ADC trouble with PIC16F88
Results 1 to 10 of 10
    Nov 2008
    Default ADC trouble with PIC16F88
    Hello all,
    I'm newbie, the goal of my project it's to use only RA0 in ADC mode and
    the rest of TRISA in a digital input but, in this setting don't work.
    Any help will be appreciated.
    Thanks a lot and regards
    giorgio
    The Code :
    '* Name : CONTROLLER.BAS *
    '* Notice : Copyright (c) 2008 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 26/11/2008 *
    '* Version : 1.0 *
    '* Notes : *
    '* Chip : PIC16F88 *
    INCLUDE "MODEDEFS.BAS"
    define OSC 4
    adval VAR BYTE
    i var BYTE
    RPM VAR BYTE
    ADCON0.7 = 1 ' right justify result
    ANSEL = %00000001 ' set AN0 analog, rest digital
    CMCON = 7 ' analog comparators off
    TRISA = %00001111 'RA.0:3 Input
    TRISB = %00000000 'all PORTB output
    Output PORTB.4 ' set RB0 as output
    Output PORTB.5 ' set RB1 as output
    loop:
    ADCIN 0,adval
    IF adval < 90 THEN
    HIGH PORTB.4
    IF adval > 100 THEN
    LOW PORTB.4
    COUNT PORTA.2,250,RPM
    for i = 1 to rpm
    toggle PORTB.5
    PAUSE 25
    NEXT i
    LOW PORTB.5
    GOTO loop 'repeat
    Jun 2007
    Default Do you have a resistor
    Hi and welcome,
    The code appears to be okay to me ( another newbie).
    You don't need these lines as you already set TRISB = 0
    I just wondered if you have a resister on RA0 to limit the current into the pin.
    If you don't you may damage the PIC.
    Hope this may help.
    Mike
    Howdy,
    This
    should be
    ADCON1.7 = 1 ' right justify result
    This may help also
    http://rentron.com/PIC12C67XAD.htm
    Different PIC, same type of ADC.
    Nov 2008
    Quote Originally Posted by mikendee View Post
    Hi and welcome,
    Hope this may help.
    Mike
    Thanks , it was a mistake
    Nov 2008
    Howdy,
    This
    should be
    This may help also
    Hello Dave, thanks a lot, but the very big problem it's the IC-PROG and JDM Programmer, that apparently don't give any error but the PIC is not programmed.
    Tomorrow try to unreverse the serial communications signal in the JDM section.
    TNX
    giorgio
    Save your headaches and look to getting a PICKIT2 from MicroChip.
    Nov 2008
    Default Pickit2 buyed
    Hello Dave,
    pickit buyed and running, I've too mounted a 18 pin in a board connected with the ICSP signal.
    It's all ok with pic 16f628, but with 18f88 have this alarm message
    The code :
    '* Version : 1.0 *
    '* Notes : *
    TRISA = %11111111 'RA.0:3 Input
    ANSEL=%00000001'only porta.0 is analogue
    ADCON1=%00000010'right justify the result(top bits are read as zero)
    CMCON = 7 'Turn off comparators
    adval VAR BYTE
    i var BYTE
    RPM VAR BYTE
    ' Define ADCIN parameters
    Define ADC_BITS 8 ' Set number of bits in result
    PAUSE 500
    loop:
    ADCIN 0,adval
    serout PORTB.6,n2400, [$FE, 1]
    serout PORTB.6,n2400, [$FE, 2, "pressione ", #adval]
    serout PORTB.6,n2400, [$FE, $C0, "giri", #rpm]
    IF adval < 90 THEN
    HIGH PORTB.4
    IF adval > 120 THEN
    LOW PORTB.4
    for i = 1 to rpm
    toggle PORTB.5
    PAUSE 25
    NEXT i
    LOW PORTB.5
    GOTO loop 'repeat
    Any help will be apreciated,
    Thanks a lot
    giorgio
    Can you post you inc file with the config settings?
    Nov 2008
    Hi Dave , I'm at home now, but have the original one from MPASM 8.10 ans pbc Pro 2.50. MicoCode Studio Plus last release.
    Tomorrow (now it's 23,20 pm) I'll post the file.
    tnx
    Nov 2008
    Hi Dave , I've posted the files in a PicBasicPro forum:
    http://www.picbasic.co.uk/forum/showthread.php?t=10207
  1. ADC Problem with PIC16F88 Configuration
    By robert.quaas in forum mel PIC BASIC Pro
    Last Post: - 9th April 2009, 17:46
  2. Trouble with PIC16F88 (chip hangs up)
    By nobner in forum mel PIC BASIC Pro
    Last Post: - 20th January 2009, 09:23
  3. PICKIT2 - PBC Pro - PIC16F88 TROUBLE
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2008, 23:37
  4. ADC Vref+ on PIC16F88
    By kblim in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2008, 10:14
  5. ADC conversion trouble
    By PICante in forum mel PIC BASIC Pro
    Last Post: - 30th April 2008, 20:42
