Audio Frequency Counter
Results 1 to 9 of 9
    Default Audio Frequency Counter
    Hi, here's a simple code based on a PIC16F84A-20/P. Can be use as a audio frequency counter. It show the frequency on 3 x 7 segments display. It also place the decimal point.
    have fun !
    And those who want also the schematic + code package, see this link to the Melabs Website. Choose Counter.zip
    http://www.melabs.com/resources/samples.htm#submitted
    sanchit04421's Avatar
    sanchit04421 Guest
    Default pic as a frequency counter
    hi.
    i m new here
    i wanted t know if i could get a pic program code for frequency counter which can measure upto 1mhz.
    is it available for download on net??
    i need it urgent for my project! thanks
    Sep 2003
    INDIA
    Default Help required
    Hello Steve,
    I have run into some problem using your code for a 16F628A with a 16x2 LCD.
    I am basically making a audio frequency counter, which would then be used to control a set of 8 LED's depending upon the Input frequency on PORTB.
    Keeping this in mind I tried to output the frequency on the LCD but I get jumping figures at high speed. I believe , I have to introduce a delay between the display. Secondly , connecting 10K to ground on Pin#3 with 1K in series , as your circuit says, I don't get any reading. Which means , I need some impedence matching or may be a signal conditioner.
    My audio source is from my desktop computer , audio out.
    my code so far -
    @   __CONFIG  _HS_OSC & _MCLRE_OFF  &  _LVP_OFF & _WDT_ON & _PWRTE_ON  & _BODEN_ON
    DEFINE OSC 20
                ;76543210
        TRISB = %00000000
        TRISA = %11110000
    DEFINE LCD_DREG PORTB 			'Define PIC port used for LCD Data lines
    DEFINE LCD_DBIT 0 			    'Define first pin of portb connected to LCD DB4
    DEFINE LCD_RSREG PORTB 			'Define PIC port used for RS line of LCD
    DEFINE LCD_RSBIT 5 			    'Define Portb pin used for RS connection
    DEFINE LCD_EREG PORTB 			'Define PIC prot used for E line of LCD
    DEFINE LCD_EBIT 4 			    'Define PortB pin used for E connection
    DEFINE LCD_BITS 4 			    'Define the 4 bit communication mode to LCD
    DEFINE LCD_LINES 2 			    'Define using a 2 line LCD
    'DEFINE LCD_COMMANDUS 2000 		'Define delay between sending LCD commands
    'DEFINE LCD_DATAUS 50 			'Define delay time between data sent.
        ' Interrupt and register definition
        OPTION_REG = %1111000   ' TMR0 clock source : RA4/T0CKI
                                ' increment on low to high transition
                                ' Prescaler assign to WDT
                                ' WDT rate 1:1
        INTCON = %10100000      ' Enable global interrupt
                                ' Disable EE write interrupt
                                ' Enable TMR0 overflow interrupt
        CMCON = 7            ' disable analog comparator
        VRCON = 0            'turns off Vref for min current
        ' Variable definition
        DisplayPort  var PORTB   ' Port for 7 Segments
        ClockInput   var PORTA.4 ' Input pin for signal
        _7Seg1       con 14      ' enable more significant 7 segment display
        _7Seg2       con 13      ' enable mid significant 7 segment display
        _7Seg3       con 11      ' enable less significant 7 segment display
        Digit_1	     var byte    ' Hundreds digit
        Digit_2	     var byte    ' Tenth digit
        Digit_3	     var byte    ' Unit digit
        ToBeDisplay	 var word    ' Result of count to be send to 7 segment display
        Display      var byte    ' Temp variable
        DisplayLoop  var byte    '
        Delay        var word    ' Variable for Delay loop
        OverFlowVar  var word	 '
        Thousands	 var bit	 ' Flag for count >= 1000 & < 10 000
        TenThousands var bit	 ' Flag for count >= 10 000
        ' Variable and software initialisation
        tobedisplay = 0 ' set initial value of count
        TMR0 = 0        ' reset prescaller
        on interrupt goto SetVarToBeDisplay
    MainLoop:
        ' MainLoop
        ' 1. display the result of the count on RA4 pin
        ' 2. refresh display
        ' 3. reset Timer0
        ' 4. reload prescaler.
        ' Duration of the procedure : 1 sec
        '           fine tuned by DelayBetweenEachDisplay Sub
        ' Looping 1 sec and get results of the pulse count in
        ' TMR0 + OverFlowVar
    DisplayRefresh:
        ' Testing amount of count
        ' Get the result of count and place decimal point flag
        ' on the according 7 segments
        If tobedisplay>=1000 then
        	tobedisplay=tobedisplay/10
        	if tobedisplay>=1000 then
        		Thousands=0
        		TenThousands=1
        		TenThousands=0
        		thousands=1
        	thousands=0
        	tenthousands=0
        LCDOut $FE,$C0, "COUNT: ",DEC tobedisplay , "    "
        gosub DelayBetweenEachDigit
        tobedisplay = OverFlowVar + TMR0
        OverFlowVar = 0 ' Reset OverFlowVar
        goto DisplayRefresh
        goto DisplayRefresh
        goto DisplayRefresh
        goto DisplayRefresh
        goto DisplayRefresh
        goto DisplayRefresh
    DelayBetweenEachDigit:
        ' DelayBetweenEachDigit
        ' Produce delay of about 3 mSec
        ' Fine tuned with MPLAB StopWatch to get MainLoop = 1 sec
    	for delay=1 to 307
    	    @ nop
    	next
    	@ nop
    	@ nop
    	@ nop
    	@ nop
    	@ nop
    	@ nop
    	@ nop
        disable
    SetVarToBeDisplay:
        ' SetVarToBeDisplay
        ' interrupt routine of TMR0 overflow
        ' Reset prescaller
        ' Reset overflow flag
        OverFlowVar = OverFlowVar + 256
        INTCON.2 = 0 ' clear overflow flag
        TMR0 = 0     ' reload TMR0
        resume
    enable
    Quote Originally Posted by charudatt View Post
    Hi charudatt,
    Here is an Idea to help with the jitters, after the LCDOUT, save tobedisplay var to a dummy var, and then before updating the display check to see if tobedisplay = dummy and if it does, go back to the loop until it changes.
    Also, what's that about?
    goto DisplayRefresh
        goto DisplayRefresh
        goto DisplayRefresh
        goto DisplayRefresh
        goto DisplayRefresh
        goto DisplayRefresh
    Sep 2003
    INDIA
    Default Thanks Joe
    I thought I got my bearing all messed up. My project is basically a Sound to Light idea (Disco light), and I thought , it was done by sampling the frequency and hence , I went about trying a Audio frequency meter.
    There was a error in the code, I wanted to introduce a slight delay in the LCD routine and i put in those lines to goto DisplayRefresh, actually it should have been Gosub DisplayRefresh.
    Anyway, any pointer / idea for disco lights using PIC.
    Thanks all.
    regards
    I built one (actually several) back around 1971 in high school electric shop, used an audio transformer secondary to speaker and primary to the gates of 3 SCRs through 3 R/C filters for 3 channel outputs to control 3 strings of colored lights put behind diffuser panels made for fluorescent lights. Wow shades, some Metal music, some get high, and who could even think of going to war ?
    Back on topic . . . R/C network, Analog voltage detection, digital output . . . same theory should work.
    Sep 2003
    INDIA
    OK , did you mean this http://4.bp.blogspot.com/_BQac7gcHPK...1600/color.gif
    Anyway , I got a lot of dope on this forum relating to this topic and shall give it a try.
    Thank you for the help.
    regards
    regards
    http://4.bp.blogspot.com/_BQac7gcHPK...P-keI3U/s1600/
    Yes, that was it.
  1. frequency counter help and pointers
    By comwarrior in forum General
    Last Post: - 30th June 2009, 11:51
  2. Replies: 14
    Last Post: - 26th September 2007, 05:41
  3. Frequency Counter
    By Asmith in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2007, 15:54
  5. Frequency Counter using PIC and PicBasic
    By PICtron in forum mel PIC BASIC Pro
    Last Post: - 28th January 2005, 06:20
