumed since it worked for you, it was a problem with the simulator. The simulator does show .02v when the button is not pressed and the rest of the inputs work correctly for the other interrupts. I guess I'm going to have to what for the real circuit board to arrive for further testing.
    Sep 2005
    Campbell, CA
    I don't see anthing that would pull the inputs low when the switches aren't pushed.
    Charles Linquist
    Sep 2008
    If I change the interrupt to either INT_INT or RBC_INT and move the input to another pin, it works fine. CCP1_INT does not work. It has to be the simulator. I don't have a real 16F628A to test yet. Should have the actual circuit board next week.
