Thermo 7 segments - little problem
Page 1 of 2 12 LastLast
Results 1 to 40 of 50
    Dec 2008
    Ploiesti, ROMANIA
    Default Thermo 7 segments - little problem
    Hello !
    I intend to make one digital thermometer, this time using a 7 segments display. I use code from my previous thermometer and from this forum for interfacing PIC with display. Unfortunate on display I have only "0". I think I made some mistakes in variables statements, but I need little help....Thanks in advance for every reply.
    Jul 2008
    TURKIYE-KONYA
    if you are using isis for simulation , it is hard to scanning displays.
    it doesnt work properly when displays are scanning.
    Dec 2008
    Ploiesti, ROMANIA
    Default ?!
    Yes, I use ISIS... It's this a problem ?! I wrote another code, with the same results : "000" on display. Both (wrong) results are because of simulation ? Thanks for reply !
    Jul 2008
    TURKIYE-KONYA
    i wrote some codes below it worked on isis.
        SEGMENT_A   VAR PORTB.3
        SEGMENT_B   VAR PORTB.7
        SEGMENT_C   VAR PORTB.0
        SEGMENT_D   VAR PORTA.3
        SEGMENT_E   VAR PORTA.2
        SEGMENT_F   VAR PORTB.2
        SEGMENT_G   VAR PORTB.1
        DP          VAR PORTB.6
        BASAMAK_0   VAR PORTA.1
        BASAMAK_1   VAR PORTA.7
        BASAMAK_2   VAR PORTA.0
        BASAMAK_3   VAR PORTA.6
        DQ          VAR PORTB.5
        TEMP        VAR BYTE
        I           VAR BYTE
        SIGN        VAR BIT
        ISI             VAR WORD ; TEMPERATURE REGISTER
        COUNT_REMAIN    VAR BYTE
        MASK_0      VAR BYTE
        MASK_1      VAR BYTE
        MASK_2      VAR BYTE
        MASK_3      VAR BYTE
        CMCON   = 7
        OUTPUT      SEGMENT_A
        OUTPUT      SEGMENT_B
        OUTPUT      SEGMENT_C
        OUTPUT      SEGMENT_D
        OUTPUT      SEGMENT_E
        OUTPUT      SEGMENT_F
        OUTPUT      SEGMENT_G
        OUTPUT      DP
        OUTPUT      BASAMAK_0
        OUTPUT      BASAMAK_1
        OUTPUT      BASAMAK_2
        OUTPUT      BASAMAK_3
        SEGMENT_A   = 0
        SEGMENT_B   = 0
        SEGMENT_C   = 0
        SEGMENT_D   = 0
        SEGMENT_E   = 0
        SEGMENT_F   = 0
        SEGMENT_G   = 0
        DP          = 0
        BASAMAK_0   = 1 ; DISPLAYS 1. DIGIT
        BASAMAK_1   = 1 ; DISPLAYS 2. DIGIT
        BASAMAK_2   = 1 ; DISPLAYS 3. DIGIT
        BASAMAK_3   = 1 ; DISPLAYS 4. DIGIT
        MAIN :
            OWOUT DQ ,1,[$CC,$44]
            BEKLE :
            GOSUB EKRAN_0
            FOR I = 0 TO 4
                GOSUB TARA
            NEXT I
            OWIN  DQ ,4,[COUNT_REMAIN]
            IF COUNT_REMAIN = 0 THEN
                GOTO BEKLE
            OWOUT DQ ,1,[$CC,$BE]
            OWIN  DQ ,0,[ISI.LOWBYTE , ISI.HIGHBYTE]
            IF ISI.15 = 1 THEN
                ISI = (65535 - ISI) + 1
                SIGN = 1
                SIGN = 0
                ISI = (ISI * 10)/16
    GOTO MAIN
        EKRAN_0 :  ; TRANSFER THE REGISTERS TO DIPLAY
        MASK_3 = ISI DIG 3
        MASK_2 = ISI DIG 2
        IF SIGN = 1 THEN
            MASK_3 = " "
            MASK_2 = "-"
        MASK_1 = ISI DIG 1
        MASK_0 = ISI DIG 0
        TARA : ; SCAN THE DISPLAYS
        TEMP = MASK_3 : GOSUB TABLO
        BASAMAK_3 = 0 : PAUSE 1 : BASAMAK_3 = 1
        TEMP = MASK_2 : GOSUB TABLO
        BASAMAK_2 = 0 : PAUSE 1 : BASAMAK_2 = 1
        TEMP = MASK_1 : GOSUB TABLO
        BASAMAK_1 = 0 : DP = 1 : PAUSE 1 : BASAMAK_1 = 1 : DP = 0
        TEMP = MASK_0 : GOSUB TABLO
        BASAMAK_0 = 0 : PAUSE 1 : BASAMAK_0 = 1
        TABLO :  ; TABLE , CONVERTS THE DATAS TO 7 SEGMENT CODE
        SELECT CASE TEMP
            CASE 0
            SEGMENT_A = 1
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 1
            SEGMENT_F = 1
            SEGMENT_G = 0
            CASE 1
            SEGMENT_A = 0
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 0
            SEGMENT_E = 0
            SEGMENT_F = 0
            SEGMENT_G = 0
            CASE 2
            SEGMENT_A = 1
            SEGMENT_B = 1
            SEGMENT_C = 0
            SEGMENT_D = 1
            SEGMENT_E = 1
            SEGMENT_F = 0
            SEGMENT_G = 1
            CASE 3
            SEGMENT_A = 1
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 0
            SEGMENT_F = 0
            SEGMENT_G = 1
            CASE 4
            SEGMENT_A = 0
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 0
            SEGMENT_E = 0
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE 5
            SEGMENT_A = 1
            SEGMENT_B = 0
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 0
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE 6
            SEGMENT_A = 1
            SEGMENT_B = 0
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 1
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE 7
            SEGMENT_A = 1
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 0
            SEGMENT_E = 0
            SEGMENT_F = 0
            SEGMENT_G = 0
            CASE 8
            SEGMENT_A = 1
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 1
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE 9
            SEGMENT_A = 1
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 0
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE "-"
            SEGMENT_A = 0
            SEGMENT_B = 0
            SEGMENT_C = 0
            SEGMENT_D = 0
            SEGMENT_E = 0
            SEGMENT_F = 0
            SEGMENT_G = 1
            CASE "h"
            SEGMENT_A = 0
            SEGMENT_B = 0
            SEGMENT_C = 1
            SEGMENT_D = 0
            SEGMENT_E = 1
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE "o"
            SEGMENT_A = 0
            SEGMENT_B = 0
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 1
            SEGMENT_F = 0
            SEGMENT_G = 1
            CASE "b"
            SEGMENT_A = 0
            SEGMENT_B = 0
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 1
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE " "
            SEGMENT_A = 0
            SEGMENT_B = 0
            SEGMENT_C = 0
            SEGMENT_D = 0
            SEGMENT_E = 0
            SEGMENT_F = 0
            SEGMENT_G = 0
        END SELECT
    some register names and label are written in turkish. i tried to comment them to english.
    there is no transistors to drive diplays.
    if your version is same with my isis , it will work.
    all files in attachment.
    Dec 2008
    Ploiesti, ROMANIA
    Thank You verry much for support ! ...My ISIS is Release 7.4 SP3, and Your code (copy/paste/compiling, because the zip file is empty !) DON'T WORK !!!
    Verry strange ... PIC and statements are the same ?
    Jul 2008
    TURKIYE-KONYA
    i refreshed the zip file download again.
    Dec 2008
    Ploiesti, ROMANIA
    Default Anod versus Catod
    You use CC, I use AC... Yes, of course that Your code works ! Great ! I will try now the "live" schematic ! Wish me luck !
    Thank You, again ! All the best !
    Dec 2008
    Ploiesti, ROMANIA
    ...a little problem : don't display value under -9.9 'C ! For -10.0 'C the display show - 0,0 'C. Now, in my town, outside is -12'C !!! (brrrrrrr...)
    Jul 2008
    TURKIYE-KONYA
    ok. i understood the problem . we will shift the "-" string 1 step left.
    change the "ekran_0" label with below ;
    ekran_0 :  ; transfer the registers to diplay
        mask_3 = isi dig 3
        if sign = 1 then
            mask_3 = "-"
        mask_2 = isi dig 2
        mask_1 = isi dig 1
        mask_0 = isi dig 0
    Dec 2008
    Ploiesti, ROMANIA
    Default Without flickering...
    I made the thermometer, using the code from Mr.Mehmet - Thanks ! I use common cathode LED display. But..., with the schematic from Mr.Mehmet , the display have flicker...It' one good ideea to use transistors for cathodes, like in picture ? It's correct ? (In ISIS dont work ! ) It's this one solution for "flicker free" ? Thanks in advance for reply !
    Dec 2008
    Ploiesti, ROMANIA
    Default Try to learn about INTERRUPTS
    I re-write the code posted by Mehmet (Thanks !) , because I intend to use interrupts. On ISIS work ...fine (little flicker ?!) . But...I wonder if the code it's right. I re-re-read MCSE help about using interrupts...and, of course, any advice it's wellcome. Thanks in advance !
    '*               Termometru 7 segmente			   *
    '*                  cu intreruperi			         *
    @ DEVICE pic16F628A, intOSC_osc_noclkout, WDT_OFF, PWRT_ON, MCLR_OFF, LVP_OFF, CPD_OFF, PROTECT_OFF
    DEFINE  NO_CLRWDT 1
    DEFINE  OSC 4
    TRISA= %11110000                   	' RA0..3=Outputs RA4...7=Input
    TRISB= %00000000 		   	      ' RB0..RB7=Outputs
    CMCON=7                            	' Disable comparators
        SEGMENT_A   VAR PORTB.0
        SEGMENT_B   VAR PORTB.1
        SEGMENT_C   VAR PORTB.2
        SEGMENT_D   VAR PORTB.3
        SEGMENT_E   VAR PORTB.4
        SEGMENT_F   VAR PORTB.5
        SEGMENT_G   VAR PORTB.6
        DP          VAR PORTB.7
        CATOD_0   	VAR PORTA.0
        CATOD_1   	VAR PORTA.1
        CATOD_2   	VAR PORTA.2
        CATOD_3   	VAR PORTA.3
        DQ          VAR PORTA.4
    OPTION_REG = %10000000
    Temp            var byte
    DS18B20_12bit   CON %01111111        	' 750ms,   0.0625°C
    Temperature     Var     Word
    TempC           Var     Word
    I               Var     Byte
    Sign            Var     Bit
    Count_remain    var     Byte
    Float           Var     Word
    V		    Var     Word	     	      ' Var. for display
    Twist           Var     Bit
    Dummy           Var     Byte
    Busy            var  	BIT            	' Busy Status-Bit
        DIGIT_0      VAR BYTE
        DIGIT_1      VAR BYTE
        DIGIT_2      VAR BYTE
        DIGIT_3      VAR BYTE
        OUTPUT      SEGMENT_A
        OUTPUT      SEGMENT_B
        OUTPUT      SEGMENT_C
        OUTPUT      SEGMENT_D
        OUTPUT      SEGMENT_E
        OUTPUT      SEGMENT_F
        OUTPUT      SEGMENT_G
        OUTPUT      DP
        OUTPUT      CATOD_0
        OUTPUT      CATOD_1
        OUTPUT      CATOD_2
        OUTPUT      CATOD_3
        SEGMENT_A   = 0
        SEGMENT_B   = 0
        SEGMENT_C   = 0
        SEGMENT_D   = 0
        SEGMENT_E   = 0
        SEGMENT_F   = 0
        SEGMENT_G   = 0
        DP          = 0
        CATOD_0   = 1 ; DISPLAYS 1. DIGIT
        CATOD_1   = 1 ; DISPLAYS 2. DIGIT
        CATOD_2   = 1 ; DISPLAYS 3. DIGIT
        CATOD_3   = 1 ; DISPLAYS 4. DIGIT
    ON INTERRUPT GOTO ISR
    INTCON = %10100000
    OWOut DQ, 1, [$CC, $4E, 0, 0, DS18B20_12bit]
     Output DQ             		          ' Make Pin Output
     DQ=0					          ' OneWire line Low
     PauseUs 480                            ' Keep down for 480 µS
     Input DQ                               ' Make Pin Input
     PauseUs 70                             ' Wait 70 µS
    Pause 500
    W1:
        OWIN DQ,4,[busy]            	   ' Check for still busy converting
        IF busy = 0 THEN W1         	   ' Still busy?  then loop
    MAIN :
            OWIN  DQ ,2,[Temperature.LOWBYTE , Temperature.HIGHBYTE]
    Convert_Temp:
    If Temperature.15 then
      Temperature= ~Temperature +1
      Twist = 1
      Sign  = 1
    Endif
    Dummy = 625 * Temperature
    TempC = DIV32 10
    TempC = (Temperature & $7FF) >> 4
    Float = ((Temperature.Lowbyte & $0F ) * 25 )>>2
    Temperature = TempC*100 + Float
    If Twist then
      V= 10000 - Temperature                ' 25 C=12500  0 C=10000  -10 C=9000
      Twist = 0
      V= 10000 + Temperature
    EndIf
    GoSub Sign_temp
            Temperature = Temperature/10
    GOSUB AFISARE
      FOR I = 0 TO 4
         GOSUB SCANNING
      NEXT I
    GOTO MAIN
    ' SUBROUTINES:
    Sign_temp:
     If V >= 10000 then                     ' Above 0 C.
      Temperature=V-10000
      sign = " "
     Else
      Temperature=10000-V                   ' Below 0 C.
      sign= "-"
     EndIf
    AFISARE :  				' transfer the registers to diplay
    IF TEMPERATURE DIG 3 = 0 THEN
        DIGIT_3 = " "
        DIGIT_3 = TEMPERATURE dig 3
        IF sign = 1 THEN
        	DIGIT_3 = "-"
    IF TEMPERATURE DIG 2 = 0 THEN
        DIGIT_2 = " "
        DIGIT_2 = TEMPERATURE dig 2
        DIGIT_1 = TEMPERATURE dig 1
        DIGIT_0 = TEMPERATURE dig 0
    DISABLE
    ISR:
    SCANNING : 				' SCAN THE DISPLAYS
        TEMP = DIGIT_3 : GOSUB TABLO
        CATOD_3 = 0 : PAUSE 1 : CATOD_3 = 1
        TEMP = DIGIT_2 : GOSUB TABLO
        CATOD_2 = 0 : PAUSE 1 : CATOD_2 = 1
        TEMP = DIGIT_1 : GOSUB TABLO
        CATOD_1 = 0 : DP = 1 : PAUSE 1 : CATOD_1 = 1 : DP = 0
        TEMP = DIGIT_0 : GOSUB TABLO
        CATOD_0 = 0 : PAUSE 1 : CATOD_0 = 1
    TABLO :  				' TABLE , CONVERTS THE DATAS TO 7 SEGMENT CODE
        SELECT CASE TEMP
            CASE 0
            SEGMENT_A = 1
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 1
            SEGMENT_F = 1
            SEGMENT_G = 0
            CASE 1
            SEGMENT_A = 0
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 0
            SEGMENT_E = 0
            SEGMENT_F = 0
            SEGMENT_G = 0
            CASE 2
            SEGMENT_A = 1
            SEGMENT_B = 1
            SEGMENT_C = 0
            SEGMENT_D = 1
            SEGMENT_E = 1
            SEGMENT_F = 0
            SEGMENT_G = 1
            CASE 3
            SEGMENT_A = 1
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 0
            SEGMENT_F = 0
            SEGMENT_G = 1
            CASE 4
            SEGMENT_A = 0
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 0
            SEGMENT_E = 0
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE 5
            SEGMENT_A = 1
            SEGMENT_B = 0
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 0
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE 6
            SEGMENT_A = 1
            SEGMENT_B = 0
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 1
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE 7
            SEGMENT_A = 1
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 0
            SEGMENT_E = 0
            SEGMENT_F = 0
            SEGMENT_G = 0
            CASE 8
            SEGMENT_A = 1
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 1
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE 9
            SEGMENT_A = 1
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 0
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE "-"
            SEGMENT_A = 0
            SEGMENT_B = 0
            SEGMENT_C = 0
            SEGMENT_D = 0
            SEGMENT_E = 0
            SEGMENT_F = 0
            SEGMENT_G = 1
            CASE "h"
            SEGMENT_A = 0
            SEGMENT_B = 0
            SEGMENT_C = 1
            SEGMENT_D = 0
            SEGMENT_E = 1
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE "o"
            SEGMENT_A = 0
            SEGMENT_B = 0
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 1
            SEGMENT_F = 0
            SEGMENT_G = 1
            CASE "b"
            SEGMENT_A = 0
            SEGMENT_B = 0
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 1
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE " "
            SEGMENT_A = 0
            SEGMENT_B = 0
            SEGMENT_C = 0
            SEGMENT_D = 0
            SEGMENT_E = 0
            SEGMENT_F = 0
            SEGMENT_G = 0
        END SELECT
    INTCON.2=0
    RESUME
    ENABLE
    PS: Remove .txt extension from attachament, for using in iSIS.
    May 2010
    Default doesnt compile
    To mehmetOzdemir
    Hi I have downloaded and ran isis.zip files and it worked fine for me but when I compile the pic basic file in the isis.zip file and re simulate it in isis it only displays as per the attatched image.
    Any ideas? is the pic basic file ok?
    I am only learning this system so I am confused as to why it works perfect with original files but yet I cant compile it from my picbasic system.
    This is what I get when I compile the files in the zip myself.
    Jul 2008
    TURKIYE-KONYA
    I used MPASM when i compiled it. Try to use MPASM or add your config settings to the top of your code.
    Dec 2008
    Ploiesti, ROMANIA
    Try to add this :
    DEFINE  NO_CLRWDT 1
    DEFINE  OSC 4
    TRISA ..... (0 = OUTPUT ; 1 = INPUT)
    TRISB ..... ( ID.)
    and don't forget to tell ISIS that your PIC work at 4 Mhz.
    May 2010
    Ok thanks alot i'll try that.
    Quote Originally Posted by fratello View Post
    Try to add this :
    DEFINE  NO_CLRWDT 1
    DEFINE  OSC 4
    TRISB ..... ( ID.)
    May 2010
    Thanks again it works perfect now.
    Quote Originally Posted by zorbzz View Post
    Dec 2008
    Ploiesti, ROMANIA
    Default Hi ! Me again :) ...
    I made this schematic; I use this code. Works fine, but.... I don't know how to display "minus sign" for negative temperatures. I try differents variants, but without results...Any advice it's wellcome ! Thanks in advance !
    ' * For use with EXPERIMENTING WITH THE PICBASIC PRO COMPILER *
    ' *  This source code may be freely used within your own      *
    ' *  programs. However, if it is used for profitable reasons, *
    ' *        please give credit where credit is due.	        *
    ' *  And make a reference to myself or Rosetta Technologies   *
    ' *			              Les. Johnson		        *
    ' Common Anode seven segment display multiplexer
    ' Displays the contents of the variable D_NUMBER on five common Anode displays
    ' using a TMR0 interrupt
    @ DEVICE pic16F648A, XT_OSC, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_OFF, LVP_OFF, CPD_OFF
      CMCON = 7
      VRCON = 0
      INTCON = 0
    Include "Modedefs.bas"
    ' ** Setup the Crystal Frequency, in mHz **
    	Define 	OSC		4 		   	' Set Xtal Frequency
    ' ** Declare the Variables **
    	LEDS		  	Var	Byte		      ' The amount of LEDs in the display
    	O_C		    	Var	Byte		      ' Used by the interrupt for time sharing
    	Counter		Var	Word		      ' General purpose counter
    	Del		    	Var	Word		      ' General purpose delay loop variable
    	D_Number		Var	Word		      ' The number to display on the LEDS
    	DP		    	Var	Byte		      ' Position of the decimal point
    	Disp_Patt		Var	Byte		      ' Pattern to output to PortC
    	Num		    	Var	Byte[5]	      ' Array to hold each digits value
    	Digit0		Var	PortA.0		' Controls the first DIGIT on the LED
    	Digit1		Var	PortA.1		' Controls the second DIGIT on the LED
    	Digit2		Var	PortA.2		' Controls the third DIGIT on the LED
    	Digit3		Var	PortA.3		' Controls the fourth DIGIT on the LED
    	temperature       var   word
    	TempC             Var   word
    	Temp	            Var   byte
          Float             Var   word
    	V		      Var   word
    	Twist             Var   bit
    	Dummy             Var   byte
          Sign              var   byte
    	busy              var   bit
    	DQ			var PortA.4
    ' ** Declare the bits and flags of the various registers **
    	T0IE		Var	INTCON.5	      	' Timer0 Overflow Interrupt Enable
    	T0IF		Var	INTCON.2	      	' Timer0 Overflow Interrupt Flag
    	GIE		Var	INTCON.7	        	' Global Interrupt Enable
    	PS0		Var	OPTION_REG.0	    	' Prescaler division bit-0
    	PS1		Var	OPTION_REG.1	    	' Prescaler division bit-1
    	PS2		Var	OPTION_REG.2	    	' Prescaler division bit-2
    	PSA		Var	OPTION_REG.3	   	' Prescaler Assignment (1= assigned to WDT)
                                  			'    (0= assigned to oscillator)
    	T0CS		Var	OPTION_REG.5	  	' Timer0 Clock Source Select (0=Internal clock)
                                 				'    (1=External PORTA.4)
    ' Set TMR0 to interrupt
    	GIE=0				      		' Turn off global interrupts
    	While GIE=1:GIE=0:Wend				' Make sure they are off
    	PSA=0							' Assign the prescaler to external oscillator
    	PS0=0							' Set the prescaler
    	PS1=1							' to increment TMR0
    	PS2=0							' every 64th instruction cycle
    	T0CS=0						' Assign TMR0 clock to internal source
    	TMR0=0						' Clear TMR0 initially
    	T0IE=1						' Enable TMR0 overflow interrupt
    	GIE=1							' Enable global interrupts
    On Interrupt Goto Mult_Int				' Point to the interrupt handler
    	TrisB=0						' Make PortB outputs
    	TrisA.0=0:TrisA.1=0:TrisA.2=0			' Make only the specific bits of PortA outputs
    	TrisA.3=0:TrisA.4=1
    	PortA=0:PortB=0			      	' Clear PortB and PortA
    	O_C=0							' Clear the time share variable
    W1:
    ' ** THE MAIN PROGRAM STARTS HERE **
    OWOut DQ, 1, [$CC, $44]
    OWOut DQ, 1, [$CC, $BE]
    OWIn DQ, 2, [temperature.byte0, temperature.byte1]
      Twist = 1
      Sign  = 1
    Endif
    TempC = DIV32 10
    If Twist then
      Twist = 0
    EndIf
      Temperature=V-10000
      sign = " "
      sign= "-"
    EndIf
    	D_Number=Temperature/10			      ' Place the value to display into D_NUMBER
    	DP=0					            ' Disable the decimal point
    	Gosub Display				      ' Display the value
    	 For Del=0 to 100			      	' Pause 10ms
    	 Pauseus 100				      ' using smaller delays
    	 Next
    Inf:
    Goto Main				              	' Do it forever
    ' Build up the seperate digits of variable D_NUMBER
    ' into the array NUM. Each LED is assigned to each array variable.
    ' LED-0 (right) displays the value of NUM[0]
    ' LED-1 (middle) displays the value of NUM[1]
    ' LED-2 (lef) displays the value of NUM[2]
    ' The decimal point is placed by loading the variable DP
    ' with the LED of choice to place the point (0..5). where 1 is the farthest right LED
    ' and 0 disables the decimal point.
    Display:
    	For LEDS=3 to 0 step -1 				' Loop for 4 digits (0-9999)
    	Disable							' Disable the interrupt while we calculate
    	Num[LEDS]=D_Number dig LEDS 				' Extract the seperate digits into the array
    	If D_Number<10 and LEDS=1 then Num[LEDS]=10	' Zero Suppression for the second digit
    	If D_Number<100 and LEDS=2 then Num[LEDS]=10	' Zero Suppression for the Third digit
    	If D_Number<1000 and LEDS=3 then Num[LEDS]=10	' Zero Suppression for the Forth digit
    	Enable							' Re-enable the interrupt
    	Next
    ' INTERRUPT HANDLER
    ' Multiplexes the 4-digits
            Disable         			' Disable all interupts during the interrupt handler
    Mult_Int:
    	Lookup Num[O_C],[192,249,164,176,153,146,131,248,128,152,255],Disp_Patt ' Decode the segments for the LED
    ' Process the first display (farthest right)
    	If O_C=0 then				' If it is our turn then
    	Digit3=0					' Turn OFF the fourth LED
    	PortB=Disp_Patt				' Place the digit pattern on portC
    	If DP=1 then PortB.7=0			' Check the value of DP and Turn ON the decimal point
    	Digit0=1					' Turn ON the first LED
    	Endif
    ' Process the second display
    	If O_C=1 then				' If it is our turn then
    	Digit0=0					' Turn OFF the first LED
    	If DP=2 then PortB.7=0			' Check the value of DP and Turn ON the decimal point
    	Digit1=1					' Turn ON the second LED
    	Endif
    ' Process the third display
    	If O_C=2 then				' If it is our turn then
    	Digit1=0					' Turn OFF the second LED
    	If DP=3 then PortB.7=0			' Check the value of DP and Turn ON the decimal point
    	Digit2=1					' Turn ON the third LED
    	Endif
    ' Process the fourth display
    	If O_C=3 then				' If it is our turn then
    	Digit2=0					' Turn OFF the third LED
    	Digit3=1					' Turn ON the fourth LED
    	Endif
    	O_C=O_C+1					' Increment the time share counter
    	If O_C>=4 then O_C=0			' If it reaches 4 or over then clear it
    	T0IF=0    					' Reset TMR0 interrupt flag
            Resume					' Exit the interrupt
    	Enable					' Allow more interrupts
    Dec 2008
    Ploiesti, ROMANIA
    If sign="-" then
            PortB=%00111111
            PortB.7=0
    	Endif
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Thermo 7 segments - little problem
    My final code, using for thermometer with two DS18B20. Works fine !
    ;                          CATOD / ANOD COMUN
    ;                         merge foarte bine !!!
    ;                        VARIANTA 2 SENZORI !!!
    ;                     by Niculescu Dan, APRIL 2011
    ;                        .oooO
    ;                        (   )   Oooo.
    ;                          \_)    ) /
    ;                                (_/
    CMCON		= 7
    VRCON 	= 0
    INTCON	= 0
        COMMON_0   	VAR PORTA.0
        COMMON_1   	VAR PORTA.1
        COMMON_2   	VAR PORTA.2
        COMMON_3   	VAR PORTA.3
        DQ          VAR PORTA.4
        DQ2		      VAR PORTA.6
        DP          VAR PORTB.7
    Temp   	        Var     Byte 		: Temp2   	      Var     Byte
    Temperature     Var     Word 		: Temperature2    Var     Word
    TempC           Var     Word 		: TempC2          Var     Word
    I               Var     Byte 		: I2              Var     Byte
    Sign            Var     Word 		: Sign2           Var     Word
    Float           Var     Word 		: Float2          Var     Word
    V		            Var     Word 		: V2		          Var     Word
    Dummy           Var     Byte 		: Dummy2          Var     Byte
    Busy		        Var     Bit  		: Busy2	          Var     Bit
    Delay           Var     Word
    Valoare         VAR     Word
    Semn		        Var     Word
        DIGIT_0     VAR 	BYTE
        DIGIT_1     VAR 	BYTE
        DIGIT_2     VAR 	BYTE
        DIGIT_3     VAR 	BYTE
    DS18B20_12bit2   CON %01111111       ' 750ms,   0.0625°C
    TrisB=%00000000				 ' Make PortB outputs
    TrisA=%11110000
    ' Init Sensor 1
     OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_12bit]
     OWOut DQ, 1, [$CC, $48]       		    ' Start temperature conversion
     OWOut DQ, 1, [$CC, $B8]
     Pause 50
    ' Init Sensor 2
     OWOUT DQ2, 1, [$CC, $4E, 0, 0, DS18B20_12bit2]
     OWOut DQ2, 1, [$CC, $48]       		    ' Start temperature conversion
     OWOut DQ2, 1, [$CC, $B8]
     OWOut DQ2, 1, [$CC, $BE]
     Pause 50
     OWIn DQ2, 2, [temperature2.byte0, temperature2.byte1]
     Pause 100
    Main :
    If portA.7= 1 then
    valoare=temperature
    semn=sign
    Endif
    If portA.7= 0 then
    valoare=temperature2
    semn=sign2
    Endif
    Part1:
    ' Start temp.conv.Sensor1
      Sign  = 1
    Endif
    TempC = DIV32 10
    If Sign=1 then
    EndIf
    If V >= 10000 then
      Temperature=V-10000
      sign = " "
      Temperature=10000-V
      sign = "-"
    EndIf
    Temperature=Temperature/10
    '===================================== end part one
    Part2 :
     OWOut DQ2, 1, [$CC, $44]
    If Temperature2.15 then
      Temperature2= ~Temperature2 +1
      Sign2  = 1
    Endif
    Dummy2 = 625 * Temperature2
    TempC2 = DIV32 10
    TempC2 = (Temperature2 & $7FF) >> 4
    Float2 = ((Temperature2.Lowbyte & $0F ) * 25 )>>2
    Temperature2 = TempC2*100 + Float2
    If Sign2=1 then
      V2= 10000 - Temperature2
      V2= 10000 + Temperature2
    EndIf
    If V2 >= 10000 then
      Temperature2=V2-10000
      sign2 = " "
      Temperature2=10000-V2
      sign2 = "-"
    EndIf
    Temperature2=Temperature2/10
    '===================================== end part two
    Gosub Selectie
    Gosub Display				' B for Common CATOD;without B for Common ANOD
    Goto Main
    Selectie :
    IF semn ="-" then
        DIGIT_3="-"
        DIGIT_3=" "
    IF valoare DIG 2 = 0 THEN
        DIGIT_2 = " "
        DIGIT_2 = valoare dig 2
        DIGIT_1 = valoare dig 1
        DIGIT_0 = valoare dig 0
    Display:					' For Common ANOD
    for i=0 to 3
        TEMP = DIGIT_3 : gosub segments
        COMMON_3 = 1 :gosub DelayBetweenEachDigit : COMMON_3 = 0
        TEMP = DIGIT_2 : GOSUB segments
        COMMON_2 = 1 :gosub DelayBetweenEachDigit : COMMON_2 = 0
        TEMP = DIGIT_1 : GOSUB segments
        COMMON_1 = 1 :DP = 0 : gosub DelayBetweenEachDigit : COMMON_1 = 0 : DP = 1
        TEMP = DIGIT_0 : GOSUB segments
        COMMON_0 = 1 :gosub DelayBetweenEachDigit : COMMON_0 = 0
    next i
    Displayb:					' For Common CATOD
    for i=0 to 3
        TEMP = DIGIT_3 : gosub segmentsB
        COMMON_3 = 0 :gosub DelayBetweenEachDigit : COMMON_3 = 1
        TEMP = DIGIT_2 : GOSUB segmentsB
        COMMON_2 = 0 : gosub DelayBetweenEachDigit : COMMON_2 = 1
        TEMP = DIGIT_1 : GOSUB segmentsB
        COMMON_1 = 0 : DP = 1 : gosub DelayBetweenEachDigit : COMMON_1 = 1 : DP = 0
        TEMP = DIGIT_0 : GOSUB segmentsB
        COMMON_0 = 0 : gosub DelayBetweenEachDigit : COMMON_0 = 1
    next i
    segments:  ; CONVERTS DATES TO 7 SEGMENT CODE for Common ANOD
        SELECT CASE TEMP
    CASE 0 	 : PortB=%11000000 ; 0=ON ; 1=OFF
    CASE 1 	 : PortB=%11111001
    CASE 2 	 : PortB=%10100100
    CASE 3 	 : PortB=%10110000
    CASE 4 	 : PortB=%10011001
    CASE 5 	 : PortB=%10010010
    CASE 6 	 : PortB=%10000010
    CASE 7 	 : PortB=%11111000
    CASE 8 	 : PortB=%10000000
    CASE 9 	 : PortB=%10010000
    CASE "-"     : PortB=%10111111
    CASE " "     : PortB=%11111111
        END SELECT
    segmentsB:  ; CONVERTS DATES TO 7 SEGMENT CODE for Common CATOD
        SELECT CASE TEMP
    CASE 0 	 : PortB=%00111111 ; 1=ON ; 0=OFF
    CASE 1 	 : PortB=%00000110
    CASE 2 	 : PortB=%01011011
    CASE 3 	 : PortB=%01001111
    CASE 4 	 : PortB=%01100110
    CASE 5 	 : PortB=%01101101
    CASE 6 	 : PortB=%01111101
    CASE 7 	 : PortB=%00000111
    CASE 8 	 : PortB=%01111111
    CASE 9 	 : PortB=%01101111
    CASE "-"     : PortB=%01000000
    CASE " "     : PortB=%00000000
        END SELECT
    DelayBetweenEachDigit:
        ' DelayBetweenEachDigit
        ' Produce delay of about 3 mSec
        ' Fine tuned with MPLAB StopWatch to get MainLoop = 1 sec
        For delay=1 to 5
    	@ nop
    	next DELAY
    	@ nop
    	@ nop
    	@ nop
          @ nop
    	@ nop
    	@ nop
    	@ nop
    END						' of story !!!
    Dec 2008
    Ploiesti, ROMANIA
    I try to use Mr.Darrel "DT_INTS-14.bas" to make another variant of my termometer using 4x7 segments LED, like this :
    @ __config _INTOSC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON
    CMCON        = 7
    VRCON     = 0
    INTCON    = 0
    DQ        VAR PORTA.4
    CLEAR
    SEGDEF    VAR BYTE[3]
    Value     VAR WORD
    Idx       VAR BYTE
    Temp      VAR BYTE
    digitloop VAR BYTE
    Blanking  VAR BIT
    TempC           Var     Word
    I               Var     Byte
    Sign            Var     Word
    Float           Var     Word
    V                Var     Word
    Dummy           Var     Byte
    Busy            Var     Bit
    TrisA.3=0:TrisA.4=1
    INCLUDE "DT_INTS-14.bas" ' Base Interrupt System
    INCLUDE "ReEnterPBP.bas" ' Include if using PBP interrupts
        INT_Handler TMR1_INT, _DISP, PBP, yes
    TRISA = 0
    TRISB = 0
    @ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts
    T1CON = $1
    ' Init Sensor 1
     Pause 50
      Sign  = 1
    Endif
    TempC = DIV32 10
    If Sign=1 then
    EndIf
    If V >= 10000 then
      Temperature=V-10000
      sign = " "
      Temperature=10000-V
      sign = "-"
    EndIf
     FOR Value = 0 TO 9999
        GOSUB SetDisp
       PAUSE 500
     NEXT Value
    GOTO Main
    '---[Set 7-seg patterns to WORD value]------------------------------------------
    SetDisp:
      Blanking = 1
      FOR Idx = 3 to 0 STEP -1
        Temp = Value DIG Idx
        IF (Blanking AND Temp != 0) OR Idx = 0 THEN Blanking = 0
        IF Blanking THEN
          Temp = 0
          LookUp Temp,[132,175,193,137,170,152,144,143,128,136,210,251],Temp
        SEGDEF(Idx) = Temp
      NEXT Idx
    DISP:
      T1CON.0 = 0                ; stop timer
      TMR1H = %11111100
      TMR1L = %00011111
      T1CON.0 = 1                ; restart timer
      PORTA = %1111              ; turn off all digits to prevent ghosting
      PORTB = SEGDEF(digitloop)  ; put segment pattern to pin
      PORTA = ~(DCD digitloop)   ; turn on the digit
      digitloop = digitloop + 1
      IF digitloop = 4 then digitloop = 0
    @ INT_RETURN
    ...but where I must put the value of temperature ?! Any advice, please ? Thanks !
    Dec 2008
    Ploiesti, ROMANIA
    I try something like this
     FOR x = 0 TO 9999
     value=temperature
        GOSUB SetDisp
       PAUSE 500
     NEXT x
    GOTO Main
    but without results ... Any thought ?
    Dec 2008
    Ploiesti, ROMANIA
    I try to revive this topic ...
    I found here (http://vnnik71.narod.ru/termo_ds18b20.html) schematic and hex file (even source code...) for an thermometer... It works absolutely great ! NO FLICKERING despite the absence of external quartz/HS oscillator !
    How is made ?! I have no ideea ...
    BUT ... in PBP this can be done ?!? I gave up to many LED display projects, because of this issue - annoying flickering ...
    Know somebody a GOOD method to get a stable, sharp display ? Thanks in advance !
    Sep 2010
    Las Vegas, NV
    Although I can't open the sight I have a few questions. What is it you're trying to do? Improve upon project posted here or start from scratch?
    What is the range of temperature you want to display?
    What displays do you want to use? If flickering is a problem you could use a faster update rate but the display will only be as good as the quality of the display. I agree 7 segment LEDs are a dime a dozen but some are better than others. Although if you want large displays you may not be able to update them but will need to turn them on the whole time using FETs or transistors.
    What is it ultimately you'd like to see from this project?
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for reply !
    So ... using as hardware - 16F628A @ 4 MHz and LED display KW4-311AVA, I built one termometer, using DS18B20, with different variants of software (presented in this topic). All my variants have this issue - display flickering, more or less, but present.
    The hardware from the link posted above use same hardware, 16F628 @ 4 Mhz and same display. BUT ... no flickering ! The display look sharp and bright.
    So ... I intend to build an termometer, using same hardware, but flicker-free ! And, despite searching this forum, I could not find any convenient version to apply.
    This is why I asked for help ! Thanks in advance !
    Dec 2008
    Ploiesti, ROMANIA
    Tried a "variation" of code from post #20 :
    ;                        Termo LED 7 seg
    CMCON	= 7
    VRCON 	= 0
    INTCON 	= 0
        Common_4   	VAR PORTA.1
        Common_3   	VAR PORTA.0
        Common_2   	VAR PORTA.7
        Common_1   	VAR PORTA.6
        DQ            VAR PORTA.4
        DP            VAR PORTB.2
    Temp   	    Var     Byte
    TempC           Var     Word
    I               Var     Byte
    Sign            Var     Word
    Float           Var     Word
    V		    Var     Word
    Dummy           Var     Byte
    Busy		    Var     Bit
        DIGIT_0     VAR 	BYTE
        DIGIT_1     VAR 	BYTE
        DIGIT_2     VAR 	BYTE
        DIGIT_3     VAR 	BYTE
    digit		    Var 	BYTE
    Data @0,20,215,76,69,135,37,36,87,4,5,255
    PortA=%00000100
    TrisA=%00111000
    PortB=%11111111
    TrisB=%00000000
    T1CON = $1
    ' Init Sensor 1
     Pause 50
      Sign  = 1
    Endif
    TempC = DIV32 10
    If Sign=1 then
    EndIf
    If V >= 10000 then
      Temperature=V-10000
      sign = " "
      Temperature=10000-V
      sign = "-"
    EndIf
    Gosub Selectie
    Goto Main
    Selectie :
    If sign = "-" then
    PortB = %11101111
    PortB = %11111111
    IF Temperature DIG 2 = 0 THEN
    digit = " "
    digit = Temperature dig 2
        read digit, DIGIT_2
    digit = Temperature dig 1
        read digit, DIGIT_1
    digit = Temperature dig 0
        read digit, DIGIT_0
    Disp:
      TMR1H = %11111100
      TMR1L = %00011111
    Common_1 = 1 : PAUSE 1 : Common_1 = 0
    PortB = DIGIT_2
    Common_2 = 1 : PAUSE 1 : Common_2 = 0
    PortB = DIGIT_1
    Common_3 = 1 : DP = 0 : PAUSE 1 : Common_3 = 0 : DP = 1
    PortB = DIGIT_0
    Common_4 = 1 : PAUSE 1 : Common_4 = 0
    @ INT_RETURN
    ...but I have some errors :
    ERROR Line 95: Syntax error. (ReEnterPBP.bas)
    ERROR Line 128: Redefiniton of LABEL Vars_Saved. (ReEnterPBP.bas)
    ERROR Line 128: Syntax error. (ReEnterPBP.bas)
    Advices ?! Thanks !
    DT_INTS only works with the MPASM assembler.
    Your device statement indicates you are trying to use the old PM assembler.
    But I can say that 1-Wire and ASM Interrupts don't get along very well.
    1-Wire has very strict timing requirements. And ASM Interrupts have a tendancy to disturb that timing.
    1-Wire commands take enough time that if you stop the interrupts to do a software OWOUT/IN ... it will cause blinking.
    The only way I can see to scan LED's at a constant rate, and do 1-Wire I/O at the same time ... is to do the 1-Wire communications by Interrupts too.
    Sorry, don't have sample code.
    Dec 2008
    Ploiesti, ROMANIA
    Ok, I understand ...Thank You so much for advice ! I will try to figure out how doing 1-Wire by interrupts ...Regards !
    There's an example of reading the DS18B20 without using OWOUT/IN here ...
    http://support.melabs.com/content/389-TEMPX.pbp
    It doesn't use timer interrupts. It uses pauses instead.
    But it should give a good idea on how to read the sensor.
    Dec 2008
    Ploiesti, ROMANIA
    Many thanks ! Now I wait for account validation ... for see the example. Thanks again !
    Dec 2008
    Ploiesti, ROMANIA
    I'm stuck ...at red lines bellow ...
    ;                        Termo 7 seg
    CMCON	= 7
    VRCON 	= 0
    INTCON 	= 0
        Common_4   	VAR PORTA.0
        Common_3   	VAR PORTA.1
        Common_2   	VAR PORTA.2
        Common_1   	VAR PORTA.3
        DP            VAR PORTB.7
    Temp   	    Var     byte
    TempC           Var     Word
    I               Var     Byte
    Sign            Var     Word
    Float           Var     Word
    V		    Var     Word
    Dummy           Var     Byte
    Busy		    Var     Bit
        DIGIT_0     VAR 	BYTE
        DIGIT_1     VAR 	BYTE
        DIGIT_2     VAR 	BYTE
        DIGIT_3     VAR 	BYTE
    digit		    Var 	BYTE
    DQ VAR PORTA.4
    DQ_DIR var TRISA.4
    command var byte
    pis   var byte
    	TrisA.3=0:TrisA.4=1
    INTCON = %00100000
    INTCON = %10100000
       Gosub init1820      ' Init the DS1820
       command = $cc       ' Issue Skip ROM command
       Gosub write1820
       command = $44       ' Start temperature conversion
       Gosub write1820
       Pause 2000          ' Wait 2 seconds for conversion to complete
       Gosub init1820      ' Do another init
       Gosub write1820
    MAIN :
       command = $be       ' Read the temperature
       Gosub write1820
       Gosub read1820
    temperature = ??????
    sign = ????
    Gosub Selectie
    Goto Main
    Selectie :
    IF sign ="-" then
        DIGIT_3="-"
        DIGIT_3=" "
        DIGIT_2 = " "
    DISABLE
    ISR:
    for i=0 to 4
        COMMON_1 = 1 : PAUSE 1 : COMMON_1 = 0
        COMMON_2 = 1 : PAUSE 1 : COMMON_2 = 0
        COMMON_3 = 1 : DP = 0 : PAUSE 1 : COMMON_3 = 0 : DP = 1
        COMMON_4 = 1 : PAUSE 1 : COMMON_4 = 0
    next i
        SELECT CASE TEMP
        END SELECT
    INTCON.2=0
    RESUME
    ENABLE
    ' Initialize DS1820 and check for presence
    init1820:
       Low DQ              ' Set the data pin low to init
       Pauseus 500         ' Wait > 480us
       DQ_DIR = 1          ' Release data pin (set to input for high)
       Pauseus 100         ' Wait > 60us
       If DQ = 1 Then
          Pause 500
          Goto main        ' Try again
       Endif
       Pauseus 400         ' Wait for end of presence pulse
    ' Write "command" byte to the DS1820
    write1820:
       For pis = 1 To 8      ' 8 bits to a byte
         If command.0 = 0 Then
            Gosub write0   ' Write a 0 bit
         Else
            Gosub write1   ' Write a 1 bit
         Endif
         command = command >> 1  ' Shift to next bit
       Next pis
    ' Write a 0 bit to the DS1820
    write0:
       Low DQ
       Pauseus 60          ' Low for > 60us for 0
    ' Write a 1 bit to the DS1820
    write1:
       Low DQ              ' Low for < 15us for 1
     @ nop                 ' Delay 1us at 4MHz
       Pauseus 60          ' Use up rest of time slot
    ' Read temperature from the DS1820
    read1820:
       For pis = 1 To 16     ' 16 bits to a word
         temperature = temperature >> 1  ' Shift down bits
         Gosub readbit     ' Get the bit to the top of temp
       Next pis
    ' Read a bit from the DS1820
    readbit:
       temperature.15 = 1         ' Preset read bit to 1
       Low DQ              ' Start the time slot
       If DQ = 0 Then
          temperature.15 = 0      ' Set bit to 0
       Endif
       Pauseus 60          ' Wait out rest of time slot
    I have no ideea how to find the value of temperature ...
    I can't figure SIGN yet, but TEMPERATURE is set in READ1820 one bit at a time.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for reply !
    ...I know that, but on display I have only "0" ...so I think I need to ...re-define temperature ?!?
    I still have no clue how the sign is set, but you GOTO MAIN from within INIT1820; not a good thing, messes up the stack.
      Sign  = 1
    Endif
    Don't you need something like this at bottom of READ1820?
    Dec 2008
    Ploiesti, ROMANIA
    No matter what temperature I set to DS18B20 ; the display show always "0,1".
    Dec 2008
    Ploiesti, ROMANIA
    It's beyond on my understanding and mental capabilities ...
    ;                        Termometru 7 segmente
    ;@ DEVICE pic16F628A, intOSC_osc_noclkout, WDT_OFF, PWRT_ON, MCLR_OFF, LVP_OFF, CPD_OFF
    CMCON		= 7
    VRCON 	= 0
    INTCON 	= 0
        DP            VAR PORTB.7
    Temp   	    Var     byte
    TempC           Var     Word
    I               Var     Byte
    Sign            Var     Word
    Float           Var     Word
    V		    Var     Word
    Dummy           Var     Byte
    Busy		    Var     Bit
        DIGIT_0     VAR 	BYTE
        DIGIT_1     VAR 	BYTE
        DIGIT_2     VAR 	BYTE
        DIGIT_3     VAR 	BYTE
    digit		    Var 	BYTE
    DQ VAR PORTA.4
    DQ_DIR var TRISA.4
    command var byte
    pis   var byte
    	TrisA.3=0:TrisA.4=1
            INT_Handler   TMR1_INT,  _show,   PBP,  yes
    T1CON = $31                ; Prescaler=8, TMR1ON
    Gosub write1820
    Gosub write1820
    Gosub write1820
    MainLOOP:
    Gosub write1820
    Gosub read1820
    TEMPERATURE = ((tempERATURE>> 1)*100)+((TEMPERATURE.0*5)*10)
    Gosub Selectie
    Goto MainLOOP
    Selectie :
    IF sign ="-" then
        DIGIT_3="-"
        DIGIT_3=" "
        DIGIT_2 = " "
    show:
    for i=0 to 4
    next i
        SELECT CASE TEMP
        END SELECT
    @ INT_RETURN
    init1820:
       If DQ = 1 Then
          Pause 500
          Goto mainLOOP     ' Try again
       Endif
    write1820:
         Else
         Endif
       Next pis
    write0:
       Low DQ
    write1:
    read1820:
       Next pis
      Sign  = 1
    Endif
    readbit:
       If DQ = 0 Then
       Endif
    ERROR Line 23: Redefinition of VAR. (DT_INTS-14.bas) ?!?
    Can not be done a simple termometer with LED display ?
    Check the include, you used the same variable.
    Dec 2008
    Ploiesti, ROMANIA
    Found it :
    "wsave VAR BYTE $20 SYSTEM ' location for W if in bank0
    ;wsave VAR BYTE $70 SYSTEM ' alternate save location for W "
    But now I have nothing on display ?!
    I can only suggest to post all your most recent code. Maybe a senior can spot something.
    Dec 2008
    Ploiesti, ROMANIA
    OK, I will follow Your advice ...
    This is the last attempt, not-working (just "000" on display). Already feel like I came out of patience with this problem .
    ' Pulse counter   - attempt to converted for LED display termometer
    ' File name : Count_Display.bas
    ' Company : Mister E
    ' Programmer : Steve Monfette
    ' Date : 27/12/2004
    ' Device : PIC16F628A
    ' This program display to 3 x 7 segments dislay the result of
    ' pulses count on PORTA.4 pin/sec.
    ' Hardware connection :
    '      1. 3 X 7 segments display on PORTB<7:0>
    '      2. 3 X PNP transistor on PORTA<3:0> to drive common anode
    '         of each 7 segments display
    ' Programming mode and PIC define
    ;@ __config _HS_OSC & _WDT_ON & _PWRTE_ON & _LVP_OFF
    CMCON=7       ' ADDED FOR PIC16F628A
    DEFINE OSC 20 ' use 20 MHZ oscillator
        ' I/O Definition
    TRISA = %11111000 ' PORTA  : <2:0> outputs to common Anode of 7 segment
                          '                1. PORTA.0 More significant
                          '                2. PORTA.2 Less significant
                          '        : PORTA.4 input for signal
    TRISB = 0         ' PORTB connected to 7 segments
                      '       B0 : segment a
                      '       B1 : segment b
                      '       B2 : segment c
                      '       B3 : segment d
                      '       B4 : segment e
                      '       B5 : segment f
                      '       B6 : segment g
                      '       B7 : segment decimal dot
    ' Internal EEPROM definition
    data @0,192,249,164,176,153,146,130,248,128,144 ' table to convert
                                                    ' numbers to 7 segments
                                                    ' pattern output when
                                                    ' drive invert
    ' Interrupt and register definition
    OPTION_REG = %1111000   ' TMR0 clock source : RA4/T0CKI
                            ' increment on low to high transition
                            ' Prescaler assign to WDT
                            ' WDT rate 1:1
    INTCON = %10100000      ' Enable global interrupt
                            ' Disable EE write interrupt
        ' Variable definition
    DisplayPort  var PORTB   ' Port for 7 Segments
    ;ClockInput   var PORTA.4 ' Input pin for signal
    _7Seg1       con 14      ' enable more significant 7 segment display
    _7Seg2       con 13      ' enable mid significant 7 segment display
    _7Seg3       con 11      ' enable less significant 7 segment display
    Digit_1          var byte    ' Hundreds digit
    Digit_2          var byte    ' Tenth digit
    Digit_3          var byte    ' Unit digit
    ToBeDisplay  var word    ' Result of count to be send to 7 segment display
    Display      var byte    ' Temp variable
    DisplayLoop  var byte    '
    Delay        var word    ' Variable for Delay loop
    OverFlowVar  var word        '
    Thousands    var bit         ' Flag for count >= 1000 & < 10 000
    TenThousands var bit         ' Flag for count >= 10 000
    Temp   	        Var     byte
    TempC           Var     Word
    I               Var     Byte
    Sign            Var     Word
    DQ      VAR PORTA.4
    DQ_DIR  var TRISA.4
    command var byte
    pis     var byte
        ' Variable and software initialisation
    tobedisplay = 0 ' set initial value of count
    TMR0 = 0        ' reset prescaller
    On interrupt GoTo SetVarToBeDisplay
    Gosub write1820
    Gosub write1820
    Gosub write1820
    MainLoop:
    Gosub write1820
    Gosub read1820
        ' MainLoop
        ' 1. display the result of the count on RA4 pin
        ' 2. refresh display
        ' 3. reset Timer0
        ' 4. reload prescaler.
        ' Duration of the procedure : 1 sec
        '           fine tuned by DelayBetweenEachDisplay Sub
        ' Looping 1 sec and get results of the pulse count in
        ' TMR0 + OverFlowVar
    DisplayRefresh:
        ' Testing amount of count
        ' Get the result of count and place decimal point flag
        ' on the according 7 segments
        'If tobedisplay>= 1000 Then
        'tobedisplay = tobedisplay / 10
        'Else
        '    tenthousands = 0
        '       thousands = 1
        'EndIf
        ' convert digit to 7 segment output pattern
    display=ToBeDisplay dig 2 ' Read hundreds digit
    read display, digit_1     ' Convert hundreds
         if thousands==1 then digit_1=digit_1 & $7F ' enable decimal dot
                                                       ' by clearing PORTB.7
        display=ToBeDisplay dig 1 ' Read tenths digit
        read display, digit_2     ' Convert tens
            if tenthousands==1 then digit_2=digit_2 & $7F ' enable decimal dot                          '
            display=ToBeDisplay dig 0 ' Read units digit
            read display, digit_3     ' Convert units
        ' Send digit to 7 segments
        For displayloop = 0 To 111 ' loop for about 1 sec
            ' display hundreds
            PORTA=_7seg1        ' enable hundreds 7 segment
            displayport = digit_1 ' display
            GoSub DelayBetweenEachDigit
            ' display tenth
            PORTA=_7seg2        ' enable tenth 7 segment
            displayport = digit_2 ' display
            ' display units
            PORTA=_7seg3        ' enable unit 7 segment
            displayport = digit_3 ' display
        Next
        ToBeDisplay = Temperature
        GoTo DisplayRefresh
            For delay = 1 To 307
                @ nop
            Next
            @ nop
            @ nop
            @ nop
            @ nop
            @ nop
            @ nop
            @ nop
        disable
    SetVarToBeDisplay:
        ' SetVarToBeDisplay
        ' interrupt routine of TMR0 overflow
        ' Reset prescaller
        ' Reset overflow flag
        Temperature = ((tempERATURE>> 1)*100)+((TEMPERATURE.0*5)*10)
        INTCON.2 = 0 ' clear overflow flag
        TMR0 = 0     ' reload TMR0
        Resume
        enable
    init1820:
       If DQ = 1 Then
          Pause 500
       Endif
    write1820:
         Else
         Endif
       Next pis
    write0:
       Low DQ
    write1:
    read1820:
       Next pis
      Sign  = 1
    Endif
    readbit:
       If DQ = 0 Then
       Endif
  1. Windows 7 64 bit problem..can anyone help???
    By ljc4141 in forum mel PIC BASIC Pro
    Last Post: - 18th July 2011, 15:29
  2. LED Machine Tach For Tired Eyes
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:55
  3. adding with 7 segments
    Last Post: - 28th November 2007, 22:51
  4. 7 segments clock
    By the_apprentice in forum mel PIC BASIC Pro
    Last Post: - 27th April 2006, 18:45
  5. 7 segment digit problem (using Mister E's code)
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 20:25
