How can I get this to stop flickering? It flickers even at 16MHz. With 4 MHz it taks the GSCLK about 250 ms to complete making all the GSDATA that are 0's really stand out causing a flicker.
Is there some other way I could do the GSCLK so I am not just turning the GSCLK pin H/L 4096 times?
ANSEL = 0 'ALL DIGITAL
CMCON = 7 'COMPARATORS OFF
TRISA = %00000000
TRISB = %00000000
DPIN CON 7
SCLK CON 6
XLAT CON 5
BLANK CON 2
VPRG var PORTA.0
DCPRG var PORTA.2
C1 var byte
C2 var byte
C3 var word
GSDATA var word
GOSUB preset
'* Main Loop *
LOOP:
FOR GSDATA = 4095 TO 0 STEP -16
gosub setgs
gosub lightemup
NEXT
FOR GSDATA = 4095 TO 0 STEP 16
gosub setgs
gosub lightemup
NEXT
goto LOOP
'* Set GS *
SETGS:
for C1 = 0 to 15 ' for 16 outputs
shiftout dpin,sclk,1,[GSDATA\12] ' shift out 12 bit GS Data
next
PORTB = %00100000 ' high xlat
PORTB = %00000000 ' low xlat
'* LIGHT EM UP *
LIGHTEMUP:
PORTB = %00000100 ' high blank
PORTB = %00000000 ' All outputs = ON
for C3 = 0 to 4095 ' Generate 4096 GSCLK pulses
PORTA = %00001000 ' GSCLK HIGH
PORTA = %00000000 ' GSCLK LOW
next
'* Preset *
PRESET:
'HIGH DCPRG
HIGH VPRG ' Put into dot correction mode
HIGH blank ' All outputs OFF
low dpin ' Starts dot correction
low xlat
For C1 = 0 to 15 ' 16 Ports
shiftout dpin,sclk,1,[%111111\6] ' 6 bits of Dot Correction per port
next
high xlat ' Latch bits into dot correct register
low xlat
low VPRG ' Enter GS Mode
for C1 = 0 to 15
for C2 = 0 to 11
shiftout dpin,sclk,1,[%111111111111\12]
next
next
high xlat ' Latch bits into GS register
low xlat
high SCLK '193rd CLK pulse
LOW SCLK
low blank ' All outputs = ON
NOTE: This code is basically the same as the above Adruno code but I have a different fade routine. The above code used direct PORT addressing for GSCLK like I did but they were using an 8MHz Adruno for their project and it worked fine. I don't understand why this will not work in PBP with 16 MHz running the show.
