confused problem with interrupt in a working program
Results 1 to 6 of 6
Threaded View
    Default confused problem with interrupt in a working program
    Although i have made a lot of simple programs in my first big program i am in a dead end! i have made a controller-joystick for a wirelless car
    i have this program that works ok:
    INCLUDE "Modedefs.bas"
    TRISA=255
    TRISC=%1000000
    TRISB=0
    ADCON1.0=1 'all porta digital for switches
    ADCON1.1=1
    ADCON1.2=1
    ADCON1.3=0
    DEFINE LCD_DREG PORTB 'LCD Configuration in portb
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 3
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 2
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_DATAUS 50
    CO VAR WORD
    B0 VAR BYTE
    B1 VAR BYTE
    B2 VAR BYTE
    A VAR BIT
    B VAR BYTE
    C VAR BIT
    FLAG VAR BIT
    A=0
    C=0
    B=0
    FLAG=0
    Pause 1000
    IF (PORTA.0==0 && A==1) then ' decision (up-down switches) about velocity of a robot
    B=B+1
    FLAG=1 'flag to know if a button was pressed
    EndIF
    IF (PORTA.1==0 && C==1) Then
    B=B-1
    FLAG=1
    EndIF
    IF (B>4 && B<250) Then '5 levels for velocity
    B=4
    EndIF
    IF B>250 Then
    B=0
    EndIF
    A=PORTA.0 'old situation of ports to compare in order to understand when the buttons were pressed
    C=PORTA.1
    IF b==0 Then ' flashing leds dependable to the velocity
    Low PORTD.7
    Low PORTD.6
    Low PORTD.5
    Low PORTD.4
    High PORTC.5
    EndIF
    IF b==1 Then
    Low PORTD.7
    Low PORTD.6
    Low PORTD.5
    high PORTD.4
    High PORTC.5
    EndIF
    IF b==2 Then
    Low PORTD.7
    Low PORTD.6
    high PORTD.5
    high PORTD.4
    High PORTC.5
    EndIF
    IF b==3 Then
    Low PORTD.7
    high PORTD.6
    high PORTD.5
    high PORTD.4
    High PORTC.5
    EndIF
    IF b==4 Then
    high PORTD.7
    high PORTD.6
    high PORTD.5
    high PORTD.4
    High PORTC.5
    EndIF
    PAUSE 12
    gosub LPD
    IF FLAG=1 THEN
    SerOut2 PORTC.6, 84, ["v: ",DEC B,13,10]
    IF FLAG=0 THEN
    GOTO MAIN
    FLAG=0
    GoTo main
    LPD:
    LCDOUT $FE,1,"V: ",DEC B
    The problem is that i want to know something about the car. so i want an interrupt in serial port (rx -portc.6) and that is where the problems started
    i made the following program. but even my joystick becomes dead (not to metion that i can't see anything in terminal!).with underlines the changes of the above program.Any ideas are welcome....
    TRISA=255
    TRISC=%1000000
    TRISB=0
    ADCON1.1=1
    ADCON1.2=1
    ADCON1.3=0
    DEFINE HSER_RCSTA 90h ' enable serial port,
    ' enable continuous receive
    DEFINE HSER_TXSTA 24h ' enable transmit,
    ' BRGH=1
    DEFINE HSER_BAUD 9600
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSBIT 3
    DEFINE LCD_EBIT 2
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    CO VAR WORD
    RCIF VAR PIR1.5 ' Receive interrupt flag (1=full , 0=empty)
    OERR var RCSTA.1
    CREN VAR RCSTA.4
    INTCON = %11000000
    ON INTERRUPT GOTO serial
    PIE1.5 = 1
    TXIF VAR PIR1.4
    B0 VAR BYTE
    B1 VAR BYTE
    B2 VAR BYTE
    A VAR BIT
    B VAR BYTE
    C VAR BIT
    FLAG VAR BIT
    A=0
    C=0
    B=0
    FLAG=0
    Pause 1000
    B=B+1
    EndIF
    B=B-1
    FLAG=1
    EndIF
    B=4
    EndIF
    IF B>250 Then
    B=0
    EndIF
    C=PORTA.1
    Low PORTD.7
    Low PORTD.6
    Low PORTD.5
    Low PORTD.4
    High PORTC.5
    EndIF
    IF b==1 Then
    Low PORTD.7
    Low PORTD.6
    Low PORTD.5
    high PORTD.4
    High PORTC.5
    EndIF
    IF b==2 Then
    Low PORTD.7
    Low PORTD.6
    high PORTD.5
    high PORTD.4
    High PORTC.5
    EndIF
    IF b==3 Then
    Low PORTD.7
    high PORTD.6
    high PORTD.5
    high PORTD.4
    High PORTC.5
    EndIF
    IF b==4 Then
    high PORTD.7
    high PORTD.6
    high PORTD.5
    high PORTD.4
    High PORTC.5
    EndIF
    PAUSE 12
    gosub LPD
    IF FLAG=1 THEN
    IF FLAG=0 THEN
    GOTO MAIN
    FLAG=0
    GoTo main
    LPD:
    disable
    serial:
    HSerin [WAIT ("d"),DEC serial_in]
    if rcif then serial
    HSerOut ["hit on wall",13,10]
    high PORTE.0
    RESUME
    ENABLE
    Last edited by illuminator4; - 13th November 2008 at 20:54. Reason: will anyone reply? (snif snif)
  1. urgent: interrupt problem please help
    By cwmaddy in forum General
    Last Post: - 21st July 2009, 19:14
  2. USART interrupt in PIC16F877A
    By amindzo in forum General
    Last Post: - 26th August 2006, 18:51
  3. Simple Interrupt Program
    By eoasap in forum General
    Last Post: - 28th October 2005, 16:22
  4. Interrupt Problem
    By FrankM in forum mel PIC BASIC Pro
    Last Post: - 20th June 2004, 15:53
  5. interrupt problem....need help urgently
    By johnson in forum mel PIC BASIC Pro
    Last Post: - 14th April 2004, 17:34
