If you have in mind to use the downloaded software, the answer is IT WILL NOT WORK.
If you will write your own software the answer is YES IT WILL WORK.
Al.
Hi Aratti, your project has inspired me to do one by myself. I wont be connecting to the computer (as it does not have an serial port) neither I can get 16F873 that easily. So I am using 16F690.
Any advise as to how to set up the registers, correctly for 690?
